-   -   Airaid CAI Installed (http://www.tacomaworld.com/forum/performance-tuning/286059-airaid-cai-installed.html)
BLOODYMARY 07-11-2013 06:52 PM
I could find very little discussion on the Airaid CAI so I figured I would bite the bullet. By far the most intricate cold air intake install I have ever done. I had to relocate the AC line bracket, cut and splice in a wiring extension for the air pump per the instructions and a few other things. On a positive note fitment is perfect and no cel. Road review and possible vid tomorrow. This thing is huge and engine cover will not fit. But so far I like my little noise maker.
http://img.tapatalk.com/d/13/07/12/pazuhegy.jpg
http://img.tapatalk.com/d/13/07/12/nutu2una.jpg
http://img.tapatalk.com/d/13/07/12/2eje2aze.jpg
http://img.tapatalk.com/d/13/07/12/vapu2y3e.jpg
http://img.tapatalk.com/d/13/07/12/yzetujuh.jpg
Krazie Sj 07-11-2013 07:31 PM
Pretty sure that one is for trucks with a snorkel.
You may want to check on that before you start running around.
WHPLSH3 07-11-2013 08:21 PM
I've got the same one. Only ran it for a week before S/C install, but very impressed. Hasn't tripped a CEL ever
S1000RR 07-12-2013 05:26 PM
Been running the same with my Supercharger for a while now. Love it. No problems or anything.
BLOODYMARY 07-12-2013 06:12 PM
Yeah its great still quiet unless I romp it!
MadToy 07-13-2013 02:09 AM
Where is the MAF sensor?
WHPLSH3 07-13-2013 07:22 AM
The MAF sensor is on the bottom of the main tube, about halfway (basically underneath the Airaid logo).
This is the only thing I wonder about with this kit... I think those of us that have it may be replacing the MAF prematurely because of this. Every auto maker hangs the MAF down so moisture can't gather on it when driving in inclement weather... but we'll just need to wait and see.
Also, during installation I found it impossible to use the supplied wiring extensions for the air pump- the spades on their wires wouldn't fit in my connector properly, despite my modifying on the bench grinder for an hour. I ultimately cut the factory harness halfway and spliced homemade extensions in using wire the same color & gauge sealed with heat shrink solder style connectors. I wrapped everything, including the now rerouted ac lines, with plastic conduit to keep anything from chafing over the life of the vehicle
Gadget@URD 07-13-2013 08:06 AM
Do you happen to have a scan tool or scan gauge?
If so can you check the fuel trim deviation at a steady 60 MPH on flat ground and then again at idle?
Thanks!
G
WHPLSH3 07-13-2013 08:09 AM
I have a basic trouble code scanner or the Torque app. Will either of these work?
I think I may buy your recalibrator anyways...
