-   -   Digital or analog Gauges?! (http://www.tacomaworld.com/forum/performance-tuning/300754-digital-analog-gauges.html)
TRD2006 10-29-2013 10:07 PM
3 Attachment(s)
Im looking at getting a set of gauges for when I do my turbo build, I really like the look of the Autometer gauges, but I'm torn between getting a digital or analog wideband air to fuel gauge. The boost gauge I think I'm going to go with is the analog.
Analog Air to Fuel...
Digital Air to Fuel...
Boost Gauge...
All input is appreciated! :)
Lurkin 10-30-2013 06:49 AM
If you want the ability to take a quick glance at the guage and comprehend what is happening, analog. If you want to look, see the number, and internalize what it means, or to just get a more exact reading, digital.
RenoTacoma 11-01-2013 10:28 PM
Definitely digital, Its what I run on my turbo car.
Rich91710 11-01-2013 10:59 PM
Analog for inside of a vehicle.
Much easier to quickly process mentally.
Digital requires you to read and comprehend the number, then consider where on the scale it is, good or bad.
Analog is right there... you know where "good" is on the scale.
Digital is better for bench equipment where you are taking the time to fine-tune something, but when driving, speed of comprehension is key.
AWilson013 11-01-2013 11:21 PM
I run AEM's line of Digital gauges. They look awesome, work even better, and have an "analog" side to them as well.
http://www.aemelectronics.com/wideba...fuel-gauge-25/
http://www.aemelectronics.com/transm...e-100-300f-764
http://www.aemelectronics.com/gauges...oost-gauge-45/
I run their Wideband A/F, Boost, and Trans Temp
Torspd 11-04-2013 12:19 PM
Digital display for the AFR.
For boost, or others, a gauge that has a digital signal converter from analog, but still uses a sweeping needle.
RenoTacoma 11-04-2013 08:34 PM
I use a digital for AF/R and analog for Vaccum/boost.
WOODEX M.E. 11-06-2013 05:15 PM
1 Attachment(s)
I used analog for both, only because I wanted them to match tho. I will say you might like the digital AFR more, but either is fine. Here is a pic of what I did.
AWF ROWD 11-07-2013 04:10 PM
What Wilson said...best of both worlds...Gadget over at URD sells the Cravenspeed Dual 52 mm Flex Pods that holds them perfectly...
http://urdusa.com/p1260519003/FlexPo...duct_info.html
Justus 11-10-2013 05:39 AM
AEM wideband with digital readout and colored "sweep" for quick reading.
Full analog boost gauge (personal preference).
wideband is same AEM listed above (AEM 30-4100 UEGO), its just not wired in when I took this pic
https://fbcdn-sphotos-d-a.akamaihd.n...97282381_o.jpg
autometer analog boost
https://fbcdn-sphotos-h-a.akamaihd.n..._3667909_o.jpg
