Oil catch can
Discussion in 'Performance and Tuning' started by Detective_Dan, Jan 25, 2014.
  1. Jan 25, 2014 at 3:15 PM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Jason
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    hey gents,
    just finished installing my Add W1 oil catch can. i bought it off Amazon, free 2 day shipping for $89 at my door. I ordered it on a Thursday evening and it was at my door at 10am on Saturday.
    it seems to be pretty damn high quality. all machined aluminum parts, with 15mm and 9mm fittings. i used the 9mm fittings and bought 8ft of 7/16" fuel line because the line that comes with it is kinda shitty.
    just a fore-warning to those of you who cant tell from the pictures; no, i dont have massive hands, this can is just pretty tiny. even though it is small, there is no need to worry because the amount that i caught over a 5000 mile period can be held in the reservoir with room to spare.
    whats in the box? everything you need (unless you want different line like i did)
    the can even has a sealed dipstick so you can check the oil level without having to unscrew the whole can.
    i put an o-ring on the dipstick just to re-assure myself that it is sealed, so bust out your handy dandy o-ring kit if you have one
    i mounted it above the driver wheel well behind the battery. also, make sure you use teflon tape to seal the tube fittings on the can
    then remove your PCV, run your lines and hose clamp them. FROM engine goes to the inlet, TO intake goes on the outlet.
    then start her up, and check for a seal and no CEL's.
    you can hear the tight seal and vacuum when i pull out the dipstick
    http://www.youtube.com/watch?v=0fMFJPiWlcI&feature=youtu.be
    ill update this thread every so often to show the amount of oil that has been caught
    EDIT: 31 January 2014
    after only 4 days and 100 miles of driving, it has caught about 3 tablespoons of oil. the unit has already paid for itself in my eyes
    UPDATE as of 26 April 2014:
    heres what ive got after 2,500 miles exactly. this is a normal sized nestle water bottle. (duct tape is on it so it doesnt leak because im moving lol)
    UPDATE as of 30 June 2014
    this is what ive got after 5000 miles on the dot. 16.9 fl oz water bottle
    UPDATE: as of 14 Sep 2014
    probably the last "oil amount" update ill do, as im sure you all get it by now.
    10,000 miles on the dot, and heres what ive saved from being pushed back into the motor
  2. Jan 25, 2014 at 6:32 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    can you tell me what is it good for? better gas mileage?
  3. Jan 25, 2014 at 6:41 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    it catches gases and oil vapor that is recirculated back into the intake. look for more threads at the bottom.
  4. Jan 25, 2014 at 7:11 PM
    Detective_Dan
    Jason
    Colorado Springs
    It replaces your pcv hose. Positive crankcase ventilation. All of the blowby gases that would normally be injected back through your intake after the throttlebody, get trapped in the can, instead of being "burned off" by the motor. It causes gunk buildup in the motor so this prevents that from happening. You just empty it every few thousand miles or so
  5. Jan 25, 2014 at 7:47 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 GX550 Overtrail+
    blow by gases. keeps the combustion chamber, throttle body, and maf clean :thumbsup:
    BTW nice write up Detective Dan, I plan to add the other one on the passenger side too :thumbsup:
    Stryker420 likes this.
  6. Jan 26, 2014 at 4:43 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    not so low, not so slow 2006 6 lug
    stockish
    Butterfly catcher
  7. Jan 26, 2014 at 8:46 AM
    Detective_Dan
    Jason
    Colorado Springs
    Dream catcher
  8. Jan 26, 2014 at 10:24 AM
    Detective_Dan
    Jason
    Colorado Springs
    i put a chunk of stainless steel scrub brush in the baffle so that the oil vapor has something to stick and condense to. no pic of it but you get the idea. the baffle unscrews so you can put whatever filter media you want in it.
    825a7ae2-c648-4b1c-b532-36a5cfd56e76_zps_20e9485811a13dc7275dd4465a9cd9651ca23be7.jpg
    Moonkonchoe, Kolunatic and Pirhett like this.
  9. Jan 27, 2014 at 4:45 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  10. Jan 27, 2014 at 5:18 PM
    Detective_Dan
    Jason
    Colorado Springs
    Thanks toe. For $89, I couldn't not give it a try. I've bought cans almost twice this much with equal or lesser build quality on them. You're basically paying for a name brand at that point
  11. Jan 27, 2014 at 5:22 PM
    Detective_Dan
    Jason
    Colorado Springs
    I would absolutely recommend this can to anyone. Great quality at good price. Plus it doesn't have those shitty sight tubes or draincocks at the bottom that are prone to leaking
    The_Black_Pearl likes this.
  12. Jan 29, 2014 at 5:36 PM
    Detective_Dan
    Jason
    Colorado Springs
    after EXACTLY 100 miles of driving, i popped it open to check what has been collected. quite a bit for only 100 miles. cant wait to see what it will catch in the next few thousand
  13. Feb 5, 2014 at 11:20 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Nice one Dan. I think i have their older can on my truck. I have yet to see if it will collect anything once i get my truck back from the shop lol.
  14. Feb 6, 2014 at 6:03 AM
    Detective_Dan
    Jason
    Colorado Springs
    Does the older model have the baffle to put mesh in? If so I recommend it. It's catching more now that the vapor has something to condense on.
    Don't use anything really fibrous like steel wool. Really small stuff has the capabilities of breaking apart and going into your intake
  15. Feb 6, 2014 at 8:22 AM
    RedLantern
    Honolulu, Hi
    no baffle..ill end up modifying it at work tho.
  16. Feb 12, 2014 at 10:14 AM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Very good looking can, looks to catch very well too.
    Googleing around, I can't find the actual companies home page or website... anyone have their homepage?
  17. Feb 12, 2014 at 12:32 PM
    Detective_Dan
    Jason
    Colorado Springs
    this is the exact one i ordered from the exact same company. just make sure to get some new 7/16'ths fuel line because you need to use the smaller nipples with this can on our engines. + the hose that comes with it is crap
    http://www.amazon.com/ADD-W1-Univer...92237023&sr=8-1&keywords=add+w1+oil+catch+can
  18. Feb 12, 2014 at 1:23 PM
    BlackSportD
    Los Angeles
    I ask because I'm curious about the company itself. They seem to make air fuel gauges, HUDs etc, but I had never heard of them before and its now very interesting to me that I can't find any info on them.
  19. Feb 12, 2014 at 2:56 PM
    Detective_Dan
    Jason
    Colorado Springs
    ive never heard of them before either, but im very impressed with the quality and finish of it for the price
  20. Feb 28, 2014 at 12:12 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Did you fab up a bracket for this? I see the two holes that are there from factory but I see you still used the two small bolts that came with the can? Just received mine today so hopefully installing it tomorrow.
    Edit: saw there were nuts for those two, so I take it you just drilled two holes and then bolted through the fender wall?
