-   -   Need suggestions for BRAKES (http://www.tacomaworld.com/forum/performance-tuning/42201-need-suggestions-brakes.html)
BluTaco08 06-24-2009 07:33 PM
My next modification to the tacoma will be a brake upgrade. I've gone from a 15inch to a 16inch wheel that are fairly heavy and I've also increased my tire size. I need some good suggestions for brakes. Any help is appreciated. If more info about the wheels and tires are required let me know. Thanks a lot everybody!
BluTaco08 06-24-2009 07:48 PM
Originally Posted by wolfpack_5150 (Post 711622)
What would really help is a budget to work with.......I could but wouldnt suggest some crappy cheap pads and tell u to scuff up ur rotors.........I could also point u in the direction of a 2,000+ setup.
What do u have to spend roughly?
I'd like to spend no more than about 800-900 on brakes. Now that being said, if I can get a decent setup with that money then I will...but if I need to go a couple hundred higher to get good, safe, quality brakes then I will. Hope this helps.
