"Fast idle" on 6 spd manual won't slow me down
Discussion in 'Performance and Tuning' started by Neotoma, Mar 10, 2010.
  1. Mar 10, 2010 at 8:22 AM
    Neotoma
    Neotoma [OP] Member
    Alaska
    TRD Offroad 4x4
    De-activated seatbelt chime! Whew!
    I bought a '10 6 spd manual, because I like to use the transmission to slow me down, especially descending steep hills. When fully warmed up, this truck has a "fast idle" (probably an emissions thing) which won't disengage until I reach a certain lower RPM or speed in that particular gear. So the net effect is that I have to break (EXACTLY what I was trying to avoid w/ a manual). Is there a mod for deactivating that "fast idle"? My '98 4Runner manual (190k), if I double-clutch it, will slow me down from any speed in any gear.
    On the plus side, this tranny was made for speed shifting. If I'm not in a hurry, I can almost drive all day w/out using the clutch, as smooth as butter (stop signs excepted). 1700 RPM seems to be the sweet spot.
  2. Mar 10, 2010 at 10:43 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    It's normal. You will get used to it with time, but I will agree its kind of annoying.
  3. Mar 10, 2010 at 10:46 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    I would not use the gears to slow down going fast anyway. Breaks are cheaper than fixing the transmission later on.
  4. Mar 11, 2010 at 12:59 AM
    eschonle
    eschonle Well-Known Member
    eric
    Seattle, WA
    2006 V6 SR5 4x4
    TRD Cat back Exhaust, Leer Shell, BHLM, Satoshi Grill
    won't clutchless shifting wear out and/or cause damage to your syncromesh?
  5. Mar 11, 2010 at 1:02 AM
    ryhar85
    ryhar85 Well-Known Member
    W. WA
    05 TRD 3" lift
    3" Trailmaster lift, 18" rockstars blacked out, 275/65/18 sxt mud terrains, more to come.
    X2. . . way cheaper!
  6. Mar 11, 2010 at 1:06 AM
    ryhar85
    W. WA
    05 TRD 3" lift
    I don't think it will damage any thing as long as you don't have to put force into it. . . Just let it fall into gear. I used to do this in my old jeep, it never caused any problems, but I don't in the taco - just because. . .
  7. Mar 11, 2010 at 7:00 AM
    Neotoma
    Neotoma [OP] Member
    Alaska
    TRD Offroad 4x4
    Gently, gently. That's where the "smooth as butter" thing comes in, and "the sweet spot" RPM. It's a low RPM, so you don't load up on the torque. If you like to hammer the accelerator, DON'T DO THIS.
    It teaches you a lot about your power train, gearing, and synchro, but never at higher RPM's or under load. I've done this with my old Ford trucks, and my 98 4Runner for years without harm, but never when I'm in a hurry.
