-   -   performance for 07 taco (http://www.tacomaworld.com/forum/performance-tuning/813-performance-07-taco.html)
texastaco 02-15-2007 06:48 PM
I am looking for a little more "umph" out of my truck. I am having an air-intake installed tomorrow. Any other ideas other than the loud exhaust?
ForeRunner 02-15-2007 10:40 PM
It's all a matter of how much do you want to spend!!!
Is it a V6 or the 4 banger? With a good intake, exhaust and a proper tune you can get some more oomph out of it.
For some good oomph you need to change the air pressure inside the intake manifold from a neagative number to a positive number.
texastaco 02-16-2007 05:03 AM
It is a 6 cyl. I am having an "Air Raid" intake installed today. Was thinking about a Magnaflow exhaust, but do not want the loud noise (it's really nice having a peaceful ride after getting rid of the Powerstroke). 4 Wheel Parts is looking into the possibility of using one of Magnaflows quiter mufflers and seeing how much that would affect performance. How do you go about changing the air presssure inside the manifold?
ForeRunner 02-16-2007 07:45 AM
Let us know how much it improves after the intake and exhaust.
You will have to get yourself either a Turbo or Supercharger to increase intake pressure other wise known as boost.
Like I said it's all about how much you want to spend.
twoarezee 02-16-2007 11:31 AM
you should get a 18" -24" magnaflow, it will be quiet but still have a deep aggressive tone. check out www.urdusa.com if you want to make good power.
TRDeity 02-16-2007 11:45 AM
I always recommend headers for an exhaust system. Those manifold systems just don't flow well.
Ldytaco05 02-17-2007 07:38 AM
superchargers can run from $3000 and up so what's your spending limit. ther's also NOS :)
AZtacoma07 02-22-2007 11:47 AM
I'm getting an 18" magnaflow on my 07 dbl cab long bed 4x4 next week. I'll report what kind of performance and noise I get.
pb2themax 02-22-2007 11:49 AM
Check out the URD MAF calibrator. It will add at least 15hp.
http://www.urdusa.com/
AZtacoma07 02-26-2007 03:35 PM
Well, I had an 18" magnaflow (part number 11256) installed a few days ago. I definately got some more pick up off the line, but lost a little top end power. The sound is about what I expected. It's loud when you get on it and then it dies to a low growl when cruising at freeway speeds. I purchased the muffler for $66 on ebay (that was including shipping) and had it installed for $40. I think that is a pretty good deal.
texastaco 02-26-2007 03:52 PM
The MagnaFlow rep told me he could supply me with there complete system and substitute an optional muffler that isn't much louder than the stock and only slightly reduces the gains. I'll let you know what happens after it is installed.
007Tacoma 02-26-2007 04:36 PM
Sounds great! Let us know what you think about it. Between the Air Raid, the exhaust, and a MAF Calibrator you should get a noticible difference. That is if you go with the MAF Cal.
TRDeity 02-26-2007 07:29 PM
Whats a complete system, cat back or all the way from headers to tail pipe? How much are they asking? :confused:
MAXTacoma 02-26-2007 08:08 PM
I have the TRD exhaust for my 06 V6 Double Cab and to tell you the truth I really havn't noticed a bit of difference with that vs. the stock exhaust when it comes in terms of performance.. It isn't loud tho except when you step on it you get a great rumble but when your cruising you can't even tell....
NomolosTRD 04-16-2007 05:13 PM
I installed the TRD intake and i noticed an increse in power right away, but there was still some resistance in the pedal. I put on a Magnaflow custom exhaust and it really boosted the power. I bet it is pushing 270+ HP now and it sounds great.
http://i82.photobucket.com/albums/j2...235_8_full.jpg
http://i82.photobucket.com/albums/j2...s/DSC02506.jpg
http://i82.photobucket.com/albums/j2...C02504copy.jpg
http://i82.photobucket.com/albums/j2...s/DSC02503.jpg
TacoChef 04-16-2007 05:56 PM
Tacochef
Can you imagine I work for Toyota but didn't know about TRD cold air.
Anyway I have K&N cold air intake and magnaflow exhaust. Just added the finishing touch JBA headers! Pulls real strong.
Steve762us 04-16-2007 10:22 PM
Are the V6's considered rich-running? I'm only three weeks into an 07, but exhaust looks pretty clean.
midV6size 04-24-2007 06:07 AM
Is that all you added, an intake and exhaust, to add that much extra hp? Just curious.
pb2themax 04-24-2007 08:00 AM
A stock Tacoma 4.0 puts about 195 hp to the wheels. Adding an intake may add about 5 to 10 hp. Exhaust may add 5 to 10. Removing cats might add a few more.
Without a MAF calibrator I doubt you can get over 25 hp total from an intake & exhaust upgrade.
midV6size 04-26-2007 04:39 AM
That's what I intend to do as well.
