sound in motor
Discussion in 'Performance and Tuning' started by easttexasboy, Mar 16, 2010.
  1. Mar 16, 2010 at 10:01 AM
    easttexasboy
    easttexasboy [OP] Active Member
    texas
    02 sr5
    it sounds like a bearing going out but i got to listening to it and it is coming from the right side of the engine. it gets louder when you accelerate. any clue?
  2. Mar 16, 2010 at 10:02 AM
    98tacoma27
    Ben
    Not Beech Creek
    Which Motor?
  3. Mar 16, 2010 at 10:15 AM
    easttexasboy
    texas
    02 sr5
  4. Mar 16, 2010 at 10:16 AM
    easttexasboy
    texas
    02 sr5
    its on the right side if your sitting in the truck.
  5. Mar 16, 2010 at 10:52 AM
    98tacoma27
    Ben
    Not Beech Creek
    And you sure it's coming form the motor? It's extrememly hard to diagnose a sound with out actually hearing it but maybe we can point you in the right direction. If you have a stethoscope (cheap at a parts store), you can determine what part of the motor it is from. Even a long screwdriver will work. Just put your ear on the end of the handle with the tip touching the motor.
    When was the last time the oil was changed?
  6. Mar 16, 2010 at 1:57 PM
    easttexasboy
    texas
    02 sr5
    ok. just got off work and did the screwdriver trick. it is a ticking noise and i hear it good right in the center of the motor.
  7. Mar 16, 2010 at 1:58 PM
    easttexasboy
    texas
    02 sr5
    oil chaged bout 1000 miles ago.
  8. Mar 16, 2010 at 2:10 PM
    newengland
    newengland small /= slow
    NH
    07 Reg. Cab. 2.7L s/c
    Alpine Supercharger, DT header, Gibson exhaust, URD short-shifter, Hellwig anti-sway bar, backwards helper-leaf traction mod
    My 2tr makes a lot of clicking noises, but I assume it is just the valves?:notsure:
  9. Mar 16, 2010 at 2:34 PM
    easttexasboy
    texas
    02 sr5
    thats what im thinking.
  10. Mar 16, 2010 at 3:37 PM
    easttexasboy
    texas
    02 sr5
    any other suggestions?
