How do I clean my DSLR?
Discussion in 'Photography' started by Tonzino, Aug 29, 2011.
  1. Aug 29, 2011 at 4:11 PM
    Tonzino
    Tonzino [OP] Active Member
    Tony
    Hayward, CA
    2011 Double Cab Off-Road
    I have had my camera for about 2 years now and in that time its gotten pretty dirty (fingerprints from my fat greasy fingers mainly). What are some techniques you guys use to clean your equipment?
  2. Aug 29, 2011 at 4:13 PM
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
  3. Aug 29, 2011 at 4:13 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    The sensor or the body its self? I just wipe with a cloth.
    Everytime I shoot my camera gets super dusty. :eek:
  4. Aug 30, 2011 at 7:12 AM
    Tonzino
    Tony
    Hayward, CA
    nice, I think I might have bought one of those at one point. I'll take a look.
  5. Aug 30, 2011 at 7:13 AM
    Tonzino
    Tony
    Hayward, CA
    Mainly the glass on the lens itself, but the camera could use a good wipe down.
  6. Aug 30, 2011 at 12:49 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    On the glass lens I use a microfiber towel.
  7. Aug 30, 2011 at 1:02 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    X2 i carry a microfiber towel in my bag for my glass but when it comes to my sensor i use the Delkin Devices Sensor Scope
  8. Sep 17, 2011 at 8:10 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I use a dual-sided lens pen. They're less than $10 and have a brush on one side and a small soft pad on the other.
    Other than that, I'm anal about keeping covers on the body-end of my lenses. It works well for me but I don't shoot much in desert or dusty conditions.
  9. Jan 22, 2013 at 9:56 AM
    asphaltpilot
    asphaltpilot CAPS CAPS CAPS!
    Jason
    South Florida
    PreRunner SR5
    I’m surprised how little information came with my Nikon regarding cleaning and maintenance. I’d like to get some tips and pointers regarding this.
    Can the camera sensor (body) be cleaned with the same wipes/cloth as the lenses? Are there any lens cleaners or wipes that you recommend not using?
    What is the maximum and minimum temperature you will expose your camera to? (I’d like to keep my camera in my truck for those spare-of-the-moment opportunities)
    Are there any environmental conditions that you will not subject your camera to (ex: windy beach, snowy conditions, etc…)
    How often, if ever, should the lenses and camera body be professionally cleaned and/or calibrated?
    Do manufactures ever contact owners regarding firmware patches or upgrades, or do you have to actively seek them?
    Any other tips and advice that you more experienced photographers can give would be appreciated. Thanks.
  10. Jan 24, 2013 at 2:43 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    cleaning sensors should not be undertaken unless you are willing to accept that sometimes you may leave it dirtier than before you cleaned it. to test if you need a sensor clean, on a bright day, shoot at the sky with your smallest aperture(f16-f32) to get an image of the sky, and hopefully some spots on the sensor. if you do have these spots(dust, oils, lint, etc), then proceed to cleaning.
    the way I do it, is this:
    1. mirror lockup, face camera sensor down and blow up with an air rocket in hopes of dislodging the dust and letting gravity hopefully take its place.
    2. I then set the camera on its back, and use a sensor swap with a drop of sensor cleaning solution to swab the sensor. two passes should be good with one swab.
    3. once the swabbing has been complete, this next step requires two lights, a table task light(with a bendable neck so you can position the light to the sensor), and a headlamp so you can see the large pieces of lint, dust, etc. use a lenspen to "dab" any particles off of your sensor. you don't want to do any brushing strokes with your lenspen as you may damage the sensor. once you think you've gotten everything clean, go outside, or inside, and perform that same shot you did to determine if you needed a sensor clean. f16-32 shot.
    use the non brush side of the lenspen to dab the sensor
    3a. if you find that you haven't gotten all of the dust out of your sensor immediately after cleaning your sensor, you can skip the swabbing, and go directly to the lenspen.
    edit: perform at your own risk. the solution cleans your optics really well, with a fine microfiber towel/swab.
