Go Back   Tacoma World Forums > Tacoma Garage > Product Reviews
Tracrac TracOne (Universal) Review/Build for 05+ Tacoma Bed Rack
Old 09-17-2013, 06:48 PM   #21
near the Tannhauser Gate
OZ-T's Avatar
OZ-T's Tacoma Gallery
Originally Posted by XXXX View Post
11/16"W x 1/4"H ID with a 3/8" wide slot
Thanks Boyd
Nice avy BTW
Old 11-18-2013, 12:47 PM   #22
sfcyclist is on a distinguished road
sfcyclist's Avatar
sfcyclist's Tacoma Gallery
Nice write up and customizing. I just go the Tracrac G2 with cantilever.
I had a few minor issues;
Need to chase almost every 3/8-16 tapped hole.
Bed pockets block the clamp from sliding into place so I had to remove them.
Old 11-18-2013, 12:51 PM   #23
XXXX [OP] XXXX is offline
Banned
XXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shed
XXXX's Tacoma Gallery
I didn't chase anything. Waxed up the bolts up and drove them home with a ratchet Your idea is much safer than mine and I know others have had the same issue with the powder-coating clogging the threads up.
No need to remove them. Just push the bed pockets in and slide the clamps past them. It is a tight fit, but you can do it.
Old 11-18-2013, 01:52 PM   #24
sfcyclist's Avatar
Well perhaps your thread were not as bad as mine.. as long as it doesn't gall up!
My guess is the bed flexes enough to push it past... stupid me.. I already cracked one taking it off.. ugh.. will try to slide it past later..
Quality is real nice though. Love the channel as I can use it to fit Thule accessories.
Old 09-21-2014, 06:18 PM   #25
hygieneboy will become famous soon enough
hygieneboy's Avatar
Navy: Sub Pilot
hygieneboy's Tacoma Gallery
What type of saw did you use to cut down the rack?
Old 09-23-2014, 09:07 AM   #26
Banned
I used a 12" compound miter saw with a 120 tooth industrial blade meant for cutting aluminum. Waxed it up like I always do and it cut like butter. The less teeth you have the slower and more cautiouse you need to be. Aluminum tends to melt into the teeth so after each cut inspect the blade for this. If it occurs remove the build up and wax the blade before the next cut....and cut SLOWER so it doesn't happen again.
For the other guy who PM'd me while on vacation concerning the lengths I cut mine down to - they are listed in the OP.
Old 09-23-2014, 10:00 AM   #27
hygieneboy's Avatar
Navy: Sub Pilot
Thanks, I guess a hack saw might take a while ��
Old 09-23-2014, 11:23 AM   #28
Banned
Nah... 5-10 min tops with the right blade on it and a miter box. The extrusions are pretty thin.
I would do it if I didn't have a saw.
Old 12-03-2014, 05:09 AM   #29
Taco-N-Madre
jruba is on a distinguished road
jruba's Tacoma Gallery
I like what you did here man , ive been looking for some ideas to customize my thule rack and I think I found them , let me ask you what is the primary use for the outside L tracks ? , awning ? tarp ? because that's something im interested in ..
heres mine :
Tracrac TracOne (Universal) Review/Build for 05+ Tacoma Bed Rack-wp_ss_20140919_0001-1-.jpg
Old 12-04-2014, 09:33 AM   #30
sfcyclist's Avatar
latest update
The Trac Rac is holding up fine but overloaded it and tore the composite bed at the front corner.
I noticed that other racks have a plate that is the length of the bed. I am sure that distributes the load better. Or they have a strut that transfers load to the base on the bed.
Tracrac TracOne (Universal) Review/Build for 05+ Tacoma Bed Rack-rack-support-front-mount-640.jpg
Old 12-04-2014, 09:36 AM   #31
OZ-T's Avatar
The legs were forced outward most likely
Had a lumber rack on my old truck break the metal bed the same way
Old 12-05-2014, 07:55 AM   #32
sfcyclist's Avatar
That makes sense but the struts shown only provide vertical support. I am sure this will help but then it's the next weakest point which is probably what your noting.
Inno Truck Bed Rack Review KnurledNut Product Reviews 14 03-03-2015 03:42 PM
TracRac TracOne score! Deuxdiesel 2nd Gen. Tacomas 1 07-18-2013 01:19 PM
The New APEX Series Pack Rack for 05+ Tacoma Long Bed CJB4LFE All-Pro Off Road 12 08-03-2012 10:09 PM
How to instal Westin universal bed rails tacoma 2012 ? Myafed2900 Performance and Tuning 4 05-08-2012 08:04 AM
Tracrac Rails System on Composite Bed CCRT 2nd Gen. Tacomas 0 10-02-2008 04:34 AM
