-   Product Reviews (http://www.tacomaworld.com/forum/product-reviews/)
-   -   Build Your Own Camper or Trailer! Glen-L RV Plans (http://www.tacomaworld.com/forum/product-reviews/192268-build-your-own-camper-trailer-glen-l-rv-plans.html)
Goober 12-10-2011 06:52 PM
After searching endlessly for home built camper plans I stumbled on a link to this site. Home built plans from shells to 5th wheels.
http://www.glen-l.com/campers/glenlrv.html
http://www.glen-l.com/campers/rv-pic...rphotos.html#i
http://www.tacomaworld.com/gallery/d.../IMG_1931a.jpg
http://glen-l.com/campers/images/fairhaven-constr9.jpg
http://glen-l.com/campers/iphoto1.jpg
kogary 12-10-2011 08:19 PM
dude, I just went through every link on that site!! Building your own camper looks awesome! Definitely a project I could see doing. My only reservation for doing something like that is that I park in the garage and I would't be able to do so (very easily) anymore.
Are you thinking of doing this in your tacoma? I was trying to understand how the blueprints work for our specific wheelbase and bed dimensions. Any insight on that?
4x4jeep 12-10-2011 08:25 PM
:popcorn:
Goober 12-10-2011 09:09 PM
Camper Jacks! But you'd need a place to drop it when it's not on the truck
The Importer version would probably fit, I'd have go measure the bed rail height and cab height to be sure. I was thinking of doing a modified version of the cab over. Haven't decided yet. Apparently the plans are full size to layout the walls right on top of, so I would have to modify that.
Determine whether our campers will fit your truck without modification
Importer-Standard Plans & Patterns package: $48.00
Importer-Long Bed Plans & Patterns package: $54.00
http://www.tacomaworld.com/gallery/d...0/Importer.jpg
Goober 07-10-2012 07:05 AM
$15 dollar for the plans for this camper
I ordered the plans to build this camper on ebay. Seller estimates his camper weighs about 700lbs.
http://www.ebay.com/itm/261044439382...S:3160&vxp=mtr
http://www.tacomaworld.com/gallery/d...edium/1559.jpg
http://www.tacomaworld.com/gallery/d...edium/2308.jpg
http://www.tacomaworld.com/gallery/d...edium/3203.jpg
Goober 11-05-2012 08:38 PM
Update on the plans listed here.
The plans I bought on ebay for $15 are lacking in a lot of detail. There is some good info in them but the basic construction details are just not there. Some buyers stated so in their feedback on ebay and the seller defends himself by stating you must have skill and imagination to build his design.
I have since purchased the "Importer" plans from Glen-L and am very satisfied with this product. The plans and "build manual" make this look easy. Very detailed construction and simple steps. Included is a full size blue print of the upper side layout, around 11' long, layout diagrams for cutting plywood panels from 4' x 8' sheets to limit waste, and bill of material includes lumber sizes and fasteners used. Information on installing electrical, lp, and water systems.
Glen-L has a builders forum, mostly about building boats but there's a section for RV's. http://www.glen-l.com/phpBB2/viewforum.php?f=16
My plan is to build a modified version of the importer. Shorter height wise, 5' tall instead of the 6' the plans call for. This would be tall enough to sit in.
A small cabover section for extra storage space and 83" long cabin so I don't have to sleep corner to corner (which I do now with just the shell arrangement). A fully finished Importer dry weight is 700lbs. So by cutting down the size and not putting in all the interior cabinetry and equipment, I'm hoping to keep it under 500lbs.
I'm going for something that looks like this shell only a foot longer from the inside dimension of the bed.
http://belairshells.com/yahoo_site_a...220049_std.jpg
http://belairshells.com/camping_shells
Goober 01-08-2013 11:20 AM
Building the Glen-L Importer Camper-modified
I've started building a scaled down version of the Glen-L Importer. I've adjusted the dimensions to fit the Tacoma.
http://www.tacomaworld.com/gallery/d.../IMG_0787a.jpg
http://www.tacomaworld.com/gallery/d.../IMG_0788b.jpg
http://www.tacomaworld.com/gallery/d...ion-detail.jpg
http://www.tacomaworld.com/gallery/d...amper-Side.jpg
http://www.tacomaworld.com/gallery/d.../IMG_0703a.jpg
NwiTACO 01-08-2013 11:27 AM
Cool deal. Glen-L has been around forever. I started building a Tubby the tugboat a few years ago and sadly never finished.
aficianado 01-08-2013 11:27 AM
badass!
Forster46 01-11-2013 01:21 PM
Interesting.
Goober 01-14-2013 05:41 PM
http://www.tacomaworld.com/gallery/d.../IMG_0824a.jpg
http://www.tacomaworld.com/gallery/d.../IMG_0828a.jpg
Chris24 01-18-2013 09:28 PM
awesome!
Goober 01-19-2013 04:21 PM
http://www.tacomaworld.com/gallery/d.../IMG_0848a.jpg
http://www.tacomaworld.com/gallery/d.../IMG_0837a.jpg
1bad10tacoma 01-19-2013 04:29 PM
Subbed for later
1bad10tacoma 01-19-2013 04:53 PM
What will you use to cover the outside of the camper? This is really cool.
Goober 01-19-2013 05:14 PM
I plan on using aluminum. I'll insulate it with either styrofoam or fiberglass.
http://www.hemetvalleyrv.net/rollforms.html
fourbyfour 01-19-2013 05:29 PM
Awesome build! How are you planning on securing it to the truck?
1bad10tacoma 01-19-2013 05:43 PM
Thanks for posting this.My father and I had a couple full sized slide-in campers over the years.We went on a lot of fishing trips with these. I may have to build one myself.
Goober 01-19-2013 06:10 PM
On the front I've installed these brackets, I added extra nuts on the bolts under the frame to keep these from twisting the bolts loose. I'll use turnbuckles with eye bolts on the camper. On the rear I'm going to use the bed bolts through the floor of the camper. I'll need to get some longer bolts to replace the stock bolts.
http://www.amazon.com/CargoBuckle-F1.../dp/B004HHU4TE
http://www.tacomaworld.com/gallery/d.../IMG_0674a.jpg
http://www.tacomaworld.com/gallery/d.../IMG_0672a.jpg
1bad10tacoma 01-22-2013 05:05 PM
any more progress on the camper build?
