IronMan 4x4 2" lift!
Discussion in 'Product Reviews' started by Haslefre, Aug 4, 2012.
  1. Aug 4, 2012 at 12:57 PM
    Haslefre
    Haslefre [OP] Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Well, I finally got around to installing my IronMan 4x4 2" lift by IronMan 4x4. I ordered it through Sierraexpeditions.com. The only problem with ordering was the shipping and wait time. It took way too long to ship from NJ (or Australia..) and it ended up being a 1 month wait from order to delivery. I finally got the time together to install it with a few people (thanks JMG, Buckswells and others).
    Here is the lift as it was delivered
    The springs are noticeably beefier than the stock sport springs, as well as the shocks.
    This is the old ones out, and I forgot to snap pictures of the new ones prior to install :(.
    [​IMG] installed with tires on in the front. Brought the front up the actual 2" that the lift claims to gain.
    The only problem with installing the front came from the people I had put them together. They did not install the tops fully, and when we drove it around the block a few times we noticed that there were still plenty of threads on the top. So we tightened them back down and torqued them.
    Here are the differences in the rears.
    and
    Now, the only problem with this whole kit is the fact that it did not come with instructions of any sort, except on mounting the springs in the front. Since none of us were very acquainted with the bushings in the back for the shackles, we did not know that the metal insert was part of the old bushings... :eek:. Well, we finally beat them out, and the new kit comes with full polyurethane bushings. Very thick, very well manufactured.
    EDIT: I forgot one thing about the new U-Bolts. They are very thick, and great manufacturing in them. BUT, the supplied lock washers were crap. When torquing down the U-bolts, the lock washers started to un-coil and split/broke in half before we were close to 80lbs. I would recommend to get new better ones from a store before putting them in.
    So here is how it stands after install and alignment done.
    I went from 21" in the front to 23" center of hub to fender. In the rear, it went from 22 1/2" to 24 1/2-25" depending on how I was parked. I have driven it about 100 miles since last night with it on, and I have not reinstalled the sway brace. This ride is amazing compared to stock. I can tell how much more handling and stability I have with it on. I would recommend this kit to anyone who is looking at saving 400 bucks over OME with Dakars. If you have any questions on it, let me know!
    ChadsPride likes this.
  2. Aug 4, 2012 at 1:02 PM
    Blueberry
    Blueberry Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    Very nice! Tire time.
  3. Aug 4, 2012 at 1:16 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Looks great :thumbsup:
  4. Aug 4, 2012 at 1:19 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    IMO, seeing all 3 shocks (OME, 5100's and IronMan), IM's seem to look the biggest/beefiest of the 3. And the leaf pack in the rear looks almost identical to the Dakar's but with 1" less of lift.
  5. Aug 4, 2012 at 1:29 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    looks tight.....love the rake. I ended up getting 5100s due to budget and my total lack of wheeling it seems:eek:.......so i'll be looking like that hopefully just an inch higher. I will def need new tires asap but yours looks perfect with the 2". Congrats
  6. Aug 4, 2012 at 1:50 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    I count 11 turns in the coil spring, while stock has only turns. Be wary of coil slap.
    Rear lift looks nice. :thumbsup:
  7. Aug 4, 2012 at 1:58 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    I've already done a bit of hard breaking/starting to see if there was going to be any issues. I am going to avoid putting on my sway bar for a while also... don't want it to rub on the coils or cause any damage if I don't quite have them in the right position. But it doesn't seem like I will need it anyway.
  8. Aug 4, 2012 at 2:11 PM
    KenLyns
    Belly of the Beast
    If you have any convenient areas to flex the truck, you can check the bumpstops hit before the coils stack solid.
    And if the coils do hit, you can always cushion it with more progressive bumpstops, like the Wheeler's Superbumps.
    (OZ-T's photo):
  9. Aug 4, 2012 at 2:14 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    I might do this later. I have no plans in the next month or two to wheel it hard. Also, added above something about the rears. The supplied lock washers were crap. They started splitting/spreading/breaking before we were close to 80lbs on them. Otherwise, it is a great kit.
  10. Aug 4, 2012 at 2:14 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Nice write up Brady. Well Done!!!
  11. Aug 4, 2012 at 2:49 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
  12. Aug 4, 2012 at 3:20 PM
    Blueberry
    Nick
    Newton, KS
    On another note sorry I wasn't able to make it by today. Ended up working until two and was dog tired when I got home.
  13. Aug 4, 2012 at 3:28 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    It's alright man. We ended up getting it done yesterday.
  14. Aug 4, 2012 at 3:33 PM
    Blueberry
    Nick
    Newton, KS
    Oh well hell. Good deal.
  15. Aug 6, 2012 at 5:33 PM
    powerpack66
    powerpack66 Member
    Chad
    kentucky
    2011 trd sport
    Still stock. Just getting started.
    I really like how your lift turned out. It made me want to consider picking one up for my truck. I have a question though. Did your kit come with the 1/2 inch shock spacers that Coryip was talking about in his thread? The reason I was asking, is I have a Dc Longbed and I was thinking that I would need them because of the extra cab weight on my truck.
  16. Aug 6, 2012 at 5:34 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    Yes, they did. You can also order the same lift with stronger coils. Mine are B rated up to 650kg, and they have coils and leaf springs for higher rating. I think you just need to call them when you order to ensure you get the correct thing.
  17. Aug 6, 2012 at 6:57 PM
    powerpack66
    powerpack66 Member
    Chad
    kentucky
    2011 trd sport
    Thanks for the reply. I'll give them a call and ask about the heavier spring option.
  18. Aug 6, 2012 at 6:59 PM
    Haslefre
    Brady
    TN
    2019 Tundra
  19. Sep 21, 2012 at 8:39 PM
    Alexfiggy
    Alexfiggy Well-Known Member
    Alex
    Miami
    Trd off road
    Hows the lift so far?
  20. Sep 29, 2012 at 4:52 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
