Tracrac TracOne (Universal) Review/Build for 05+ Tacoma Bed Rack
Discussion in 'Product Reviews' started by XXXX, Sep 8, 2013.
  1. Sep 8, 2013 at 5:03 PM
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    Got if from Lowes for $299.00. They offer models for our trucks, but I did not like their prices or the added hardware they give you so I decided to do it A la carte and end up with what I think is a better rack for my uses while being a little less money.
    Grabbed some Tacoma bed rail clamps $79.99 online (they are cheaper now)
    Beef!!!
    The Tracone is a universal rack and works for a fullsize truck so it's tall and wide on a Tacoma......VVV
    I didn't want to hit every tree in the woods or have a need for a rack 5" taller than my cab so I cut it down in length and width.
    test fit width
    Cut 9" off the width
    After I cut down the horizontals I added notches to each so I never had to remove the end caps to put new hardware on it. Tracrack was smart and everything for it is the same 3/8" thread. Because of this the options for fabbing home made holders or adding other aftermarket rack hardware to it is limitless if you use a little imagination.
    Had to drill one hole in each horizontal's cut side for the end caps.
    I cut 4" off both the front and the back, but I would recommend 3" in the front and 4" in the back if you turn your kayak upside down like I do. My front kayak handle hits the cab offroad so I have since added 3/4" of height back to the front rack (luckily I saved all my cut offs).
    handles hitting with yaks flipped at 4" of cut off before I raised it
    The holes are the perfect diameter after cutting so no need for drilling. Just tap it with 3/8" and your good to go with the stock bolts.
    If you mount it the way you are supposed to you loose a good 5" of bed space
    So I turned my front rack around removed the front bed rail for max clearance and bed space
    Tool box mounts right into the 3/8" standard threaded holes on top of the brackets. Each bracket has one. They also give you two additional brackets should your tool box be more than 12" deep. I didn't need them.
    still plenty of room for the hi lift
    13' & 9' yaks
    I recommend swapping out the bed clamp bolts. They suck and are to long due to being universal. Use stainless 3/8" - 16 x 1-1/2" Hex heads
    Recent mods.....
    Sanded/primed/painted black
    added 1' of airline/"L" track to each outside vertical
    I put some great 3m tape on them so there wasn't metal to metal contact and to help hold them.
    used 1/4-20 tap
    1/4-20 x 1" stainless screws
    you can get all kinds of fittings but I chose these for my uses
    Added single pc of L track to each lower inside corner for strapping stuff into the bed or in the middle of the rack.
    Be sure to Loctite everything and you should be good to go.
    dwill913 and Capt. Obvious like this.
  2. Sep 8, 2013 at 5:17 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    That looks really nice man. Good job :thumbsup: I might try this
  3. Sep 8, 2013 at 5:25 PM
    XXXX
    sKiP
    05 Prius
  4. Sep 8, 2013 at 5:28 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    This doesn't look like a motor swap :confused:
    Nice work man, looks good! Love me some L track
  5. Sep 8, 2013 at 5:33 PM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    I really like the addition of the L track! Paint looks good as well. I wonder how it will hold up with sliding yaks on and off? My 12 ft 75 lb sit on top has rubbed the original clear coat off after just a year.
  6. Sep 8, 2013 at 5:34 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Is the original finish anodized aluminum? I have the thule height adjustable racks and want to paint them black. Your racks look awesome :thumbsup:
  7. Sep 8, 2013 at 5:39 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Nice thread Boyd
    Just one point I'll make , my aluminum headache rack did not get along with stainless bolts
  8. Sep 8, 2013 at 5:44 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Can you still haul full size sheets of plywood or would they hit the cab (assuming they'd flex down) or is that not a concern for the rack?
  9. Sep 8, 2013 at 5:46 PM
    XXXX
    sKiP
    05 Prius
    Motor is coming soon. Recouping funds after wheel bearings on the dam Ford. Now I'm just working on the crap I accrued for it over the past year :D
    Thanks. No the paint will not hold up. The original powder coat didn't either. The yaks wore down to raw aluminum. I didn't post it yet because I didn't take pics, but on the front in the middle I didn't paint it and put down rubber roof flashing. I just painted the rear today so in a day or two when it's cured Ill do that one and take pics. I looked all over for a good rubber and even got some 1" x 4' strips I was going to glue down. One day I was walking by my tape shelf and saw the flashing and a light went off so I said screw glue and rubber just use the easy stuff.
    Powdercoat & crappy at that. I got pics of it bubbling up on my camera Ill post when I'm done with the rear rack. I sanded the bubbles down and primer/filled them before paint.
    I know it won't hold up with tree's scraping it up, but a touch up every year or so is easy now.
  10. Sep 8, 2013 at 5:56 PM
    udy2554
    udy2554 NORTHERN RED-NECK
    John
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    Would an anti-seize compound help with the steel/aluminum reaction? Or maybe the Loctite?
    Loving the black!
    Great ideas Boyd!:thumbsup:
  11. Sep 8, 2013 at 5:58 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    x2
  12. Sep 8, 2013 at 6:03 PM
    XXXX
    sKiP
    05 Prius
    Wonder if bathing them in loctite will help me :D
    Never tried a sheet of plywood. I did have (2) 5' x 15' skids up there last winter and wheeled with them for about a mile with no straps on them and never heard anything hit. My roofs already dented from hitting trees anyway so if it did hit it's no biggie :D
  13. Sep 8, 2013 at 6:08 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Steve
    Buffalo NY
    2010 RC 2.7 4x4
    BUCKLE UP! It makes it harder for Aliens to pull you out of your Truck.
  14. Sep 10, 2013 at 6:54 AM
    Eddie Van
    Eddie Van Huge Member
    Maryland
    '13 DC 4x4 Off-road Manual
    Great review. Thank you!
  15. Sep 17, 2013 at 5:55 PM
    XXXX
    sKiP
    05 Prius
    No more slippery silver
  16. Sep 17, 2013 at 6:11 PM
    OZ-T
    Peter North
    British Columbia
    What's the width of the track on the top of the bars , looks like it's the same as my DeWalt ProRac on my cap
  17. Sep 17, 2013 at 6:28 PM
    XXXX
    sKiP
    05 Prius
    exactly 4" at it's widest
    very possible to have a similar extrusion die used for both products.
  18. Sep 17, 2013 at 6:31 PM
    XXXX
    sKiP
    05 Prius
    better view of cut off I saved
  19. Sep 17, 2013 at 6:33 PM
    OZ-T
    Peter North
    British Columbia
    Sorry , I meant the actual T slot track
  20. Sep 17, 2013 at 6:39 PM
    XXXX
    sKiP
    05 Prius
    11/16"W x 1/4"H ID with a 3/8" wide slot
