-   Product Reviews (http://www.tacomaworld.com/forum/product-reviews/)
-   -   My review on the Python 991 Alarm/Remote Start. (http://www.tacomaworld.com/forum/product-reviews/54354-my-review-python-991-alarm-remote-start.html)
stang88 09-29-2009 05:54 PM
i posted this in the alarm/video section too...
http://www.pythoncarsecurity.com/pro...?ProductID=619
i just installed one of these in my 2009 dc taco. Since i am an authorized installer, dei sent me one for free to try out and demo for customers.
I had an autopage rs 727 in before.. both are excellent products.. but here is where the python 991 soars above the autopage:
Mile long range.. yes its true.. actually 1.2 miles.. i about fell over that it actually goes that far.
color background.. you can change the illumination which is a nice little added feature.
remote looks more professional.
remote charges by mini usb and only needs to be charged once a year.. just dont lose the charger..lol
shows the interior temp as the vehicle is warming up.. nice feature so you can tell if 11 min is long enough or if it needs to run longer.
you can adjust the shock sensor from the remote.
now to the installation.. DO NOT ATTEMPT THIS UNLESS YOU KNOW HOW. its a very complex system and not for a beginner..
no more drilling a hole for a led or hiding the valet button.. both of those are on the antenna now.
Any questions feel free to ask..
oh.. you can find this alarm and its viper brother.. on ebay for around $250. but then you dont get the lifetime warranty.
AZFizik 09-30-2009 09:06 AM
How was the install? I put alot of Code kits in where the wiring came out at weird angles and generally didn't fit very nicely. And which unit did you use for the key bypass?
stang88 09-30-2009 07:17 PM
install went perfect... i installed one of these last week and loved it.. so i called dei and they sent me one.. i had an autopage in there before so i just kep my old bypass module " pkall". the range is so kick ass... just as you would expect from a dei product.. perfect....
leo858 10-10-2009 08:45 PM
Will this work on a manual transmission?
Rascal737 01-16-2012 01:42 AM
I have a python 574 alarm/remote start (same as the 991, but the newer version)....I've pretty much got most of the wiring done except for a few on the 10 pin remote start connector that I'm not 100% sure on.....I hope someone can help.
The 10 Pin connector has:
violet - Starter output -------- connect to starter 1 (green/black) on the truck?????
green - Starter input -------- connect to starter 2 (black/white) ????????
pink/white - (30)flex relay output(car side of ign, acc or starter wire) -------- connect to Ign 2 (blue/yellow)???????
pink/black - (87a)flex relay input(car side of ign, acc or starter wire) ------- ???????
OR
do I cut the starter 1 (green/black) wire and connect the modules violet wire to the truck side and the green wire to the ignition side?????
and cut the Ign 2 (blue/yellow) and connect the pink/white wire to the truck side and the pink/black wire to the ignition side??????
Rascal737 01-16-2012 01:47 AM
Also the door trigger input....if i connect this to the left front trigger (green/yellow) wire, I'm only monitoring the one door, correct.
Is there a common wire that all doors will trigger??
2K6 Taco 01-19-2012 02:22 PM
Ijust got this system installed. I was wondering if the shock sensor is built in the antenna or the brain? I have the remote sensitivity to the highest (15) and kick the shit out of my front driver wheel and nothing. If i bang on the windshield lightly it will 'warn away'
Rascal737 01-20-2012 03:37 PM
Both Python 991 and 574 have external shock sensors that can be adjusted for sensitivity.....you'll just have to locate the sensor and there is an orange adjustment screw on the side
2K6 Taco 01-21-2012 09:18 AM
They are built in. I just dont kno if its in the brain or the control center
Rascal737 01-22-2012 03:33 PM
ok.....i just installed myself the python 574 (which is the newer version of the 991) and I have an external shock sensor.....i know exactly where the shock sensor is located.....i don't know if the 991 is exactly the same, if the 574 was changed, then i don't know....i do have the install manual for the 991 at home, don't have access to it for a few hours.....i can let you know what it says later
Rascal737 01-23-2012 02:19 PM
You are right 2K6 Taco, the Python 991 has the shock sensor built into the main unit (the brain)....they also have an install note on it : "In many vehicles, fastening the main unit (the brain) to a steering column or screwing it to metal will result in poor sensitivity, especially at the rear of the vehicle."
hope that helps, I would take it back to where you got it installed and ask them where they mounted the brain
2K6 Taco 01-24-2012 05:58 PM
My brain is behind the driver side fuse box. Not strap/screwed to anything.
TacomaPrime 01-24-2012 06:00 PM
I have this as well. Love it. especially the remote start option.
Rascal737 01-25-2012 01:45 PM
could be the reason why there isn't much sensitivity......it's not feeling the vibrations or shake from the truck
Rascal737 01-27-2012 12:11 PM
yeah, remote start optionis the bomb!!!! I find myself remote starting the truck way too often now
TacomaPrime 01-27-2012 01:17 PM
Is there a hood pin option for this unit? my previous dei systems always had a hood pin that would shut the vehicle off if you remote started it and opened the hood. Or it would make the alarm go off if you opened the hood.
Rascal737 01-28-2012 04:48 AM
I don't know if the 991 model came with a hood pin, but it does have a hood pin input....install manual shows it as a gray wire. The 574 model does have a hood pin included and it does both, shut off the vehicle if its running and sets off the alarm (if the vehicle is armed) when the hood is opened.
Cruzs2013SR5 03-24-2013 09:16 PM
Anyone know if the wiring is the same for a 2013 Tacoma DCSB. I will be buying the Python 574 and installing myself.
