Go Back   Tacoma World Forums > Vendors > Relentless Fabrication
DCSB Relentless Bolt On Hybrid Sliders with Kickout
Old 09-15-2012, 08:26 PM   #1
camiliosalomanda is just really nicecamiliosalomanda is just really nicecamiliosalomanda is just really nicecamiliosalomanda is just really nicecamiliosalomanda is just really nice
camiliosalomanda's Avatar
Air Force: 3C0X1 Seperated/ Infromation Technology Specialist DAF
camiliosalomanda's Tacoma Gallery
I am going to use this space for a write up on installing Relentless Bolt On Hybrid Sliders with Kickout.
Eric and his team make a high quality product.
I have painted all the parts that were bare metal.
Square Washers
U Brackets for Cross Member
Extension Arms for Frame
Driver Side Slider
Passenger Side Slider
All Parts
Primer
BedLiner
Old 09-15-2012, 08:29 PM   #2
Tomorrow I will be installing all the parts and I will take pictures of the progress as I do it. I have to go grab some flat dollies to build a small frame to hold them in place.
Eric feel free to chime in if there is something I have missed here.
I could possibly install all this backwards, hahaha.
Any and all advice is welcome.
Old 09-15-2012, 11:11 PM   #3
RelentlessTaco's Avatar
Looking good! Thanks for doing an install write up.
Old 09-16-2012, 12:08 PM   #4
So I have been waiting for the rain to let up so I get under the truck and look around to make sure I know where everything goes.
I am still a little unsure about where the extensions go on the sliders. So we will see what happens there.
SIDE NOTE: Meanwhile I have put a brisket on the smoker.
Brisket
Half Brisket Marinate for 2 hours or longer
Rub
Paprika
Ground Mustard
Salt
Pepper
Oregano
Onion Powder
Garlic
Mop
Rogue Pink Voodoo Beer with Bacon and Maple
Liquid Smoke
Cook
Smoker at 225 for 30 minutes
Place Brisket Fat side up
Smoke 3 hours then mop
Old 09-16-2012, 04:26 PM   #6
Originally Posted by Wildlandtaco View Post
The brisket has been on for almost 6 hours now.
I just finished installing the sliders and will be posting pictures as soon as I upload them.
Old 09-16-2012, 05:18 PM   #7
The Install
So I have installed the sliders and performed a preliminary test.
I started by making a rolling cart stand that held the slider in place as close as I could get them to the holes in the frame.
Once in place I positioned them as best as I could
Then I installed the U Cross Member Bracket
As always leave everything loose until all bolts and nuts are in place for fitment reasons.
Removed the Drive Shaft Cross Member Bolt
Removed the Hose Bracket as it was in the way.
Lining up the holes
Then I clamped the back so that I could keep the holes inline to start installing the bolts.
I installed the U Cross Member Bracket Bolt to the sliders because it is hard to line up.
Then I figured out what the extension arms were for
Position them inside the boxed in part of the frame and install the bolt for the one closest to the back of the truck first as it is easier to get the front one in because the extension arms from the front will be close to the hole for the back one.
Re-install the Drive Shaft Cross Member Bolt so the the rest of the slider is in place.
Install the rest of the bolts from the outside
Use the square washers on the inside.
Also the last hole in the frame toward the rear I believed was a mounting hole, but the bolts were not long enough to fit through it and get the nut on. So I do not think that is a mounting point.
There is one bolt and washer that goes inside the boxed in part of the Drive Shaft Cross Member. One of those tough spots to get to.
Passenger Side Done
Driver Side repeat all steps
Driver Side Bolted on
Driver Side Installed
Hi Lift Time with Relentless Hi Float Base
I know everyone had been asking around if the bolt on sliders were strong enough for a Hi Lift.
They flexed a little bit since I did not install the bottom two bolts that require drilling.
It came close to the pinch weld but never touched.
Done
Old 09-16-2012, 05:39 PM   #11
OZ-T's Avatar
OZ-T's Tacoma Gallery
Are these the no drill bolt ons OP ?
Old 09-16-2012, 06:05 PM   #12
Great write up and the brisket looks delicious! Must be nice having that waiting when done with the install as a job well done.
Old 09-16-2012, 06:05 PM   #13
yep :-)
Old 09-16-2012, 06:16 PM   #14
WheelinJ91 will become famous soon enough
WheelinJ91's Tacoma Gallery
If you had added the bolts to the bottom (where drilling is required) do you think it would have not flexed? They look like even without the bottom bolts that they would hold if you lost clearance and save your rockers.
Old 09-16-2012, 06:27 PM   #15
OZ-T's Avatar
Originally Posted by RelentlessTaco View Post
yep :-)
Sweet
Old 09-16-2012, 07:00 PM   #16
Originally Posted by Forster46 View Post
Very nice.
I like the brisket write up as well
Thank you.
Unfortunately the brisket was bland. Should have marinated it over night instead of only two hours. Crock Pot it goes with more mop.
Old 09-16-2012, 07:01 PM   #17
Thanks Eric. Again great product man. I think I am going to drill those holes in the bottom and add the final bolts just to complete the ordeal.
Old 09-16-2012, 07:03 PM   #18
Yeah these are super beefy. I dont think you need the bottom two bolts unless you are just super careful.
I can imagine once I let them sit a bit and then go back and torque them a bit more they wont flex at all.
I havent been working out so I am kind of weak on the wrenching.
Old 09-16-2012, 07:07 PM   #19
So while I was under there I noticed that my passengerr side CV boot clip came off the top end of the boot.
DAMMIT.
I just had this fixed from the sway bar crushing it when it popped off.
http://www.tacomaworld.com/forum/2nd...ght=lower+link
Thoughts? I am wondering if I need to get the diff drop for my truck since I have the 3 inch lift.
I read that it is not necessary and some say it does not even help.
Again Thoughts?
Old 09-16-2012, 07:27 PM   #20
The diff drop is a must i think with a 3" on a 4x4, but as i have not lifted my truck yet (this weekend ) ill let someone else answer that
Relentless sliders for sale Halo913 Buy / Sell / Trade 15 05-30-2012 01:40 PM
CBI bolt on sliders w/kickout and AllPro IFS skid SR54x4 2nd Gen Tacoma Marketplace 28 01-02-2012 07:45 PM
WTB: 2nd Gen DCSB Bolt-On Sliders tacomtn 2nd Gen Tacoma Marketplace 0 09-24-2011 12:05 PM
Relentless weld on sliders DWreck Buy / Sell / Trade 16 01-31-2011 02:42 PM
'05+ D-cab specific Bolt-on Sliders w/ kickout mr.trd CBI Off-Road Fab 14 11-15-2010 05:00 AM
