Head ache rack
Discussion in 'Relentless Fabrication' started by Huntr Pat, Oct 22, 2012.
  1. Oct 22, 2012 at 10:43 AM
    Huntr Pat
    Huntr Pat [OP] Green Taco
    Emmett*Idaho
    99 2.7 xtra cab
    K&N,Warn winch w/combo system,3"Revtek bilsteins,Marlin Crawler Nilights LEDs fog & flood Yakima roof racks. 31'"BFG K02's
    Need a head ache rack 4 a 99 1st gen taco. How much.
  2. Oct 22, 2012 at 11:29 PM
    RelentlessFab
    Eric
    Sparks, NV
    Depends on a few things.
    Steel or aluminum?
  3. Oct 23, 2012 at 8:15 AM
    Huntr Pat
    Emmett*Idaho
    99 2.7 xtra cab
    what ever cheaper aluminum cantbe that strong. I'd say steel\
  4. Oct 23, 2012 at 8:18 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    aluminum can be plenty strong
  5. Oct 23, 2012 at 8:21 AM
    tacofire38
    tacofire38 Captain Taco
    Land o Pears,TX
    08 Taco PreRunner SR5
    V-Tech gunmetalrims, BFG All-Terrains, Front 5100s and OME 884 coils, Rear 5160s, Rear AAL, SpiderTrax Wheel Spacers, Hummer Bed Rack, Thule Kayak Roof Racks........
    Had an aluminum rack on my old diesel and it held kayaks and wood and numerous other heavy items
  6. Oct 23, 2012 at 8:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    What are you trying to protect/use the headache rack for?? Cause there are guys running aluminum bumpers and skids...Pretty sure your headache rack won't get more abuse than that.
  7. Oct 23, 2012 at 8:26 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Of all of the head ache racks I have seen 99% have been Aluminum. Even on semi tractors.
  8. Oct 23, 2012 at 8:29 AM
    OZ-T
    Peter North
    British Columbia
    I have an aluminum headache rack , it's strong as hell and will haul whatever I have ever put on it , in my case 20' lumber
  9. Oct 23, 2012 at 8:30 AM
    Huntr Pat
    Emmett*Idaho
    99 2.7 xtra cab
    Aluminum best features is its weight ratio and its much more exspensive. I'd compare the price for both. I just need standard head ache rack with light tabs, and a opening for slider window tab on the for a vhf antenna on bottom right side. need to see some models.
  10. Oct 23, 2012 at 8:31 AM
    OZ-T
    Peter North
    British Columbia
    You gonna mount lights up top or rear facing ?
  11. Oct 23, 2012 at 10:14 AM
    Huntr Pat
    Emmett*Idaho
    99 2.7 xtra cab
    lights rear facing. will load lumber but that what they make trailers for. may haul some lumber from time to time.light tabs should be on bottom of top bar. rear facing so it dont interfere on loading.
  12. Oct 23, 2012 at 10:21 AM
    OZ-T
    Peter North
    British Columbia
    Cool
    I don't own a trailer , at least not yet :)
    Would you get a cage to protect the back window ? I had that on my old truck , saved my back window a few times hauling firewood
  13. Oct 23, 2012 at 10:31 AM
    Huntr Pat
    Emmett*Idaho
    99 2.7 xtra cab
    I use my Taco for hunting mostly. so if I have a roll over at least I have the headache bar. I would cage around and have the slider exposed. whats good is a slider if you can't use it.\
  14. Oct 23, 2012 at 11:11 AM
    OZ-T
    Peter North
    British Columbia
    I use my slider for ventilation
  15. Oct 23, 2012 at 1:14 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Hey Oz, where did you get your rack? Is it a relentless? I checked your build, but that didn't help much lol
  16. Oct 23, 2012 at 1:58 PM
    OZ-T
    Peter North
    British Columbia
    No , mine is from a Canadian truck accessory store called Cap-it , anything Eric builds will be even stronger than the one I have , having said that mine never had any issues with any load I hauled with it .
  17. Oct 23, 2012 at 2:32 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Alright, I was hoping You would say a Canadian store :D. Eric makes great stuff, but if I can get it locally im sure it will be cheaper. thanks Oz
  18. Oct 23, 2012 at 4:58 PM
    OZ-T
    Peter North
    British Columbia
    Yikes
    Unanticipated vendor thread derailment
    Sorry Eric
  19. Oct 23, 2012 at 5:06 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    OP, Bedracks are very easy to build, so if you are able to find a local fabricator/welder, they should be able to build you one for a few hundred, give or take, depending on what you want.
    this is for a 2nd gen, but the dimensions could easily be adapted for a 1st gen.
  20. Oct 31, 2012 at 2:30 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    :eek:
