toilet that keeps constantly running???
Discussion in 'Off-Topic Discussion' started by tacomaman06, May 4, 2011.
  1. May 4, 2011 at 4:57 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    any plumbers or anyone else round here know what would cause a toilet to constantly run? one of ours is doing it and its getting on my damn nerves with the trickling water sound. whats the cause/fix?
  2. May 4, 2011 at 4:59 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    see if the flapper is stuck
  3. May 4, 2011 at 5:01 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    the pull chain links may have doubled up-make sure the flapper closes all the way onto the hole-chech where the flapper hinge is positioned on the neck-the flapper needs to set level over that hole:)
  4. May 4, 2011 at 5:01 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    replace all of the parts inside the tank - should be able to pick up a kit at any hardware store. sometimes things just wear out...
  5. May 4, 2011 at 5:02 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    where's Scott? or Drew...
  6. May 4, 2011 at 5:03 PM
    CoopersTacoma
    CoopersTacoma Active Member
    2010 Double Cab TRD OffRoad V6 Auto
    ARE CAP
    ever heard of google??
  7. May 4, 2011 at 5:04 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I had this issue multiple times. Check everything that the above posts said but you can also screw that floaty ball thing that measures the water level. You should be able to screw it lower so it sits tighter above the water. Make sense? Dang listen to my instructions, haha, you can tell i aint no plumber neither!!!:rofl:
  8. May 4, 2011 at 5:04 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    ^^ This. Its almost always the flapper stuck open
  9. May 4, 2011 at 5:05 PM
    Tacomanator
    Clam Slammer
    Southern Cali
  10. May 4, 2011 at 5:06 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    im not entirely sure this is a serious thread. . . . but if not, just take back off and figure it out.
  11. May 4, 2011 at 5:16 PM
    MTgirl
    Weesa
    You forgot about the thing-a-ma-jig and the doo-hickey...;)
  12. May 4, 2011 at 5:16 PM
    MurphMan
    MurphMan Senility Rocks!
    Murph
    Maine
    '08 Tacoma TRD Sport
    * AFE Stage 2 XP CAI System * Westin Platinum Series Black Step Bars * TruXedo Lo Pro QT Soft Roll-Up Tonneau * Dee Zee Heavyweight Truck Bed Mat * WeatherTech Extreme-Duty Floor Liners * WeatherTech In-Channel Window Visors * Sony Xplod CDX-GT81UW Receiver * Sony Xplod 2-way speakers * Boss Audio BASS600 Amplified Subwoofer * Billet Grille Mod
    I vote on the flapper not sealing tight. Something is prob keeping it from sitting on the bottom completely (like the chain is too tight) or the flapper needs to be replaced. Other possibility is the shut-off needs to be adjusted so it will stop the water when the tank fills. Old ones could be adjusted by bending the arm that holds the float. More current ones will have a screw-type adjustment on the top of the valve assembly.
  13. May 4, 2011 at 5:18 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    245k+ miles, rust, working AC, bald eagles
    definitely the flapper thingy ma jig not sealing right.
  14. May 4, 2011 at 5:24 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Flap on. Flap off. The flapper!
  15. May 4, 2011 at 5:26 PM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    It's the flapper. The ball screwey thing is the float, youd mess with that if there was only an ounce of water in the bowl and you were leaving skid marks and wanted more water in the bowl. It's cheap and easy to replace. Fluidmaster makes the best replacements, you can get them anywhere. You can try to either press down or slightly lift up where the flapper is hinged to the fill valve so it seats better until you can get to a store. Remember the water in the tank is clean.
  16. May 4, 2011 at 5:28 PM
    MurphMan
    Murph
    Maine
    Toilet humor. :rolleyes:
  17. May 4, 2011 at 5:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sure have. i can play the smartass role as well.
    turns out its the flapper not sealing up good.
  18. May 4, 2011 at 5:29 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    no please elaborate
  19. May 4, 2011 at 5:29 PM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    i'd give you a free flapper from work if you were local! hahaha
  20. May 4, 2011 at 5:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thanks man.:rofl:
