Anyone built a TPMS pipebomb?
Discussion in 'Wheels & Tires' started by Shadow3, Aug 30, 2011.
  1. Aug 30, 2011 at 8:06 PM
    Shadow3
    Shadow3 [OP] Well-Known Member
    Carmel Valley, CA.
    2011 PreRunner SR5, Magnetic Grey
    Bilstein 5100 set at 1.75" Leaf Spring TSB HomerTaco Satoshi grill Brute forcefab rear bumper Sirius-XM radio Fog Light kit Wet Okole seat covers Metalmiller-Punisher
    Does anyone know of a thread regarding construction of a pvc TPMS pipebomb? I want to try that. Also has anyone tried puting all the sensors in the spare?
  2. Aug 30, 2011 at 8:07 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
  3. Aug 30, 2011 at 8:08 PM
    sprocketdog
    sprocketdog Well-Known Member
    Halifax Pa
    05 Taco 96 Taco 06 TSX 94 extra cab Hilux
    DR coilovers, Camburg UCAs, Dakar rear springs, Bilstien 5150s, Demello sliders, rear plate bumper w/ swing gate, and alot more mods. [IMG]http://i1216.photobucket.com/albums/dd368/sprocketdog1/059.jpg[/IMG]
    I seen a thread over in TTORA along time ago about this.
  4. Aug 30, 2011 at 8:10 PM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    uhhh....... pretty sure pipe bombs are illegal. just sayin......;)
    tcjacado likes this.
  5. Aug 30, 2011 at 8:10 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    yep, theres a few on here. Works pretty well, also.
  6. Sep 2, 2011 at 6:30 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    I bet the feds are keeping a close eye on this thread ;)
    Rocket23 and Kronk21 like this.
  7. Sep 2, 2011 at 7:18 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Pretty simple - I used a valve stem from walmart, 3" dia piece of PVC and 2 PVC endcaps. Cut about a 4" piece of the pipe. Drill a hole in one of the endcaps sized correctly for the valve stem you bought (there are only 2 common sizes, but I don't remember what the correct drill is). Pop the valve stem in from the underside. You'll probably have to gently pull it through with a pair of pliers. Use 2-part PVC primer and cement to attach the non-drilled cap to the pipe. Then wrap your TPMS sensors in some paper towels or something to keep them from rattling around and put them in the pipe. Then prime/cement the endcap with the valve stem in place. Wait 24 hours, then pump it up to 30 PSI and make sure it holds air. Follow your manual on how to reset your light.
    Mine has held for 5,000 miles now, no issues. I bought cement but not primer initially, and the chamber didn't hold air. PITA to re-do it, so spring the $5 for the primer and do it right the first time.
    kmbldr, wi_taco and AxisCab like this.
  8. Sep 24, 2012 at 11:47 AM
    D44boy
    D44boy Well-Known Member
    Kaneohe, hawaii
    2011 prerunner double cab
    Just followed these instructions. Works like a champ! Thanks Polymer! One thing that I found out is when you put the second cap on, because it makes a seal, the air pressure you create by putting it on prevents it from staying on. I had to depress the air valve as I pushed the second cap on.
  9. Sep 24, 2012 at 11:47 AM
    D44boy
    Kaneohe, hawaii
    and yes, i know, i revived a year old thread.
  10. Sep 24, 2012 at 1:01 PM
    OffroadToy
    OffroadToy pull my finger
    2007 Offroad DCSB AT- VSC,TRAC,HAC, & DAC
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    They're easy to make. I built this one a couple years ago but haven't used it yet. [​IMG]
    I just went to Home Depot for the pvc pieces and glue and a automotive store for the valve stem. I wouldn't recommend putting the sensors in the spare in case you ever need to mount it....some use a wheel barrel tire. They do make large hose clamp type straps though for mounting the sensors to the inside of wheels.... http://www.revolutionsupply.com/strapkit.aspx
  11. Sep 24, 2012 at 1:04 PM
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd use a threaded end cap so I could get them out if I ever needed to.
    Silentshredr likes this.
  12. Sep 24, 2012 at 4:04 PM
    D44boy
    Kaneohe, hawaii
    thought about that after. would it be airtight, or would you have to use cement to seal it off? Not that familiar with pvc.
  13. Sep 24, 2012 at 4:09 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Tried it. Didnt work. So I did the tear open dash and cut a wire and run it to 12v mod. Worked like a charm.
    AxisCab likes this.
  14. Sep 24, 2012 at 5:17 PM
    You could make it air tight, possibly with a rubber gasket or the use of liquid gasket.
  15. Sep 24, 2012 at 5:25 PM
    bjasper
    bjasper Well-Known Member
    Brian
    Carmel, CA
    06 TRD PreRunner
    Dad's truck, minor mods.. Saving for my own :)
    Looks like a Carmel Valley meet might be brewing in this tread. Haha
    Is your truck silver and black mostly? I think I saw you at the Bagel Bakery a while ago.
  16. Sep 24, 2012 at 5:41 PM
    Polymerhead
    Missouri
    :thumbsup: Nice. Good tip about depressing the valve. Mine has held up perfectly for the year since I wrote this. Also, I can't take credit for the idea. I took it from someone else here I think. Fits great in my under-seat storage.
  17. Sep 24, 2012 at 5:43 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    x2...
    Especially with a retired navy seal starting it haha
  18. Sep 24, 2012 at 7:57 PM
    Airun
    Aaron
    Show Me State
    Great lookn truck OP. love the tire and wheel combo.
  19. Sep 25, 2012 at 11:51 AM
    Shadow3
    Carmel Valley, CA.
    You probably have seen me around a few times! I am near the barnyard and crossroads often.
  20. Sep 25, 2012 at 11:52 AM
    Shadow3
    Carmel Valley, CA.
    Thanks man! I am happy with how it has turned out so far.
