95-97 Satoshi Build
Discussion in '1st Gen. Tacomas (1995-2004)' started by MapleMoose, Feb 2, 2012.
  1. Feb 2, 2012 at 9:06 PM
    MapleMoose
    MapleMoose [OP] Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    95-97 Tacoma Satoshi Write-up
    I havent seem too many 95-97 satoshi grilles on here so i decided to give it a shot and make a write up. I wanted a color matched look so i painted it white.
    Material List:
    95-97 Painted grille - $30-$100
    Toyota Landcruiser Emblem - $50 (PART NUMBER: #75311-90K00)
    Perforated steel with round holes - $20
    Color matched paint (2-3) - $30-$45
    Black Gloss - $15
    Clear Coat - $15
    Epoxy - $5
    Bondo and fiberglass - (had some laying around)
    I also borrowed a dremel kit from a friend.
    I started off by buying a new grille so i could take my time with it. I went with a painted style so i wouldnt have to deal with the chrome. Made it way easier to sand and prep the grille.
    I cut out the horizontal and vertical members with a cutting disc on a dremel. I made sure it was as flush as possible without damaging it too much.
    I sanded everything down with 120 grit sand paper and wiped it with a wet cloth. I then prepped the side parts for fiberglass. First time using this stuff and it was messy!
    Left it overnight to harden and then applied the bondo. Again this was the first time using bondo so it was messy.
    While the bondo was hardening, i traced the shape of the grille onto a piece of cardboard. I then transferred that onto my perforated steel. I cut the steel with a grinder and began sanding it down with 120 grit. I should have been using 400 grit too but i didnt have any. After sanding was done i sprayed it with brakleen to get rid of any rust or oils before painting.
    I did a couple coats of etching primer and couple coats of gloss black paint.
    Mr Yoda likes this.
  2. Feb 2, 2012 at 9:06 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Now back to the grille. I Sanded down the bondo after it dried until it was as smooth as could be. I then had to sand the edges down so the mesh would sit flush. I had to bring some parts of the edge up higher so it would make a straight line. I used a file.
    After that it was priming time. A couple coats of primer and a quick sand.
    Painting time!
    I couldnt find the exact paint match for my truck so i had to color guess. i ended up getting Nissan Super White for my mine. Worked out pretty well cause it matched up good.
    Finished it with a couple coats of Laquer clear coat. Test fitted the grille behind and it looked great!
  3. Feb 2, 2012 at 9:06 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Now one of the hardest parts was painting the headlight surround area. Taping it was not fun and i couldnt seem to prevent black paint from getting onto the my white grille. After a couple fails i finally got it.
    After it was completely dry, i flipped it over and worked on the pieces that will secure the mesh to the grille. I bought some little zip tie things to epoxy to the inside grille.
    Left it overnight to harden. I then cut up the small mesh pieces for the side vent parts of the grille. Primed and painted them and secured them using zip ties.
    All Done!
  4. Feb 2, 2012 at 9:13 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    very nice :thumbsup:
  5. Feb 2, 2012 at 9:51 PM
    Tacos Por Vida
    Tacos Por Vida Well-Known Member
    Dominick
    Albuquerque, NM
    97 Taco
    3-inch revtek spacers 265/75 BFG AT Flowmaster exhaust K&N CAI 12'' Type R w/ 1000w amp pioneer cd deck tinted windows
    nice write up, might have to do this one day.....
  6. Feb 2, 2012 at 9:53 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Nice! Looks good!
  7. Feb 2, 2012 at 9:54 PM
    Konaborne
    Konaborne Pineapples on pizza Hawaiian does not it make.
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    fox extended travel remote resivoir coilovers, 14" eibach 600lb coils, All Pro tubular chromoly 1" uniball upper control arms, All Pro expedition leaf packs, 10" bilstein 5150 piggyback reservoir shocks 265/75r16 Goodyear wrangler MT/R kevlars wrapped around 16" Helo 791 gloss black, Mini H1 retrofits with 6000k bulbs, 18" magnaflow w/custom exhaust reroute various decals, Sockmonkey retro hood stripes
    looks good!
  8. Feb 2, 2012 at 9:56 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    :wave:
  9. Feb 2, 2012 at 10:00 PM
    livel0veryde
    livel0veryde Well-Known Member
    josh
    missouri
    Tacoma based buggy
    nice write up sir.
  10. Feb 2, 2012 at 10:16 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    nice!
  11. Feb 3, 2012 at 10:45 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    looks great. looking to getting a 4wd grille to replace my 2wd grille that is currently on the tacoma now.
  12. Feb 4, 2012 at 2:10 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Thanks guys! I ordered a Landcruiser emblem today, should make it complete
  13. Feb 13, 2012 at 5:04 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Bad ass bro! Very inspiring! I think ill do this this summer :cool: Lucky for me..the grill you bought already looks color matched to my truck so no painting for me :D haha...sept corner lights..
    :thumbsup: Job well done!
  14. Feb 13, 2012 at 6:31 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  15. Feb 13, 2012 at 6:51 PM
    Madjik_Man
    Madjik_Man The Rembrandt of Rattle Can
    Colorado Front Range
    1998 Ext Cab 3.4 4x4 TRD 5MT, 2004 DC 3.4 4x4 TRD
    I'd like to pull a "Danielson" and wax on and wax off to your truck.
  16. Feb 13, 2012 at 7:02 PM
    96Taco
    96Taco Well-Known Member
    Alberta
    2014 DBL CAB Tacoma
    Awesome!
    Where did you get your steel mesh from?
  17. Feb 13, 2012 at 7:22 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Local welding shop. Its called "perforated sheet metal"
  18. Feb 13, 2012 at 7:22 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Not sure what to say to that.... but thanks!
  19. Feb 13, 2012 at 8:03 PM
    Madjik_Man
    You said enough :eek:
    I admit I have an unnatural boner for 95-97 front ends and yours with the color matched grille and satoshi makes me wanna maul myself.
  20. Feb 14, 2012 at 7:38 AM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    Nice man! You've encouraged me! I'll be doing this next!
