Sleeping Platform - 2x6's or 2x8's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skincer, Apr 16, 2013.
  1. Apr 17, 2013 at 9:24 AM
    #21
    OZ-T I hate my neighbour
    Here you go OP , hope this helps
    2x6 , fit sucks
    Shaped 2x8 , fits good
    Here are the dimensions for that
    If you want the top to be flush with the bedside ledge and top of wheel wells it will sit like this
    And here are the dimensions for the flush mount
    If you have any questions , hit me up
  2. Apr 17, 2013 at 9:44 AM
    #22
    skincer
    skincer [OP] Member
    San Diego Area
    2013 Tacoma 4WD TRD Off-Road
    Duh ... I don't know why it never occurred to me that 2 2x4's would be the right width. I still don't understand why they made that notch 1" deep rather than 1.5". I'm also thinking removing .5" of thickness from the bottoms of the ends of the 2x4's like OZ-T said would be a good idea so that the plywood sits on the ledge and the 2x4's. With the 2x4's and the edge support, I wonder if I could get away with 1/2" plywood ... probably best to go with 3/4".
    boston23 likes this.
  3. Apr 17, 2013 at 9:44 AM
    #23
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    The only thing you could have done better is just make him a set! :D
    Relaxinslax likes this.
  4. Apr 17, 2013 at 9:49 AM
    #24
    skincer
    skincer [OP] Member
    San Diego Area
    Damn, you're a woodworking master. Thanks a lot. I don't know how much of that I can replicate with my crappy table saw, but it gives me something to shoot for.
  5. Apr 17, 2013 at 9:53 AM
    #25
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Helluva post Oz! :) If I ever need to build these things I'll come back here.
  6. Apr 17, 2013 at 10:01 AM
    #26
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    so I do't have to go out and look, do I have those notches in my 07?
  7. Apr 17, 2013 at 10:03 AM
    #27
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I thought about making them just because he did all that work for us
  8. Apr 17, 2013 at 10:24 AM
    #28
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yes.
    I just used 2 - 2x6's and cut plywood to fit the space and they sit on top of the 2x6's. They are not cut flush with the ledge but will support anything you put on them. I've had close to 1,000 lbs on my platform (towards the front so notches were supported for the first few inches by the wheel well) and it did perfectly fine. If you're worried about sag, use 3/4" plywood. You do not need the ledge to support a simple sleeping platform and do not need a center support either. You guys are over thinking it.
    BigRus75 likes this.
  9. Apr 17, 2013 at 11:06 AM
    #29
    Ermahgerd
    Bosshoag likes this.
  10. Apr 17, 2013 at 11:08 AM
    #30
    You wanna rumble ?
    Bosshoag and TacoEspecial like this.
  11. Apr 17, 2013 at 11:09 AM
    #31
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Thanks Oz, Sub for future project.
  12. Apr 17, 2013 at 11:13 AM
    #32
    You're just mad cause you did all that extra work for nuthin!
  13. Apr 17, 2013 at 11:15 AM
    #33
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    OZ..you are a badass. hahaha..
    i just sleep on the bed of my truck. i tend to be in black bear country when i hunt/camp. hate to fall asleep hovered over a box of Snicker bars. :)
  14. Apr 17, 2013 at 11:15 AM
    #34
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
    I used 2x8's cut milled to fit. I made mine square, not fancy tapered edge like Oz. I also used a thickness planner to get the right thickness and then 1/4" round on all edges. Works great!
    hafjell likes this.
  15. Apr 17, 2013 at 11:21 AM
    #35
    Meh
    Literally took me 10 minutes , at work , while I was getting paid
    BigRus75, rob1208 and Tacobello like this.
  16. Apr 17, 2013 at 11:40 AM
    #36
    So you're cheating the system? tsk, tsk :D
  17. Apr 17, 2013 at 11:44 AM
    #37
  18. Apr 17, 2013 at 11:45 AM
    #38
    So you paid yourself to screw around? You might want to rethink your business plan :der:
  19. Apr 17, 2013 at 11:51 AM
    #39
    I get paid to be on site :)
  20. Apr 17, 2013 at 5:13 PM
    #40
    Or $165 for 10' of 1" x 4" x 1/8" aluminum rectangle tube 6063
    http://www.metalsdepot.com/catalog_cart_view.php?msg=
