3 inch lift and/or leveling kit pics thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by napiliboy47, Feb 8, 2010.
  1. Feb 3, 2014 at 3:28 AM
    #181
    setty7
    setty7 Well-Known Member
    Justin
    Florida
    PreRunner Sport
    Can someone plz help me. I'm wanting to pull the trigger here in a week or so. I'm wanting a leveling kit that will give me a little lean with front end being a little higher than the rear and is fairly in expensive. I don't want to do the 5100s because I have to max them out to achieve this look. Correct me if I'm wrong. I also want to do blocks instead or aal's in the rear. Thanks for y'all's help.
  2. Feb 3, 2014 at 7:45 PM
    #182
    setty7
    Justin
    Florida
    PreRunner Sport
    Bump bump
  3. Feb 3, 2014 at 7:48 PM
    #183
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  4. Feb 3, 2014 at 8:08 PM
    #184
    Alex352
    Alex352 Well-Known Member
    Alex
    Oregon
    07 Tacoma Dbl Cab
    http://www.tacomaworld.com/forum/2nd-gen-builds/281569-alex352s-build-thread.html
  5. Feb 4, 2014 at 3:51 PM
    #185
    setty7
    Justin
    Florida
    PreRunner Sport
    Can anyone plz answer my question. Thanks
  6. Feb 4, 2014 at 3:57 PM
    #186
    setty7
    Justin
    Florida
    PreRunner Sport
    Want some lean. Not look stupid though. And not have to spend a lot or run into suspension problems. Don't off-road, just strictly looks
  7. Feb 4, 2014 at 4:06 PM
    #187
    setty7
    Justin
    Florida
    PreRunner Sport
    Wat about blocks in the rear? And where is the best place to get these springs? Expensive to install?
  8. Feb 4, 2014 at 4:37 PM
    #188
    setty7
    Justin
    Florida
    PreRunner Sport
    How much will these springs lift the front?
  9. Feb 4, 2014 at 7:13 PM
    #189
    yotafirefighter
    yotafirefighter Active Member
    NC
    11 Tacoma
    3 inch suspension lift.
    Yes, the tires stick out a little past the fenders and mudflaps. and yes they are 17x9 -12 offset.
  10. Feb 4, 2014 at 7:30 PM
    #190
    setty7
    Justin
    Florida
    PreRunner Sport
    2.5" will get me the little bit of Cali without anything added in the rear correct? Will my stock shocks be fine if I add the coil springs?
  11. Feb 4, 2014 at 8:20 PM
    #191
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    PM sent
  12. Feb 4, 2014 at 8:35 PM
    #192
    TheGrayRider
    NW Florida
    2017 BBP DC 4X4 OR
  13. Feb 4, 2014 at 10:31 PM
    #193
    wrecks
    wrecks Member
    Bay Area
    2k13 SR5
    Weathertech Floor Liners, Cover King Seatcovers, Tonno Pro Soft cover, De-Badged, Plasti-dipped Rims,
    subscribed :)...
  14. Feb 5, 2014 at 6:50 PM
    #194
    setty7
    Justin
    Florida
    PreRunner Sport
    So, what do I need where I dont have to change much?
  15. Feb 5, 2014 at 7:24 PM
    #195
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    If your just wanting to level it then try the bilstein 5100 adjsutables.
  16. Feb 6, 2014 at 4:16 AM
    #196
    setty7
    Justin
    Florida
    PreRunner Sport
    but I don't want them to be maxed out for the look I want. It will be a rougher ride I am sure?
  17. Feb 6, 2014 at 1:21 PM
    #197
    Mainmoe02
    Moe
    Austin, Texas
    At the 2.5" mark they will be maxed out and ride fairly stiff. But at the 1.75" mark I'VE READ that they ride fine. I don't have experience with adjusting the 5100's past the stock coil seat setting, but I do run them on my truck. But from the research I've done on both 1st and 2nd gen setups the 5100's ride better than a spacer any day. If your wanting to not take apart the Coilover setup then you could add a small top plate spacer which I've also read is not a bad ride. If you get a top ate spacer any bigger than 1/4" then you'll need to extend the top plate bolts which requires taking apart the coil setup. There are 1/4", 1/2", and 3/4" top plate spacers. Remember that your lift height is double the size of the spacer.
  18. Feb 6, 2014 at 5:10 PM
    #198
    setty7
    Justin
    Florida
    PreRunner Sport
    Thanks for your help! If I just do the adjustables at 1.75" will I achieve the look I want (a little cali)? I dont want to do 2.5" and be maxed with a rough ride
  19. Feb 6, 2014 at 5:29 PM
    #199
    steveo27
    steveo27 Ask me about my weiner
    Steve
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    My 5100s are set at 1.75 with OEM Off Road springs and they ride fine. The front end feels ALOT tighter than it did with the stock Bilsteins.
  20. Feb 6, 2014 at 5:33 PM
    #200
    RaleighTaco
    RaleighTaco Well-Known Member
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    3in pro comp spacer up front...2in add a leaf in the rear and just upsized to 17'' mb tko's with 265/70/17 cooper atp's. My kit rides stiff as all get out compared to stock and i feel like my front shocks are maxxed out! Im upgrading my shocks to pro comp pro runners. Highly suggested if your going with the spacer. I will let you know if it improves ride quality as far as the front.
