MOOG Part #K100128 Problem Solver Caster / Camber Cam Bolt Kit
Discussion in 'RockAuto' started by tcBob, Feb 21, 2014.
  1. Jan 13, 2015 at 10:12 PM
    #101
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I've got some old TC stock length LCA bushings here in Orange County CA if you or anyone else would like to fit check them into some stock LCA's.
  2. Jan 14, 2015 at 12:11 AM
    #102
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    No the cam kits do not come with it
    The outer metal sleeve, which is actually pressed into the LCA. the kit seems to come with the inner sleeves, that go on the outside of the cam kit
    I'm not sure, and I've haven't rally done research on it fully, just kinda skimmed Google with the keywords on TW. Haven't found a holy grail on said kit with an install that works. I'll do some more digging tomorrow.
    I'll do some more research on it, if I tackle this, I might just end up doing the work myself to make sure I do it right and test fit options and possible write up for future reference.
  3. Jan 14, 2015 at 4:09 AM
    #103
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    @v5iov replaced the LCA bushings with the energy suspension bushings. Have to check his build thread :rolleyes:
  4. Jan 14, 2015 at 4:30 AM
    #104
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    No build thread yet.... but yes, you have to basically rebuild the bushings by reusing the shell and core....
    I did this at the same time as the moog cam bolts... all good so far...
    *edit: My OE bushings got really bad right before a trip to Rausch Creek and and the same week I totaled my daily driver... I did not get to do the work myself...
  5. Jan 15, 2015 at 4:58 AM
    #105
    Bonomonster
    Bonomonster Well-Known Member
    Albany NY
    2007 FJ Cruiser
    3" lift, Skids, Sliders, 33" tires
  6. Jan 15, 2015 at 9:05 AM
    #106
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I believe people have done it... but though they are for FJ aren't they? And I believe the FJ and taco have slightly different bushings
    @NJ636 had the part numbers and how they were different
    Can't really remember sorry
  7. Jan 15, 2015 at 2:00 PM
    #107
    Bonomonster
    Albany NY
    2007 FJ Cruiser
    I just posted the FJ ones because that's what I drive. I do believe they make a set for the Toccoa also.
  8. Jan 15, 2015 at 2:10 PM
    #108
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
  9. Jan 15, 2015 at 2:28 PM
    #109
    nj636
    Kev
    Jersey
  10. Jan 24, 2015 at 10:27 AM
    #110
    Bonomonster
    Albany NY
    2007 FJ Cruiser
    Just ordered two sets of the Moog bolts for my FJ. I'll let you guys know if they work or not.
  11. Jan 24, 2015 at 2:23 PM
    #111
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Gonna have these installed when they replace my frame!
  12. Jan 24, 2015 at 7:20 PM
    #112
    Bonomonster
    Albany NY
    2007 FJ Cruiser
    There's really nothing wrong with the stock ones as long as their not siezed. If they are putting on everything new, I'd just pull the bolts, and put on a good coat of anti-sieze. It'll last forever that way. Mine were froze already which is why I'm replacing. I'd go stock and anti-sieze them well, but the Moogs are cheaper so I went that route.
  13. Jan 24, 2015 at 8:33 PM
    #113
    Bonomonster
    Albany NY
    2007 FJ Cruiser
    I've never heard of anti-sieze washing out over time, but I guess it's possible.
  14. Jan 24, 2015 at 8:44 PM
    #114
    OZ-T You are going backwards
    Lol , fucking Canadians
    What's that in Freedom Units ?
  15. Jan 24, 2015 at 8:51 PM
    #115
    I'm not your buddy friend
  16. Jan 24, 2015 at 8:57 PM
    #116
    I'm not your guy buddy
  17. Jan 24, 2015 at 9:01 PM
    #117
    Of course you are , you're Canadian
  18. Jan 24, 2015 at 9:08 PM
    #118
    Damn I'm hungry now
  19. Jan 31, 2015 at 12:25 PM
    #119
    Bonomonster
    Albany NY
    2007 FJ Cruiser
    Well I received my parts from Rockauto today and their inventory is still messed up. I ordered 2 kits, both K100128.
    Kit #1 was sealed in plastic when I opened it. It has one 826-4 washer, two 826-3 washers, and a 826-2 washer. The instructions show this is what I should have. Instructions for kit #1: 0388663152cacd53dad0a93612c3b3d7_a389c6c4cbfe9d407eb6c553aa31444449a89d33.jpg
    Kit #2 was already opened, and obviously was returned at some point. One of the grease fittings is already installed, and the other is just loosely floating around in the box. I am also missing one of the sleeves with this kit. This kit also came with different washers. It has one 826-4 washer, two 826-8 washers, and a 826-2 washer. The instructions for this kit also show that this is correct. Instructions for kit #2: 4b65f2b52036c807acf108db990f22cb_8046f1600db2148167a519dba9b89a46f47b5695.jpg
    Along with that, they also sent me the wrong wiper blades.
    I obviously need to call Rockauto to get this fixed. What I need to know is exactly what washers I need. These are for a 2007 FJ cruiser. Moog shows the FJ uses the same K100128 kit as the Tacomas.
  20. Jan 31, 2015 at 12:30 PM
    #120
    Bonomonster
    Albany NY
    2007 FJ Cruiser
    Also, none of the sleeves rotate freely around the bolts, and I can't get any of the nuts to thread onto the bolts more than a few turns. Is all of this normal?
