Biggest Spare That Fits Under Bed
Discussion in 'Wheels & Tires' started by sac130e, May 10, 2011.
  1. May 10, 2011 at 10:43 AM
    sac130e
    sac130e [OP] Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Wondering what the biggest tire size that will fit in the storage place under the bed. I have a 275/70/17 and need to know if that size wheel will fit in the spare mounting location. Has anyone else fit bigger wheels under the bed?
    Thx
  2. May 10, 2011 at 10:53 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i fit a 285 under there on the stock rim. i cut the side bracing for the spare though.
  3. May 10, 2011 at 11:01 AM
    sac130e
    Scott
    Milton, FL.
    I plan to mount the tire on a MotoMetal rim up under there, do you think this would damage the rim up under there? Hate to spend 200 on a chrome rim to see it damaged under there.
    Thx
  4. May 10, 2011 at 11:04 AM
    The_Hodge
    SC
    the tire should hit the supports under the bed before the rim would, but you'd still be susceptible to stuff coming up from the road or from offroading.
  5. May 10, 2011 at 11:08 AM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    A 285-70-17? I would be interested to see what you had to cut if you could snap a pic. I wonder if certain tires would fit better than others. Like an A/T vs a M/T?
  6. May 10, 2011 at 11:20 AM
    The_Hodge
    SC
  7. May 10, 2011 at 12:22 PM
    sac130e
    Scott
    Milton, FL.
  8. May 10, 2011 at 12:46 PM
    The_Hodge
    SC
    running a tire carrier now and was previously running 315s, so they were definitely not going to fit. no issues w/ heat. same locks/deterrents can be used w/ the 285 that can be used w/ a stock spare, ie cables w/ locks.
