Squeaky Dakars : Any advice from others with the Dakars ?
Discussion in 'Suspension' started by OZ-T, May 10, 2011.
  1. May 10, 2011 at 8:44 PM
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    As the title suggests , I have the Dakars on my '09 DCLB , they have been on the truck for about 2 weeks , one side has started to squeak a bit , I pressure washed any grime outta them and that solved the problem for a couple days but now that side has a slight squeak again .
    All of the silencer pads are still there and the factory grease is all present and accounted for , the squeak seems to be coming from the front just behind the mounting eye , in between the top 2 leaves . The new bushings were lubricated with a rubber friendly grease on install .
    I have seen the sticky for squeaky leafs but was wondering if there are any Dakar specific things I could try or maybe overlooked .
    The squeak is not that big a deal to me , but if it wasn't there I would enjoy that a bit more .
    Discuss
    EDIT : my solution
    Alternately , TW members Cape Codder and Crom have come up with this solution using zip ties ~
    https://www.tacomaworld.com/threads...-with-the-dakars.156353/page-29#post-10499502
    https://www.tacomaworld.com/threads...-with-the-dakars.156353/page-31#post-10669474
    lynyrd3, CowboyTaco and Rhyno like this.
  2. May 10, 2011 at 8:48 PM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    beaver grease?
    SOSHeloPilot likes this.
  3. May 10, 2011 at 8:49 PM
    OZ-T
    Peter North
    British Columbia
    I'm trying to actually have a serious thread here , thank you .
    lynyrd3 and verynearlypure like this.
  4. May 10, 2011 at 8:53 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    I know, i just wanted to add that, and this explaining that.
    OIG :wave:
  5. May 10, 2011 at 8:53 PM
    jjbeenken
    jjbeenken Well-Known Member
    Arkansas
    2022 DC TRD Sport(always under construction)
    Hertz - Arc Audio - Precision Power - Image Dynamics - Helix -AP UCA's - Dakar Springs - Icon Vehicle Dynamics
    My buddy's stock leaf with an aal started squeaking, I'm wondering if those shackle bolts needed chassis greeez?
  6. May 10, 2011 at 8:55 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Pressure washed the springs? Possibly forced grime into spring, and washed out some grease. Can't you compress the spring by driving on an offset incline and lube the leaf once it begins to flatten out?
  7. May 10, 2011 at 8:57 PM
    rcfreak201
    rcfreak201 Well-Known Member
    subbed, i dont have dakars but my leaf squeak on every little bump i go over, its super annoying!
  8. May 10, 2011 at 8:57 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    just wondering, wouldnt it be the same as a factory leaf squeak? (i know you put different ones in there) mine squeaks too, pretty bad actually. i have some dupont synthetic grease that may end up in them.
  9. May 10, 2011 at 9:01 PM
    Blumpkinson
    Blumpkinson Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    I have Dakars on my 1st gen, they have been squeaking since the first time i took it offroad. It's probably just all the sand that gets stuck between the leafs. I've tried pressure washing it too, but it eventually comes back. It has gotten noticeably less noisy after breaking them in (i might just be use to the sound by now though).
    Just turn the music up or use it as an excuse for an aftermarket exhaust :D.
    Dr.Gonzo likes this.
  10. May 10, 2011 at 9:04 PM
    CopyTaco
    CopyTaco skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    OME, Demello, 4xInnovations, Relentless, Murdered Click Sig Pic for Build Log
    While not the Dakar's, my 2" AAL from Toytec squeaked like crazy over the smallest speed bumps etc. and was incredibly annoying. It finally went away when I took my truck to an OHV park for the first time and got some real flexing going on for a few hours. After that trip the squeaking has gone completely away. Worth a shot and you might have some fun while doing it :)
  11. May 10, 2011 at 9:27 PM
    OZ-T
    Peter North
    British Columbia
    I'm just talking about one of those car wash sprays not a real pressure washer .
  12. May 10, 2011 at 9:29 PM
    OZ-T
    Peter North
    British Columbia
    Mine were quiet until it rained and I was travelling on a dirt road , lots of fine mud under there
  13. May 10, 2011 at 9:41 PM
    OZ-T
    Peter North
    British Columbia
    I read a thread that suggested that the bushings that come with the Dakars are squeak culprits and should be replaced with OEM ones .
    Anybody done this ?
  14. May 11, 2011 at 10:42 AM
    OZ-T
    Peter North
    British Columbia
    The front bushing is pressed in from OME , but if it is the same diameter as the rear you should be able to replace them with the ones used on the rear eyes , no ?
  15. May 11, 2011 at 12:19 PM
    OZ-T
    Peter North
    British Columbia
    Agreed
    What did you torque your hanger bolts to ? I've also read that they can be the source of the squeak if over cooked .
  16. May 11, 2011 at 12:27 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    It's the front bushing. You can do one of two things.
    1. live with it
    2. replace the bushings (with oem or aftermarket)
    I find they are fine when they are wet and they are fine when they are dry. Anywhere in-between and they squawk like a mother. If you stick your head by the front bushings and rock the truck you will find that is the source.
  17. May 11, 2011 at 12:29 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    As an add-on I've have chose to live with the squeak as there are only a few short months here where is doesn't rain.
  18. May 11, 2011 at 12:31 PM
    OZ-T
    Peter North
    British Columbia
    Thanks Jeremy
  19. May 11, 2011 at 4:39 PM
    AK27
    AK27 Well-Known Member
    try 'sea foam deep creep' oz, one of the garage crew had success with it on his leaf packs
  20. May 11, 2011 at 5:15 PM
    OZ-T
    Peter North
    British Columbia
    Thanks
