HELP! Kitten Stuck In Engine Department
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomapro, Jun 1, 2011.
  1. Jun 1, 2011 at 1:19 PM
    Tacomapro
    Tacomapro [OP] Well-Known Member
    SR5 Regular cab 4x4 K&N Cold Air, Toyota 16" Baja Rims, 18" Magnaflow Muffler, and 35% Tint.
    SR5 Regular cab 4x4 K&N Cold Air, Toyota 16" Baja Rims, 18" Magnaflow Muffler, and 35% front tint 15% rear glass tint.
    Please Help!
    I have a kitten stuck in between the radiator and the fan. I guess you would call it the opening for air to hit the radiator from the fan. It is in the bottom of the circular opening. What would be the quickest way to get this kitten out???
    Thanks
  2. Jun 1, 2011 at 1:21 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
  3. Jun 1, 2011 at 1:22 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    :worthless:
  4. Jun 1, 2011 at 1:23 PM
    Tacomapro
    Sorry, it is a 2008 regular cab, manual.
    Sorry no pics...
  5. Jun 1, 2011 at 1:23 PM
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    Turn the truck on...
    Find a really small puppy to chase it out....
    Spray it with water :notsure:
  6. Jun 1, 2011 at 1:25 PM
    David Tarantino
    N.J.
    08 tacoma
    how the hell did it get in there
    you may have to remove the fan
  7. Jun 1, 2011 at 1:26 PM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Haha...not doing it...can't make me!
    Horn...or it's actually un able to physically get out? That could take some removing parts.
  8. Jun 1, 2011 at 1:26 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    Pics or it didn't happen
    :locked:
  9. Jun 1, 2011 at 1:27 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Animals will snuggle up to the motor at night if it is cold out .
    Good luck OP
  10. Jun 1, 2011 at 1:27 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
  11. Jun 1, 2011 at 1:27 PM
    SuperTacoma
    SuperTacoma Well-Known Member
    Clint
    Georgia
    2019 Double Cab SR5 4x4 Silver
    I had a kitten stuck on my wheel well above the strut of my Escape.
    I put a glove on one had. (Sharp little claws) and use the air compressor to shoot burst of air at it and it slowly crawled out backwards until I could get with the gloved hand and set him free.
  12. Jun 1, 2011 at 1:28 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    take the fan shroud off
  13. Jun 1, 2011 at 1:29 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
  14. Jun 1, 2011 at 1:29 PM
    mjohn617
    Petaluma, CA
    How did you know there was a kitten there in the first place?
  15. Jun 1, 2011 at 1:30 PM
    TacoMal
    California
    I've seen one crawl under and onto the driveline of a crown vic as it pulled into a parking lot. Took about 20 minutes to nab it and pull it out. I mostly watched, and laughed.
  16. Jun 1, 2011 at 1:30 PM
    Tacomapro
    It got there because I started my truck. It must have hit the fan and wentforward, landing on the bottom of the circular opening in front of theradiator. It moved to the passenger side at bottom of the circular opening. Itwas not bleeding and was still alive. Can I move that black housing around the radiator easily or should Iremove skid plate and try to reach up from the bottom?
  17. Jun 1, 2011 at 1:32 PM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    just yank him out...they are really flexible
  18. Jun 1, 2011 at 1:33 PM
    Tacomapro
    Thanks,
    I will give it a try.
  19. Jun 1, 2011 at 1:37 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    If it's a small kitten...they're actually really flexible....I suggest long sleeves and a pair of leather gloves.
    Reach in there and grab him/her around the head and pull him out. He won't like it...but looking at the amount of space down there and between the fan blades (I actually went outside and looked at mine) I don't see why it wouldn't work. Don't force it if he gets hung, but I can't see that happening....if your arm and hand go in...his head and body should come back out the same route. My opinion FWIW..
  20. Jun 1, 2011 at 1:38 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    i'd just crank the engine until i screams and runs out?
