Footwell, Cupholder, Console, Glove Compartment, Rear Seat LEDs
Discussion in 'Lighting' started by Tacown3d, Jan 17, 2012.
  1. Jan 17, 2012 at 9:35 PM
    Tacown3d
    Tacown3d [OP] Member
    Austin, TX
    09 PreRunner TRD Sport
    I spent all day rigging up my Taco the way Toyota should have. Behold! Light!
    The glove compartment light is brighter than the picture indicates...
    These look great from above.
    All of the lights are tied in with the AirCon controls so they dim with the dash lights. I'll probably change the footwell and rear floor lights eventually since they aren't a match to the factory orange... oh well.
    Special thanks to Oznium and Super Bright LEDs for without their products, I would have been in the dark. Thank you to TW for the guidance in disassembling the dash, console, and the correct location to tap into the dash lights. My next lighting project will be entry lights that shine onto the ground below the door when the key fob unlock is pressed.
  2. Jan 17, 2012 at 9:47 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    very nice work
  3. Jan 17, 2012 at 9:49 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    the floor lights arent triggered with the doors? just when dash lights are on?
  4. Jan 18, 2012 at 3:24 AM
    OxyGuy
    OxyGuy Well-Known Member
    Conway, SC
    2007 PreRunner
    What lights did you use for the footwell and cupholders? Can you give a few details of how you done this?
  5. Jan 18, 2012 at 9:57 AM
    Tacown3d
    Austin, TX
    When I tap into the dome light for my entry lights, I'm going to mount white LEDs under the dash that will come on when the door is open. I wanted the amber ones for driving.
    Footwell lights in front:
    AM-RB-x6: AM series Miniature Rectangle Accent Light - Black from Super Bright LEDs
    Footwell in rear:
    ALM-RB-x3: ALM 3 LED Rectangular Accent Light Module from Super Bright LEDs
    Cupholder: 2 of these 5mm Orange
    http://www.oznium.com/prewired-leds
    For the cupholder lights, I removed the entire center console and disassembled the dash to remove the lower center dash area where the cigarette lighter and auxiliary port reside. I then drilled 2 holes for the LEDs and used LED holders from Radio Shack. The light inside the center console is a flexible self-stick ribbon from Super Bright LEDs... while I had the console out, I drilled a hole for the wires to pass through and stuck it under the lip on the edge. The rear floor lights were mounted to the hump that contains the under-seat storage box. I removed the box so I could run the wiring.
    All of the lights are tied into the power and ground coming from the AC selector switches. Green is power, green-white is ground.
  6. Jan 22, 2012 at 6:34 PM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    what circuit do i tap for dome on with the door open.where do i find it ? i put 6 led aftermarket liscese plate twin bulbs along the bed rail and just have them on a switch would like to have them on with the door open circuit and help would help (2010 taco)
  7. Feb 8, 2012 at 12:06 PM
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
  8. Feb 9, 2012 at 8:15 AM
    Oregon TRD
    Ross
    2005 Mall Krawler
    I thought of doing this, putting my wide angle leds in the plastic under the door. But I have a full kit under my truck so i skipped it. Would work perfect though. I may do it anyway.:cool:
