Another front wheel bearing replacement resource
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Feb 2, 2012.
  1. Feb 2, 2012 at 2:49 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Bear with me. I want to put all the research aides I used in one place.
    For starters my 2006 has 81,### miles. The front driver side wheel bearing is roaring and when jacked up the wheel shakes when rocked from the top and bottom. I am planning on replacing the bearing assembly and then replacing the bearing in the OEM assembly for the next time the bearings go out.
    The exploded front wheel hub assembly from Toyodiy.com:
    Instead of being raped by Toyota or E-bay I opted for a Timken replacement.
    http://www.autopartswarehouse.com/s...c=Front&intcmpid=Product+Listings+Best+Seller
    I will get the oil seals (43501F and 43502F) and O-Rings (90301-A0005) from my friend at the Toyota dealership.
    90301-A0005 - O-ring
    90316-A0001 - Inner Oil Seal
    90312-96001 - Outer Oil Seal
    Rockauto, has the Timken(koyo) bearing and the national seals. Don't forget to look-up their promo code for us.
  2. Feb 8, 2012 at 4:42 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Yep
  3. Mar 12, 2012 at 10:10 AM
    Marnes2986
    Marnes2986 Well-Known Member
    Mark
    Anaheim-Corona, Ca
    Do you need the 43501F and 43502F seals?
    The inner seal goes between the bearing and the hub, where does the outer seal go?
  4. Mar 12, 2012 at 10:23 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Take old seals off put new ones in same location = pretty easy :D
  5. Mar 12, 2012 at 1:42 PM
    Marnes2986
    Mark
    Anaheim-Corona, Ca
    Sorry im sure i read it yesterday. Ive been going through all the wheel bearing threads and decided to post on this one.
    Most of the threads say they replace the o-ring, the inner and the outer seal. But on this thread the OP mentions:
    "I will get the oil seals (43501F and 43502F)"
    Im wondering if I need to purchase these parts too.
  6. Apr 26, 2012 at 2:20 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I have not had to remove / replace my front bearings yet. I was under the impression from the photos posted on TW, that the roller bearing is obtainable, but the outer bearing race is part of the flange. In other words, in a typical bearing setup, you have the roller assembly and a bearing race that is pressed or driven into the housing.
    If you replace the bearing into a worn / used housing, wouldn't this be asking for troubles from the start?
    As I said, I could be all wrong and maybe those bearing races can be replaced.
    PK
  7. Apr 26, 2012 at 3:32 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Pardon my ignorance as I have not had this apart but..............if it is an unserviceable sealed pressed in bearing, then why does it need more than a couple of o rings to keep crap out. What oil is there that is requiring the inner/outer oil seals? If bearings are serviceable then why can't we just repack them to prevent them from going out as soon as they seem to do? Is the early demise a 4wd thing vs. prerunner thing since they are just rolling on the prerunner and no power is applied to them?
  8. Apr 26, 2012 at 4:07 AM
    PMK
    Florida
    10 DCLB TRD Sport
    I have read that both 4wd and prerunners have bearing issues, the 5 lug does not. The seals are grease seals to keep crud out and grease from flowing out onto the suspension and no doub greasing the brakes.
    As for servicing, the task involves the same disassembly and pressing apart so most folks would not bother with it until failure.
    PK
  9. Aug 20, 2012 at 8:46 PM
    tinker2
    tinker2 Well-Known Member
    East Of The Big River
    :homer: Sub'd
  10. Aug 20, 2012 at 8:48 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    . . . Sub'd . . . good info. . . . especially with parts numbers and exploded views.
  11. Oct 5, 2012 at 5:44 AM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    anyone have the national oil seal # for 43501F & 43502F ??
    i tried cross referencing them with my national book at work but no luck..
  12. Oct 5, 2012 at 5:46 AM
    nj636
    Kev
    Jersey
    Just found Nat'l # 710477 (Outer) $8.70 & 710573 (Inner) $9.65
    Save some cash over the Toyota seals
  13. Oct 7, 2012 at 1:16 PM
    streamlight
    streamlight Member
    I've got the bearing/hub assembly new for sale cheap if anyone needs it.($60.00 shipped)
    I've got the Beck Arnley version which I believe is made by the same manufacturer that made National Bearing & MOOG. Below are a few cross reference numbers.
    Toyota #43570-04010
    SKF #FW194
    National Bearing,MOOG #515040
    Timken #BM500007
    Koyo #ATM2122437
  14. Dec 3, 2012 at 12:10 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    So, what is with the right and left numbers? The aftermarket sources don't differentiate between the two. Why does Toyota? I want to buy a hub, #43501/43502, so I can have a bearing assembly pressed in and have a complete unit ready to bolt in to save time in the future. I'm hoping I can buy just one and use it for either side. Which one should I get? the 01 or the 02?
  15. Dec 4, 2012 at 8:14 AM
    streamlight
    streamlight Member
    Nothing special about the LH & RH letters, I believe it's just to indicate that there are two of the same part.
  16. Jan 17, 2013 at 9:41 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Added these to the OP. Also RockAuto has the Timken(Koyo) bearing and the National seals, use their promo code too!
  17. Jan 29, 2013 at 2:05 PM
    nj636
    Kev
    Jersey
    saving money :woot:
  18. Jan 30, 2013 at 9:11 AM
    xyourlocaldjx
    xyourlocaldjx Well-Known Member
    are all those oil seals needed for a 2 wheel drive as well or are some not needed?
  19. Jan 30, 2013 at 9:26 AM
    XXXX
    sKiP
    05 Prius
    Some are for the CV's so they are not needed. I'm not sure what ones because I have a 4x4.
  20. Jan 30, 2013 at 11:57 AM
    nj636
    Kev
    Jersey
    5 lugger or pre-runner?
