2nd Gen Tacoma shock info compilation
Discussion in 'Suspension' started by DevL, Aug 2, 2012.
  1. Aug 2, 2012 at 10:59 AM
    DevL
    DevL [OP] Well-Known Member
    Id like to make a compilation of shock info for 2nd gens.
    To start I'd like to by confirming this is the factory installed TRD shock.
    Can anyone confirm? If anyone finds any incorrect info or typos let me know.
    FRONT TRD FACTORY SHOCK
    46mm Monotube Shock Absorber
    Internal Design: Monotube
    Collapsed Length: 17.1 in / 434.3 mm
    Extended Length: 22.17 in / 563 mm
    Boot Included: Blue straight
    Mounting Kit: B4-KT1-Z237A01
    Spring Seat: Replaceable (E4-FT1-Z011A03)
    Finish: Yellow paint
    Supercedes: F4-BE5-C513-H1
    Part #: 24-188401
    REAR TRD FACTORY SHOCK
    Series: 4600 Series; 6 Lug Wheel; Rear; 46mm Monotube Shock Absorber
    Collapsed Length: 13.98 in / 355 mm
    Extended Length: 22.94 in / 582.7 mm
    Mounting Kit: B4-KT1-Z008A00
    Spring Seat: No
    Supercedes: F4-BE5-C515-H0
    Part #: 24-186056
    FRONT 5100 BILSTEIN
    Series: 5100 Series (Ride Height Adjustable); Front Lifted Height: 0-2.5"; Front; 46mm Monotube Shock Absorber
    Collapsed Length: 17.03 in / 432.5 mm
    Extended Length: 22.56 in / 573 mm
    Boot Included: Black straight
    Reservoir: No
    Finish: Zinc plated
    Supercedes: F4-BE5-C475-H1
    Part #: 24-186711
    REAR 5100 BILSTEIN
    Series: 5100 Series; Rear Lifted Height: 0-1"; Rear; 46mm Monotube Shock Absorber
    Collapsed Length: 14.02 in / 356 mm
    Boot Included: Black bellows
    Spring Seat: No
    Reservoir: No
    Finish: Zinc plated
    Supercedes: F4-BE5-C476-H0
    Part #: 24-186728
    REAR 5160 BILSTEIN
    Series: 5160 Series; Rear Lifted Height: 0-1"; Rear; 46mm Monotube Shock Absorber
    Collapsed Length: 13.84 in / 351.5 mm
    Extended Length: 23.23 in / 590 mm
    Boot Included: No
    Spring Seat: No
    Reservoir: Yes
    Finish: Zinc plated
    Supercedes: F4-BR5-H734-H0
    Part #: 25-177343
    FRONT OME NITROCHARGER
    OME N140S Nitrocharger
    Internal Design: Twintube
    Collapsed Length: 15.95 in / 405 mm
    Extended Length: 21.38 in / 543 mm
    Spring Seat: No
    Reservoir: No
    REAR OME NITROCHARGER
    OME N182 Nitrocharger
    Collapsed Length: 13.86 in / 352 mm
    Extended Length: 23.94 in / 608 mm
    Boot Included: No
    Spring Seat: No
    Reservoir: No
    FRONT OME NITROCHARGER SPORT
    OME N90000
    Internal Design: Twintube/Montube Hybrid
    Collapsed Length: 16.26 in / 413 mm
    Spring Seat: No
    Reservoir: No
  2. Aug 3, 2012 at 8:44 PM
    DevL
    Links pointing to data would be a big help guys...
    Still needed
    Need Icon 2" rear and 2.5" front and rear.
    Need Fox 2.5" front 2" rear.
    Need King 2.5" front and rear.
    Need anyone elses coilovers or shocks you think should be added.
  3. Aug 8, 2012 at 3:13 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    FOX Shox:
    OE Length 2.5 w/ Remote Resevoir
    Fox Part# 880-02-376-B
    Extended Length: 22.21"
    Collapsed Length: 17.58"
    Shock shaft Travel: 4.63"
    Height Adjustment: 0"-2"
    OE Length 2.0
    Fox Part# 985-02-002
    Extended Length: 22.23"
    Collapsed Length: 17.55"
    Shock shaft Travel: 4.7"
  4. Aug 22, 2012 at 7:23 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Toyota TRD Bilstein shocks are NOT Bilstein 4600s. The TRD shocks are built by Bilstein to Toyota specs, but they are not 4600s.
    TomHGZ likes this.
  5. Nov 16, 2012 at 7:13 PM
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    05/ 07,09/11Tacoma access cab 4x4
    Fox Part# 880-02-418-A
    Extended Length: 22.54"
    Shock shaft Travel: 4.96"
    Height Adjustment: 0"-3"
    Kit comes with reservoir mounting brackets. Extended travel shock to be used with UCAs. Recovers lost droop due to lift if wound up.
  6. Nov 18, 2012 at 8:37 PM
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    so billstien 5100 0-1 inch lift and factory yellows have same extended length???
  7. Nov 19, 2012 at 4:52 AM
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    Very close but both are crap shocks.
  8. Nov 19, 2012 at 5:25 AM
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    [/QUOTE]REAR OME NITROCHARGER
    Boot Included: No
    Spring Seat: No
    Reservoir: No[/QUOTE]
    Correct me if I am wrong, but isn't the boot the aluminum sleeve that sits around the shaft?
    TomHGZ likes this.
  9. Nov 19, 2012 at 5:32 AM
    hanrock
    craig
    sask
    i think the newer sport version has a black plastic one..
    TomHGZ likes this.
  10. Nov 19, 2012 at 6:38 AM
    TeamLombardo
    Tony
    El Paso
    The fronts have the black plastic one. My rear N182s came with the yellow aluminum boot like pictured in the OP
  11. Dec 2, 2012 at 10:59 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    sticky?
  12. Dec 24, 2012 at 4:10 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Opinions from those who run them: FOX vs. BILSTEIN for front end upgrade from factory Bilstein (or other options) for desert running... not racing, but to improve the bounce or stop the rocking horse affect.
  13. Dec 25, 2012 at 6:20 AM
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    Night and day difference..bigger shock, more damping, adjustability, remote reservoir.
  14. Aug 30, 2013 at 6:10 AM
    Longo118
    Longo118 Well-Known Member
    New York
    2006 4x4
    -OME Lift w/ Dakar leafs -Wheels + Tires -All Pro IFS skid -4xInnovations Sliders -Tool box, hi-lift, shovel mount and a few others
    I just have to Sub to this thread because this helped me answer SO many questions haha.
  15. Aug 30, 2013 at 8:41 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    You can get a black plastic cover for the rears too that go over the aluminum. Toytec charges you extra for them, calls them rock guards. When I ordered mine from wheeler's they came with them.
  16. Jul 19, 2014 at 9:21 AM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    The OME rear shocks have an impressive range of travel for their size but they really limit rear droop it seems. In the back with the stock bumpstops you should be able to run a shock with a compressed length of 15-16". Does anyone know if there is an OME shock with the same valving but a longer compressed length? OME doesn't really list valving and lengths as clearly as bilstein or some other manufactures... their catalog is more application based ):
  17. Jul 19, 2014 at 9:25 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    very handy list, I am going to sub since new shocks are on my to do list...
  18. Dec 4, 2014 at 6:39 AM
    yzmxer608
    yzmxer608 Active Member
    I'm kind of confused here, are the two shocks measured the same way? If the OME's can provide 2.5" of lift how are they shorter than the stock TRD's? Does it have something to do with the collapsed length? Aren't they non-adjustable as well?
    Also for shocks that have extended length (i.e. Icon extended length version) the extra inch of wheel travel (.5" shock travels) applies to down travel correct? How long of a shock could you theoretically use to get more down travel, eventually it'd limit up travel right? Just as an example if you took that Icon shock and made it 1" longer to give 2" down travel, what would happen over the whole stroke?
    Edit: Disregard the last part, I figured it out after thinking about it a while.
  19. Mar 6, 2015 at 8:46 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Ironman4x4
    http://www.ironman4x4.com/catalogues
    http://www.ironman4x4.com/system/resources/W1siZiIsIjIwMTUvMDIvMTkvMmt6aTN6dGUwcV9Wb2xfMTVfV0VCX0lyb25tYW5fNHg0X1N1c3BlbnNpb24ucGRmIl1d/Vol%2015%20WEB%20Ironman%204x4%20Suspension.pdf
    Front - 12710GR
    Extended Length: 540 mm / 21.26"
    Collapsed Length: 408 mm / 16.06"
    Rear - 12744GR
    Extended Length: 609 mm / 23.98"
    Collapsed Length: 361 mm / 14.21"
    Old Man Emu
    http://www.arbusa.com/Uploads/PDF/onlineManualsGuides/OME_Guide_current.pdf
    Front - 90000 and 90021
    Extended Length: 543 mm / 21.38"
    Collapsed Length: 413 mm / 16.26"
    Rear - 60091
    Extended Length: 599 mm / 23.59"
    Collapsed Length: 360 mm / 14.17"
    I used Google to convert the mm to in. It wasn't exact, so the inches have been rounded to the hundredth either up or down.
  20. Mar 7, 2015 at 8:59 AM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Yes they are. It's the coil that you pair them with that provides lift. The shock itself has a set length of travel. So all your longer/stiffer coil does is change your ride height. Your suspension cannot droop any more or uptravel any more unless you start messing with control arms. The OME have the same amount of travel but yes it is odd that they are have a different extended and collapsed length :notsure:
    And no OME shocks arent "adjustable"
