Not just a body mount chop, but relocated!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Haws, May 15, 2013.
  1. May 15, 2013 at 9:29 AM
    Haws
    Haws [OP] Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    So over the last few years I've been on the mission to build up my 2010 double cab TRD. My goal is 37" iroks on 16x10" wheels. Ive read many many builds, and know of most of the obstacles to try and make this happen.
    This is what I recently done. With the help of Double R Custom Metal Fab we completely removed and relocated the front body mounts behind the front fenders, and rebuilt/relocated them further back. This made a whole lot more room for tires. Not as hard to install as one might think. What do you guys think?
    He mentioned that if there was enough interest that he would put together a kit for anyone else wanting to do this. The new ones will be a bit thicker.
  2. May 15, 2013 at 9:33 AM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Whats it looks like on the inside where he moved it too? A few more pics would help
  3. May 15, 2013 at 9:39 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    ^ agreed, need more pics
    +1 on originality. I have never seen an attempt at this. Even though I'll never go to 37"s, still like to hear/see more on this. The mount point you relocated to able to handle the load as the stock location?
    :playball:
    Big Sky Country likes this.
  4. May 15, 2013 at 9:47 AM
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    Looks great!!! Did you have some pictures of the install??
  5. May 15, 2013 at 9:49 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
  6. May 15, 2013 at 9:51 AM
    Large
    Large Red
    I'd actually like to see the whole truck, looks like you trimmed quite a bit from your fenders already.
  7. May 15, 2013 at 9:57 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I still think youll need a body lift or lt to clear, im not sure even tubbing would eliminate rub as youll run into clearance issues with your pedals if you go too far. I managed that with just a sledge. Cool though, nice work. I have mine ground to the body mount, like into it, it clears 35s but wouldnt 37s i think. But like i said i think now youll rub the wheel well real hard. Youll have to tub the top too.
  8. May 15, 2013 at 10:36 AM
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Yes I have more pictures of the install, and will post when I get them uploaded. I really need to start a build thread soon. The mount on the frame was rebuilt and moved back. We are still using the original mounting point on the body, just added another point of contact. I really believe its stronger and more stable now than before. We also opened up the body at that point to see how and what might be effected. Ill post those soon too.
    Maxamillion2324
    I do have a 2" body lift just no puck in the relocation because I moved it up and eliminated it. My fear is your right, but Im crossing my fingers. Rubbing is wheeling right? Going to the tire shop today or tomorrow to see what fits. Ill post pics of that too
  9. May 15, 2013 at 10:46 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Subd for a possible "cure" referrence
  10. May 15, 2013 at 11:00 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Sweet and original....lets call it the "Haws body mount" mod....:)
  11. May 15, 2013 at 11:00 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I like the idea, can't wait for more pics!!!
  12. May 15, 2013 at 2:43 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Right on, I don't think you'll have any issues with body or mount or none of that. You'll get all the rubbing figured out too I'm sure. It's obvious you have the skills and will!
    Look forward to more!
  13. May 15, 2013 at 3:01 PM
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    385/75/16.... I think that it measures out to 38x15.50x16 Toyo MT which is not what Ill run! I think Ill play it safe and run a 36" Irok.
    Jckdnls and Crom like this.
  14. May 15, 2013 at 3:04 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '24 F-150
    DO IT.. Awesome idea with the reloaction
  15. May 15, 2013 at 3:12 PM
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    So is it the inside the cab you want pictures of?
    Heres some more of what I have of the relocation mod. Just what I started with and where and what I did. Of course you don't have to cut. I think I got more than I would have with a Hammer. It will give you an idea of whats behind there.
  16. May 15, 2013 at 3:24 PM
    Oowen
    Owen
    Reno, NV
    '24 F-150
    What are you running for gears?
  17. May 15, 2013 at 3:26 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    here's a question, how would y our location affect people with sliders welded to teh fram already?
  18. May 15, 2013 at 3:33 PM
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    Sub'd for big tires with minimal lift..
  19. May 15, 2013 at 3:37 PM
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    I have a set of sliders on the shop floor now, but waited to put them on after I did this mod. Its about 4" further back on your frame. I would guess if this interfered with your slider mount that you would need to cut and move just that leg back.
  20. May 15, 2013 at 3:41 PM
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    I haven't geared yet. I wanted to see just what I could fit first. Kinda thinking 4:88's?
