2000lbs of river rock in bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AFZ, May 30, 2013.
  1. May 30, 2013 at 9:48 AM
    AFZ
    AFZ [OP] Well-Known Member
    IN
    4x4 AC 4.0 TRD OR
    Payload is 1650, but am I really going to hurt anything on a 5 miledrive if I pick up 2000lb of river rocks?
    Bed won't crack or anything, right?
    V6 AC 4x4 w/ TRD OR
  2. May 30, 2013 at 9:49 AM
    miacevedo
    miacevedo Well-Known Member
    SoCal
    SuperWhite 4X4
    All Pro Hybrid front bumper. All Pro rock sliders. Warn Winch. Icon 2.5 Remote Resi Coilovers & Rear Icon 2.0 Extended Remote Resi's. AP Standard leafs. Rear SuperBumps. OEM bed mat and All Weather floor mats. Pelfreybilt IFS Skid. Method NV wheels on 285/75/16 Toyo Open Country AT2.
    Nah, go for it.
    dand likes this.
  3. May 30, 2013 at 9:51 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    If you are worried about your truck and it's that short of a trip, why not make two trips?
    Sugar Silva likes this.
  4. May 30, 2013 at 9:52 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Just do it!!
  5. May 30, 2013 at 9:53 AM
    TacoTT520
    TacoTT520 Active Member
    Tommy
    Fort Hood, TX
    2010 DCSB TRD OR 4x4
    Full OME w/ 885's, LR UCA's, Wheelers superbumps (front), All Pro U-Bolt Flip Kit with Poly bumpstops, SS Extended Rear Brake Lines, All Pro rock sliders, 255/85/16 KM2's on stock TRD rims
    if its only 5 miles why not just make 2 trips and for each one you'll be way under the max payload instead of 400lb over. i can see where your coming from that it should be ok but for 10 more min of your time why risk it.
  6. May 30, 2013 at 9:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, I wouldn't put 2,000 lbs in the bed of the Tacoma. I know people have done it and gotten away with it but for such a short trip, make 2 trips. Even at 1,000 lbs, I promise that you'll be sitting squarely on the bump stops thanks to Toyota's laughable excuse for leaf springs.
  7. May 30, 2013 at 9:54 AM
    KevbekTacoma
    KevbekTacoma To Be Continued...........
    Kev
    SoCal
    '12, 4X4, DCSB, MT
    KING 2.5 RR (Front/Rear), TC UCA, DAKARS, MTR W/ KEVLAR, SCS SR8, TUBE BUMPERS, SLIDERS, MF CAT BACK, LIGHTS.
    Do it dude. Your truck is only gna run slower
  8. May 30, 2013 at 9:54 AM
    JRod4928
    JRod4928 Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    doubt the bed will crack since the load will be distributed thoughout the bed....my concern is the rear suspension.
    2 trips IMO - or go really slow. It's not the static load that will kill your truck - it's the sudden hit of potholes, speed bumps, or body-roll when turning too hard/fast.
  9. May 30, 2013 at 10:01 AM
    linzy77
    linzy77 Does not suffer fools lightly
    Linzy
    Dumbfukistan
    2013 Access V6 TRD Off Road
    X2 ^^
    Hope you have your TSB at least. If not schedule an appointment when you are done. lol :ballchain:
  10. May 30, 2013 at 10:02 AM
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    Can't, the load is measured by shovel (dozer) load. So, 1 scoop is 1.5 cubic meters which is 2,000lbs.
  11. May 30, 2013 at 10:05 AM
    Boone
    Boone, NC
    Airbags deployed
    Ahh. Then stick a sheet of 3/4" Plywood in the bed to help distribute the weight and to the bump stops you go. Let us know how it goes. Pics or it didn't happen.
    On second thought, how about a trailer? 1/2 on trailer, 1/2 in truck.
    SOSHeloPilot likes this.
  12. May 30, 2013 at 10:07 AM
    Pugga
    Massachusetts
    A 1.5 CM bucket will likely be longer than your truck's bed so you won't end up with the full load. Also, why couldn't the operator stop dumping mid load? It's not like it's not like you hit a button and it dumps, there is some operator control there.
    Alexely999 likes this.
  13. May 30, 2013 at 10:09 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    I had a pallet of fire stove pellets (2000lbs) in my 05 Tacoma for a short 10 mi trip, nothing happened but I wouldnt do it on a regular basis
  14. May 30, 2013 at 10:10 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    yes need pics or I lose faith in humanity once again :D
  15. May 30, 2013 at 10:13 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    It's not the load itself that would do damage to the bed. It's the dumping of said load into the bed that would cause any possible cracking.
    06Tacooo likes this.
  16. May 30, 2013 at 10:18 AM
    KevbekTacoma
    Kev
    SoCal
    '12, 4X4, DCSB, MT
    Valid point.
  17. May 30, 2013 at 10:42 AM
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    Called another guy, $2 more per ton but they will split the load. 2,600lbs for $45, smoking deal I guess.
  18. May 30, 2013 at 11:18 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Even with splitting, i'd still put a sheet of plywood in the bed to protect it from the dropping of the rocks
  19. May 30, 2013 at 11:32 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    that's true, plywood wouldnt be a bad idea. I bet the bed would hold up though - that composite material is tough stuff. If it was 0 degrees outside though - then it might shatter or crack, but no prob in the summer.
  20. May 30, 2013 at 11:40 AM
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    I had a bed full of soil in mine for a 10 mile trip. I did it twice actually. I don't know how much it weighed, but I do know that my truck didn't like it.
    Like others have said, don't make a habit of it!
