Major alignment problems.
Discussion in 'Wheels & Tires' started by sk8rjess, Jul 8, 2013.
  1. Jul 8, 2013 at 4:03 PM
    sk8rjess
    sk8rjess [OP] IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    Was just told by a shop they couldnt align my truck because my pass tierod was maxed out. A previous alignment shop maxed it out and because of that the steering wheel was turned but they had told me I can rotate it at the steering column. It didnt bother me so I didnt rotate anything.
    Now im eating through these front tires.. what the heck would cause this or can be done to fix it? Heres a pic of the numbers
  2. Jul 9, 2013 at 5:43 PM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    sooo no body has any input to this? really?
    i think it's all effed up from my coilovers being cranked to level out the front. that's the only thing that has been changed that would affect it.
    nothing is bent that i can tell.
  3. Jul 9, 2013 at 5:51 PM
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    The steering rack is not centered.
    Count the number of turns the steering wheel turns from center, left to right. They should be equal. If they are, something is bent.
  4. Jul 9, 2013 at 6:15 PM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    i'm not sure how the rack couldn't be centered. all the bolts are tight and there is no adjustment on the rack itself. but wouldn't everything being miss aligned throw that off anyway?
    turns right 2 times. turns left 1.5 times. but the driver pitman looks fine, and has plenty of thread left to adjust.
  5. Jul 9, 2013 at 6:20 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    sounds like a tierod ends need to be adjusted. turn the wheel to center and from there back off the passenger side and increase driver side to even them out. I think that's what an above poster meant. The rack is not centered between tie rod ends.
  6. Jul 10, 2013 at 6:13 AM
    gasgasman
    Girard
    Texas
    Exactly. With the different amount of turns from left to right, the rack is not centered.
    Someone pulled the steering wheel off and reinstalled it to be in the straight ahead position.
  7. Jul 10, 2013 at 6:49 AM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    ahhhh i gotcha. sweet, i'll do that tonight and post back. thanks guys
  8. Jul 29, 2013 at 7:15 PM
    gasgasman
    Girard
    Texas
    Any updates?
  9. Jul 29, 2013 at 7:31 PM
    GrayTacoma
    GrayTacoma Well-Known Member
    Andy
    Huntingtown, MD
    2011 TRD off road
    PIAA ion yellow fogs stay on all time,aux reverse lights, aux lights, camper with rack, cb, air bags, on board air, aux fuse box, aux batt, CAI, etc.............
    Get the upper control arms. Once you lifted the front of your truckr it changed the suspension geometry. Or you could have the alignment shop hollow out the holes where the upper control arm goes (the long bolt up top) that should bring the camber and caster closer to specs and then adjust the toe . Hope this helps.
  10. Jul 31, 2013 at 7:08 AM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    Heh i still haven't had time really to tackle this. I was hoping to do it this week.
    Andy, i'm doing my best to not have to spend money on IFS parts with a SAS in the near future.
    Back when i first had this issue i talked to my buddy who was the manager at an alignment shop for the last few years and he said the same thing that was repeated earlier - reset the tierods and try again
