2014 radio into 2012 USB issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MGMFire 711, Mar 4, 2014.
  1. Mar 4, 2014 at 9:12 AM
    MGMFire 711
    MGMFire 711 [OP] Member
    Gio
    South florida
    12 TRD sport
    So I just installed a 2014 entune radio with navigation and xm in my 2012. It seems like everything plugged up and no wires missing. Everything works perfect except for the USB connection. Is there any difference between the 2 plugs between both units? I don't see why it wouldn't work. The aux connector seems to work though.
  2. Mar 4, 2014 at 10:22 AM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    Subed..... I plan to do this swap myself and need all the info I can get.
  3. Mar 4, 2014 at 10:36 AM
    Tigmandick
    Tigmandick Member
    Richard
    G I
    2012 TRD Offroad m6
    You'll need this USB cable from eBay to make the USB connection work properly. Then follow these instructions to get it hooked up. I didn't bother with the input jack modification on those instructions, between the USB port and Bluetooth I don't think I'll ever need it. Also, that USB cable comes from China so it will take a while to get here. Mine took about two and half weeks.
    Credit goes to member yellowrubiu
    And on a side not does your xm still work?
  4. Mar 4, 2014 at 10:50 AM
    MGMFire 711
    Gio
    South florida
    12 TRD sport
    Yea I did get the xm to work. My 2012 already had xm and just needed the xm module and adapter cable which I received from FLtrucks and plugged right up. The link didn't work for me but I found the original post thanks. Did your 2012 already have the USB connector? I was wondering since everything plugged right in why it wouldn't work. The plugs seem to be the same. Can't there be a way to make it work without having to modify the cable?
  5. Mar 4, 2014 at 10:56 AM
    Tigmandick
    Tigmandick Member
    Richard
    G I
    2012 TRD Offroad m6
    I haven't receved my radio from fl yet did you ask for the xm adapter if so what was the part number .
    But my truck also came with xm and USB.
  6. Mar 4, 2014 at 11:07 AM
    MGMFire 711
    Gio
    South florida
    12 TRD sport
    Can't recall a part number on it. It was a loose cable that came in the box. I just asked for the xm and he included all the cables along with it. I do remember it was a long cable with one side similar to the gps connector, which went to the xm unit and the other side was a blue connector which I assume plugged into the shark fin connector which was also blue I believe.
  7. Mar 4, 2014 at 1:14 PM
    MGMFire 711
    Gio
    South florida
    12 TRD sport
    Tigmandick, do you remember where you plugged that into in the back of the radio to make the USB work?
  8. Mar 4, 2014 at 3:21 PM
    Tigmandick
    Tigmandick Member
    Richard
    G I
    2012 TRD Offroad m6
    I have no t received mine but that's the solution I have found sorry I am not more helpful.
  9. Mar 4, 2014 at 4:02 PM
    MGMFire 711
    Gio
    South florida
    12 TRD sport
    Been trying to search for differences in the connections between 2012's and 2013+ but no luck. If anyone can find it somewhere it would be helpful. I'm kinda picky about keeping the stock look and don't wanna lose the function of the stock usb connection
  10. Mar 5, 2014 at 1:10 PM
    Tigmandick
    Tigmandick Member
    Richard
    G I
    2012 TRD Offroad m6
  11. Mar 5, 2014 at 7:48 PM
    MGMFire 711
    Gio
    South florida
    12 TRD sport
    Thanks. That makes sense. But you think maybe there's a way to maybe find the cable similar to the 2013+ ones and just plug it into the back? Or you think it's more complicated than that?
  12. Mar 5, 2014 at 7:57 PM
    Tigmandick
    Tigmandick Member
    Richard
    G I
    2012 TRD Offroad m6
    I am gonna do some continuity tests see if it just needs repined to somewhere in the harness but unfortunately I won't be able to do that till about the 20th as I will be out of the country till then can't wait to get my hands on it.
  13. Mar 5, 2014 at 8:57 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
  14. Mar 6, 2014 at 8:21 PM
    MGMFire 711
    Gio
    South florida
    12 TRD sport
    Whenever you figure it out post it up please.
  15. Oct 17, 2014 at 5:22 PM
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    Any updates?
  16. Oct 17, 2014 at 5:37 PM
    JHSwafford
    JHSwafford Member
    Justin
    Charlotte, NC
    2012 Nautical Blue DCSB TRD OR
    Bilstein 5100s Front and Rear, Front set at 1.75" Icon 1.5" Progressive AAL 17x9 KMC XD Addicts LT265/70/17 TerraGrapplers OEM Skid Plate OEM Roof Rack OEM Bed Mat Rocky Mounts Locking Bike Carriers Debadged 2014 Entune Audio Plus Navigation Head Unit 5000K HIDS 30" AVEC Spot/Flood combo light bar Weathertech Mats Husky Mud Flaps
    I had this same issue when I installed my 2014 nav unit into my 2012. I would say I am atleast moderately educated on electronics and circuitry as well as audio but could not figure out how to make the 2 adapters work that FLTrucks said we would need to keep the USB function. The reason is that the factory wiring for the USB port is in an unlikely location.
    After reading multiple threads, I finally tracked down a member that had successfully used the 2 adapters that FLTrucks said were needed. I PM'ed him and we exchanged a few messages and he was nice enought to snap this picture for me.
    Credit for this picture goes to warriors_03
    This is located BEHIND the glove box. If you notice on the right hand side of the picture that black canister is actually the "shock" for the glove box that keeps it from falling open.
    The adapter with the female brown end hooks into the brown male end that is plugged into the multimedia unit behind the glove box.
    The blue adapter (if i remember the color correctly) plugs into the back of the head unit.
    You will need about a 2-3 foot MALE to FEMALE USB cable to extend the 2 adapters and connect them together. I ordered 1 off Amazon for around $5. May be able to find 1 at Best Buy but I do know these are a lot less common than your average male to male USB cable.
    wagerhope likes this.
  17. Oct 17, 2014 at 7:16 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    Bingo! I just found that thread and figured it out myself. Thanks for the reply!!!!!!
  18. Oct 17, 2014 at 7:44 PM
    ssilence
    ssilence Well-Known Member
    Middle Georgia
    2012 Tacoma Pre-Runner
    Pop and Lock
    Thanks for this info. Just so I follow. You unplugged the male brown connector from multimedia unit. Plugged this into the brown female adapter that goes to a standard USB plug. Run a male to female USB extension behind the radio and the plug into another adapter before going into the radio???
    Do we have part numbers for the 2 adapters?
  19. Oct 17, 2014 at 8:12 PM
    JHSwafford
    JHSwafford Member
    Justin
    Charlotte, NC
    That is correct. I can't remember part #'s for the adapters. I've had mine installed for about 6 months now with no issues and full functionality of all features as if it were equipped with the unit when purchased new. I know those adapters are called out specifically in fltrucks 2014 navigation unit thread.
  20. Oct 18, 2014 at 3:34 AM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
