Clunk/Pop from drivers floorboard
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Feb 4, 2015.
  1. Feb 4, 2015 at 7:01 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    This past weekend I hauled a load of wood from Sanford to Raleigh, let it sit in the truck for a week, and then Raleigh to Merchant's Millpond. When I was just about at my destination I started to hear and feel a clunk or pop in the floorboard under my left foot, like someone hit the floorboard with a hammer, when hitting some bumps. It is an intermittent sound as not all bumps make it happen. Even after unloading I still heard the noise occasionally.
    I've read a lot of posts with similar predicaments, sway bar end links, ball joints, rear shocks, loose battery, etc. Everything on my truck seems ok and I haven't heard it since I got back home.
    And the tale of the phantom noise will continue.
    The list to removing the noise:
    1. Visual inspection of front and rear suspension (shocks, ball joints, Control arm bolts, etc) - X
    2. Lift vehicle and test front suspension for worn parts (ball joints, hub bearing, etc) - X
    3. Re-torque body mounts (BensonX) - In Progress
    4. Replace LCA CAMS and bushings and retorque (LCA Cams are frozen) - In Progress
  2. Feb 4, 2015 at 7:50 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Were you driving in snow at the time?
  3. Feb 4, 2015 at 7:55 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Nope, clear and dry roads.
  4. Feb 4, 2015 at 7:56 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Well there goes my idea....:D
  5. Feb 4, 2015 at 8:22 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea that's my luck with all the ideas I've seen so far. I'm hoping to get more here.
  6. Feb 4, 2015 at 8:24 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Check your upper and lower CV bolts are tighted to spec and whether your bushings are worn.
  7. Feb 4, 2015 at 9:37 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    CV bolts?
  8. Feb 5, 2015 at 11:41 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Just took a hard/fast left turn (caught a yellow light) through a rippled intersection and heard/felt it pop a couple times. Dry road, no snow, truck unloaded.
  9. Feb 5, 2015 at 11:44 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Think he means upper and lower control arms?
    I know the lowers can cause a popping noise. Torquing these resolves it for some people.
    And what is your definition of checking the lower and upper ball joints?
  10. Feb 5, 2015 at 11:53 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Pretty standard thing to check. Similar to how he does it.
    How To Find Suspension Noises 101 - EricTheCarGuy: http://youtu.be/scFbb43fwqk
    I'm looking into replacing my lca bushings and bolts because they are seized.
  11. Feb 5, 2015 at 11:55 AM
    Large
    Large Red
    I had one I just solved yesterday night.
    It was the LCA cam bolt, jacked up front of truck and torqued all the alignment cam bolts to 100 ft lbs (155 ft lbs if you are 2wd) and it went away.
  12. Feb 5, 2015 at 12:01 PM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Good deal :thumbsup: Some people are visual checkers..
    If your lca bolts are seized maybe one of the bushings collapsed? But, I think if you were rocking the wheel in a vertical position you would feel it. Along with the ball joints, wheel bearing also. Really a good checking for everything..
  13. Feb 10, 2015 at 7:16 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    ^That. I had a moment there... :(
  14. Feb 10, 2015 at 7:48 AM
    jeremyk61
    jeremyk61 Well-Known Member
    My guess is ball joints. I had the same thing with the floor board pop. It was especially bad for a day or so after hauling a load. I greased the ball joints (you have to pierce the boot) and it went away. You can rock the truck back and forth and try to simulate it (have someone down underneath the truck listening); you get a good work out if it takes a few minutes of rocking to pin point it.
  15. Feb 10, 2015 at 7:55 AM
    ZXTwnT300
    ZXTwnT300 Member
    Shawn
    Birmingham,AL/Chapel Hill,NC
    2015 DCSB TRD OffRoad 6spd
    Hey Sandman,
    I just wanted to say hey and say that I am in the Chapel Hill area (when I am not back in Alabama). New to the taco owner world but I am loving it so far. Hope you get your noise figured out!!
    Shawn
  16. Feb 10, 2015 at 8:06 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    My lower control arm bolts had loosened recently too. Had to torque them up and my pop in drivers side went away. That's what I would check first.
  17. Feb 10, 2015 at 9:36 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I'll go about the lower ball joints after I get my lca cams replaced. One thing at a time.
  18. Feb 10, 2015 at 11:45 AM
    Chasemitchell
    Chasemitchell Well-Known Member
    Dalton ga
    2012 DCSB Sport 4X4
    bad strut, same thing happened to my 2012
  19. Feb 10, 2015 at 11:53 AM
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    How big are your tires. You may have just hit the fender liner or something like that.
  20. Feb 10, 2015 at 11:54 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Interesting..I forgot my 08' made the clunk when I first bought it. The pass front shock was blown. Hence the clunk
