JBA Offroad Upper Control Arms And Suspension MEGA Thread BS thread
Discussion in 'Suspension' started by tcBob, Feb 24, 2015.
  1. Feb 24, 2015 at 10:04 AM
    tcBob
    tcBob [OP] Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Update! :goingcrazy: For all you guys and gals with no lift/ minimal lift or just dont want as high of castor numbers marlin has release a stock replacement arm. It has all the same benifits of his standard UCAs IE More clearence at the spring stronger easily replacable balljoints and bushings. Just no added castor. Check out them here. He now is also a distibuter for Kings, Billstien, OME, Fox, and a few others. And most will agree his Customer Service is second to none. :cool:
    Explaining what you have:
    https://jbaoffroad.com/
    So a few months ago I hooked up with a guy local to me who has been in the industry for a long time who is looking to break out of the jeep world and start offering some parts for toyotas. The company JBA ( formerly Jeepin By Al) has been building jeep parts and adjustable coilovers and full suspention systems for all indepent suspension jeep since 2007. He himself has been welding and building parts for the industrial industry since 1987. The owner and myself have hooked up to try to bring some new products to our trucks that maybe solve some issues/price points out there now. He is currently in production of a set of uca's for our trucks designed for lifted trucks and I have to say so far I am impressed. Looking at some of the things people desired in these he has come up with a great product at a great price point. These allow for you to get your truck back into factory alinment after you lift your truck and I have to say my truck rides great now! No more bump steer or wandering around nice and straight and smoth now :D His uca have a replacable MOOG balljoint on top for easy maintnence and replacement is available through most auto parts stores. He is using toyota OEM bushing for the control arm they are very quiet riding. My alignment is now dead on with my camber at 0 on both sides and caster at 2.2 on the left and 2.1 on the right. As I test these out I will keep updating this thread I will say I gained 1.75 inches of downtravel now that my uca no longer hit the coils and if I had longer shock I would have a bit more. He is in the works for developing a host of other products as well so this is kind of a show an tell and see what you guys think. They are right in line with the LR UCA but have a replacable ball joint and these things are beefy:shock: They also have a lifetime warranty on the UCA and a 1 year on the balljoints. Any questions I would be more than happy to help and if I dont know the awnser I can get ahold of him and find out. Check out his web site and some pictures and I will keep updating but I am confident these will last a long time! Thanks for reading and let me know what you guys think I already got a few comments from the live thread and will pass anything on to him. These will be produced and available begining of march.
    Great summery of the thread from @DVexile :thumbsup:
    Long thread, been following it from the start. Sounds like the design has settled. I thought for newcomers I'd provide a thread summary - please correct me where I get things wrong and I'll edit this post. I'm going to throw out a few questions at the end and add the answers as hopefully people answer them!
    WHAT ARE THESE?
    Drop in replacements for the stock UCAs with the following features:
    • Use ball joints that are commonly available for replacement as needed in the future with zerks for easy maintenance
    • Ball joint angles and UCA hoop shape allow for more travel than stock UCAs thus appropriate for slightly greater shock travel in a "mid-travel" setup using the stock LCAs
    • Use the OEM bushings that are lower maintenance than fancier poly bushings used on many other aftermarket UCAs and are also unlikely to squeak
    • Shift the range of achievable caster compared to stock so that lifts in the 2-4" range can get caster around 2.5-3.0 (considered desireable range for stability) while keeping camber where you'd want to prevent tire wear
    Current options are for Standard or Heavy Duty design, the HD having larger tube size and some extra gussets. All current product is "High Caster" design (see development history for what legacy "low caster" would be).
    WHAT ARE THEY NOT?
    These UCAs are not "adjustable" like the Light Racing UCAs. Instead they are designed with a permanent offset compared to stock to end up where you'd likely adjust the LR UCA for a truck with a 2 to 4" lift. Other aftermarket UCAs do the same thing. The benefit to JBA/TC/Camburg fixed offset is there is nothing to slip and send things out of whack nor is there an unusual UCA adjustment that confuses barely literate alignment techs. The benefit to LR of course is you do have the adjustment and could run low caster at stock height or high caster lifted with the same UCA if for some reason that was important to you.
    They are not uniballs like Total Chaos or a variety of other "racing" UCAs but they do still offer a very wide joint angle range much like a uniball while being lower maintenance than a uniball. Similarly they don't use poly bushings that most of the "racing" UCAs use and instead stick with the OEM bushings. Poly bushings are unlikely to tear over lots of travel and should last the life of the truck but they require maintenance (greasing) and many of them squeak too. The OEM bushings the JBA arms use don't squeak and don't require routine maintenance but you may need to replace them after many tens of thousands of miles.
    DEVELOPMENT HISTORY AND PROBLEMS
    Much of the first 20 some pages of this thread deal with problems in the first released versions of the JBA UCAs. At the point of this writing these issues appear to all be resolved and all new purchased UCAs do not have these issues. People who were early adopters have had their UCAs replaced or in some cases need to request a replacement if they don't like their present caster numbers.
    The very first version of the JBA ended up having an interference problem on *some* trucks - but of course not on the trucks it was developed on. This resulted in bent UCAs and other suspension components for the unfortunate folks affected. The solution was to change the bend shape of the tubing to provide more clearance. The first version had a almost strait section with 45 angles at each end the second version changed this into a broader curve giving more clearance on the inside of the UCA. All purchasers of this version were contacted and their UCAs replaced with the fixed version.
    This new second version had no clearance issues but many people were not getting what they considered adequate caster on lifted trucks. To many the whole point to the aftermarket UCA was to improve caster on a lifted truck and the improvement over stock was not as much as hoped for. How much of this was variation and how much was just not enough angle in the initial design is not clear, but Marlin produced another version, the HC or "High Caster" version with more angle designed in. Everyone appears happy with this HC version.
    People who had the initial "low caster" version and we're happy with their alignment probably have no interested in changing UCAs again. But folks with that version who were unhappy can contact Martin to get the new "HC" version. For a brief period Marlin sold the remaining stock of the "LC" version at a discount at the same time the new "HC" version was being sold. At this time only the "HC" version is available. Again, there are standard and heavy duty versions of this same HC version.
    As a note, Marlin appeared to stand behind his product and produced many free replacements to those affected by the development problems. Naturally this was still a painful experience for those that had to swap UCAs multiple times.
    QUESTIONS (PLEASE ANSWER IF YOU KNOW)
    • Are the ball joint angles and clearances sufficient for the various "extended travel" coil overs out there meant for "mid-travel" designs and is anyone actually using such a configuration?
    • What are you "losing" by using OEM bushings vs. poly bushings?
    • What kind of off road driving would people consider the threshold for moving to the HD design? (obviously this is very speculative, but for example distinguish slow rock crawling, fast washboard, hard running over whoops and so forth)
    PLEASE PROVIDE CORRECTIONS FOR ANYTHING I'VE GOT WRONG!!!! I'm no expert, I'm just trying to summarize 30 pages of posts accurately to make sure I understand the product and trade offs and hopefully this will be helpful to future purchasers too.
    UPDATE: The new arms produce alost more caster and are designed to provide 3 degrees of castor for up to a 3 inch lift! All new arms going forward will be these high caster arms and the older ones are on markdown till they are gone! Thanks for your guys patience enjoy the new arms!
    My Truck with 3.25 inches of lift driver and 3.75 inches of lift passenger just to prove these work:cool:
    JBA Now offers adjustable Adjust-A-Strut designed to give 1.4 inches of front lift for the tacomas with adjustments for compression and rebound built into the shocks. Also offering his Total Control rear shock that adds inch of downtravel over 5100's and adjustable valving built into the rear shocks as well. Armor and more to come as he expands his Toyota lineup!
  2. Feb 24, 2015 at 10:08 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Possibly a better alternative to Light racing UCAs from the looks of them. Doesn't say what they're made of though.
  3. Feb 24, 2015 at 10:11 AM
    Shwig
    Shwig Well-Known Member
    Eric
    TN
    2014 Tacoma DCLB TRD sport.
    Eibach, bilstein 5100s front/rear, Toytec AAL, front window tint, BP fabricating front skid plate, TRD center caps, Avid light bar, Predator step bars, raptor grill mod, TRD pro wheels, Clazzio seat covers
    Can i be a tester?
  4. Feb 24, 2015 at 10:18 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    is he using an extended length balljoint? Moog part#?
    (Maverick) likes this.
  5. Feb 24, 2015 at 10:22 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Any plans for 1st gens in the future? Also, what are they made out of?
  6. Feb 24, 2015 at 10:25 AM
    Shwig
    Eric
    TN
    Do you know the caster/camber correction numbers?
  7. Feb 24, 2015 at 10:45 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Pretty sure he's asking the same question I was...
    Type of steel/tube. :cool:
  8. Feb 24, 2015 at 10:49 AM
    HiFire
    HiFire Well-Known Member
    Eric
    Hawaii
    SR5,4x4,DCSB,Auto
    Weathertech mats, BAMF sliders, US Offroad front winch bumper, RCI Alum. Skid plates, ICON suspension, Pelfreybilt rear bumper, JBA uca's, Allpro u-bolt flip,
  9. Feb 24, 2015 at 10:57 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Definitely interested! But dude stop hooking up with him :drunk:
    GusmanJE, Mack411 and Thuguon2.7 like this.
  10. Feb 24, 2015 at 1:36 PM
    Shwig
    Eric
    TN
    TW discount code?
  11. Feb 26, 2015 at 7:29 AM
    tacovinny
    tacovinny Well-Known Member
    Vince
    Bay area
    08 4x4 v6
  12. Feb 26, 2015 at 8:12 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Would like to see a good picture at full droop of the spring clearance this UCA provides.
  13. Feb 26, 2015 at 8:24 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Why the ugly red/orange color?
    Well IMO its ugly :eek:
    2X4TACOMA likes this.
  14. Feb 26, 2015 at 8:28 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Interesting
  15. Feb 26, 2015 at 8:35 AM
    Large
    Large Red
    Add a gusset to the bolt sleeves, LR UCA's often fail there
  16. Feb 26, 2015 at 8:35 AM
    HiFire
    Eric
    Hawaii
    SR5,4x4,DCSB,Auto
    How about gussets from the tube for the bushing to the perpendicular tube. Hope that's clear as mud. People have posted pics of control arms breaking at this joint that didn't have any gussets.
  17. Feb 26, 2015 at 8:37 AM
    Large
    Large Red
    Guess we had the same thought :p
  18. Feb 26, 2015 at 8:45 AM
    !TacoTaco!
    !TacoTaco! TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
  19. Feb 26, 2015 at 8:48 AM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    ^^This^^ Other than that, I think they look great. I like the idea of being able to find new ball joints easily.
  20. Feb 26, 2015 at 9:20 AM
    Poofyfoot
    Poofyfoot Well-Known Member
    Jordan
    Logan, Ohio
    89' Pickup and 2013 AC Sport
    :popcorn:
    These would looking mighty fine on my already black and red themed truck.
