SAS Quick Guide & Cost...
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 6, 2011.
  1. Apr 28, 2014 at 11:13 AM
    #181
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Yep, absolutely.
  2. Apr 28, 2014 at 9:28 PM
    #182
    Pinoiako916
    Pinoiako916 Well-Known Member
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    Cost of a total 3 link sas swap with coil overs on a 14' Tacoma
    How much will it cost to do a front and back sas swap with dana 60's 3 link with coil overs or ori struts, parts and labor? As well as putting in 37-40 inch tires? (all parts brand new)
  3. Apr 28, 2014 at 9:31 PM
    #183
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    you must ask in multiple threads?
    go join pirate 4x4. they will give you a better answer any way
  4. Apr 28, 2014 at 9:32 PM
    #184
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Probably the best advice ever given. lol
  5. Apr 29, 2014 at 5:25 AM
    #185
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Materials, $10k. Labor, $15-20k. Can be done cheaper, can be done more expensively.
    I do make a nice set of brackets specifically for your truck for a 3-link. PM for details.
  6. Apr 29, 2014 at 8:31 AM
    #186
    Stoffregen Motors
    Stoffregen Motors Active Member
    Cool, CA
    That's a pretty good quote, but I couldn't do it any cheaper than $30, unless the customer supplied the parts and they were used parts. You'll get $6K into the front axle alone without blinking an eye.
  7. Apr 30, 2014 at 4:54 PM
    #187
    Pinoiako916
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    Looking back, my budget for both buying the Tacoma and doing a 3 link (parts and shop labor included) is around $40k-$42k total.
    Would I be better off getting a first gen tacoma to make this 3 link mod fit within my budget?
  8. May 1, 2014 at 4:20 AM
    #188
    Supra TT
    Eric
    Indiana
    You're better off getting an old school toyota made in 1985... Already has a SFA, you could convert it to links for around $6k if you want... and about $4k for the truck or way cheaper depending where you are located.
  9. May 1, 2014 at 9:01 AM
    #189
    Stoffregen Motors
    Cool, CA
    I just built a 2001 4Runner for a customer with a 3 link in the front and leafs out back. It was a 3.4L/Auto truck to begin twith and it had the electronic case and ABS. It was a $30K+ build. So no, building an older Tacoma is not necessarily going to be cheaper. Areas where you could save money: buy a truck without ABS, a manual shift t-case, and use a junkyard D60 for the front.
    The problem with the older (1985) trucks is that they have no power. The 2005+ 1GR-FE 4.0L has V8-like HP, so comparing the two is really not fair.
    bcbd10b5-12bd-425e-b28f-f694d56c7dbb_zps_cc293d860bf5b6a55df163d29d144e8917de8d5a.jpg
    Jerry_Schroeder_Final_Small_006_zpsa9723_e1b74972b2b3f980cb3f2786431ff0710b3e2716.jpg
    98rock runner, smw62891 and eimkeith like this.
  10. Jun 11, 2014 at 12:47 PM
    #190
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    Yes possible, but why do the SAS with no gearing options? It could always be added at a later date I suppose.
  11. Jun 11, 2014 at 12:51 PM
    #191
    Boomtacoma01
    Houston
    Hell I have at least 15K in my 85. Thats the cost of new parts and outsourcing when you dont have the tools or facilities when you start a build. Luckily I do now. It all adds up quick. It will be more after I start linking it.
  12. Jun 12, 2014 at 8:47 AM
    #192
    Stoffregen Motors
    Cool, CA
    I keep thinking it may actually be cheaper to start with a 2wd or PreRunner. Less to remove, less wiring, less flashing lights on the dash to deal with. Of course you'd have to buy another adapter or a different transmission...
  13. Jun 12, 2014 at 2:14 PM
    #193
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    My truck started life as a prerunner. Can't say it was easier to deal with but it didn't have ABS which was a plus. Once 4wd swapped, I chose to put a J-shift t-case in and trans from a 4wd 4runner. Now that its axle swapped, I'm glad it doesn't have ABS :cool:
  14. Sep 12, 2014 at 7:24 AM
    #194
    Supra TT
    Eric
    Indiana
    Well I have plenty more $ in my 1st gen than your 85. So my statement still stands. Besides if you run toyota axles on the older trucks you can make it pretty bad ass for $10k... It's $10k just to swap to a SFA on a tacoma.
    So if it already has a j-shift case with 4wd and no ABS... you saying that's the ultimate truck to swap?
  15. Sep 13, 2014 at 8:47 AM
    #195
    Stoffregen Motors
    Cool, CA
    Yep. If not more.
  16. Mar 26, 2015 at 3:16 PM
    #196
    Boomtacoma01
    Houston
    That 14K includes the 4K purchase price. I should have clarified that in my previous post. Going way up now since I'm swapping in a set of tons.
  17. Mar 26, 2015 at 3:58 PM
    #197
    Supra TT
    Eric
    Indiana
    All good. I just swapped in a 3-link front and that put me about another $2400 into the truck. Pushing $30k here soon and no that's not including truck price :luvya:
  18. Mar 26, 2015 at 4:42 PM
    #198
    bullcrew
    bullcrew Well-Known Member
    travis
    oceanside
    03 quad cab sas
    Lol it gets pricey ...faster than you'd think....
    Don't know what I'm into mine but I know its was $13k before a lot of other stuff.....and that's parts only.
  19. Mar 26, 2015 at 5:03 PM
    #199
    Supra TT
    Eric
    Indiana
    I've basically included every single part, shipping, replacement parts, labor from others, tranny rebuild, IFS build, bumpers... EVERYTHING In the price. So that's where my cost is from. It'd be much lower if it was just the SAS and I didn't break 500 thousand parts in 5 years.
  20. Mar 26, 2015 at 7:22 PM
    #200
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    I like to keep my head buried in the sand, much less painful...
    It's only money, you can't take it with you.
    GH
