Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Dec 16, 2013 at 7:25 AM
    #2961
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Spartan up front, no ARB. If you can't turn it it's bc it has a load on it. One hand on the tire to rock it a tad, and it turns like butta.
    Get the brass KP bushings from C & M...$70 :spy:
    I just LOVE the Chassis Unlimited Arms...actually had the guy these knuckles are for order them and return his ballsacktic ones. I am doing the double shear setup on these just like mine as well.
    And does the carpet match the drapes :D
  2. Dec 16, 2013 at 7:50 AM
    #2962
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    This ^ mine turn very easy unless there is load on them. The key is to pack the hell out of them with grease.
  3. Dec 16, 2013 at 8:51 AM
    #2963
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    :pout: i dont even have hubs yet....
  4. Dec 16, 2013 at 9:02 AM
    #2964
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    C&M Brass KP bushings are now $95 through their site :confused: I really dig the Chassis Unlimited arms! They are local to me so I went down and picked them up. The guy who runs it went to my high school, good dude.
  5. Dec 16, 2013 at 9:11 AM
    #2965
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Price may have went up but that's still over $50 cheaper than from Solid. Just be sure to drill and tap a few holes in the top surface to make them easier to remove. That's the only difference between the two brands...
  6. Dec 16, 2013 at 9:38 AM
    #2966
    thegame
    Brian
    Folsom, CA
    Yeah Reids are about the same as Solids I guess. I'll have to order C&M's soon :D
    Just got a call from ECGS, I guess someone else ordered the used set of Yukon hubs about 5 hours before me. So I'm getting brand new ones for $300 :) Good enough!
  7. Dec 16, 2013 at 4:12 PM
    #2967
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  8. Dec 16, 2013 at 4:13 PM
    #2968
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  9. Dec 16, 2013 at 7:10 PM
    #2969
    thegame
    Brian
    Folsom, CA
  10. Dec 17, 2013 at 5:38 AM
    #2970
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
  11. Dec 19, 2013 at 9:22 AM
    #2971
    thegame
    Brian
    Folsom, CA
    Hey, on your truck, in order to keep a straight panhard, did it have to be pretty far off center (towards the front of the truck) on the axle to clear at full bump? I'm curious because if I have to run my panhard that far off center, I might need to get a double hole hi-steer arm for the driver side so I have room to move the panhard forward. I'm trying to avoid messing with bending a panhard is all :)
  12. Dec 19, 2013 at 9:24 AM
    #2972
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    I used a double hole for both arms :eek:
  13. Dec 19, 2013 at 9:32 AM
    #2973
    thegame
    Brian
    Folsom, CA
    I know. Did you ever mock it up with the tie rod in the closer/shorter position?
  14. Dec 19, 2013 at 9:33 AM
    #2974
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    No bc it wasn't even a possibility with my ballistic cover.
  15. Dec 19, 2013 at 9:34 AM
    #2975
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    It's a tight fit, but everything clears lock to lock.
  16. Dec 19, 2013 at 9:41 AM
    #2976
    JLee
    Jerry
    Benicia, CA
    Looking good now you have 5 months to get it rolling so you Mark & Eric can roll out to MOAB :p
  17. Dec 19, 2013 at 9:49 AM
    #2977
    thegame
    Brian
    Folsom, CA
    Yeah but with the tie rod in a higher location, you might have cleared the diff cover, maybe? I know -Matt- on Pirate runs Ballistic arms and the dimensions are pretty similar to Chassis Unlimited arms but his tie rod is in the closer location. He did have to build a bent panhard though... All fingers point to swapping this single hole hi-steer arm for a double I guess :rolleyes:
  18. Dec 19, 2013 at 9:51 AM
    #2978
    thegame
    Brian
    Folsom, CA
    What's up with the polished tie rod and drag link? Bling bling yo! Looks great! I can't wait to start cutting :cool:
  19. Dec 19, 2013 at 10:22 AM
    #2979
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Polished? That's the way it came. :p
    I'm half tempted to just go with 37"s... ~$140 less per tire.
  20. Dec 19, 2013 at 10:25 AM
    #2980
    JLee
    Jerry
    Benicia, CA
    I thought you bought your tires already? :confused:
