Solid Axle Swap BS Thread
Discussion in 'Solid Axle Suspension' started by Supra TT, Feb 20, 2012.
  1. Oct 10, 2014 at 11:48 AM
    #4201
    BradyT88
    BradyT88 Well-Known Member
    Look at Rocky. He destroyed 2 ring and pinion sets in Moab running his 38's on Toy axles. They were both the rear interestingly enough. On the front he broke both hubs which is probably what saved the ring and pinion.
  2. Oct 10, 2014 at 11:52 AM
    #4202
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    his second set got destroyed because of a poor set up. I told him it wasn't right when we put it together but he didn't give a damn.
  3. Oct 10, 2014 at 12:35 PM
    #4203
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Good to know :thumbsup:
    Lol I set up my 5.29's. I was pretty pleased with how it came out, I just hope it lasts. First time I'd ever set up gears..
  4. Oct 10, 2014 at 12:38 PM
    #4204
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I pulled my rear v6 3rd out to replace a tweaked diff stud and found a chipped pinion gear and a twisted Trail Gear chromo axle on the drivers side. I'll be going to a junkyard 14 bolt soon with a shave kit. The 5vze swap , 39.5" Krawlers and a twin stick is just too much for a toy axle
  5. Oct 10, 2014 at 12:42 PM
    #4205
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    How's your front holding up? I'm assuming it's fully built? Only thing left to do up front for me is arp knuckle studs and trunion eliminators.
  6. Oct 10, 2014 at 12:53 PM
    #4206
    MonkeyProof
    SoCal- SGV
    the front so far is great...so far.
    i installed OG 30 spline Longfields, ARP studs, OG Longfield chromo inner hub gears, TrailSafe Knuckle Wiper Set which is pretty nice and the trunion bearing eliminator kit which is also pretty badass. only issue Ive had so far is a driverside outer hub gear and found that when i tore everything a part to install the Trail safe Wiper Kit. we'll see how it will all hold up after i install my hydro assist :cookiemonster:
  7. Oct 10, 2014 at 1:01 PM
    #4207
    rctoy
    konstantenos
    Pocatello Idaho
    Just curious by why are you going with a 14 bolt and not the dana 60 like everyone else does. i still have the 35 spline rear that came with my front 60 i went 14 bolt because i wanted it to be stronger and cheaper.
    hydro assist will help save your gear box from getting ripped of the frame with big tires. Just ask rocktoy about that one.
  8. Oct 10, 2014 at 1:03 PM
    #4208
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Yeah I have TG 30 splines, chromo inners and outers, arp hub studs, TG rock rings and wipers, truss, and knuckle studs. Did you leave the stock outer hub gear as a failsafe? Mine's still a relatively new build so I don't have too many runs on it but I haven't been gentle.
    What are your plans for hydro assist? I have recently started looking into that too.
  9. Oct 10, 2014 at 1:20 PM
    #4209
    MonkeyProof
    SoCal- SGV
    i didnt intend to leave em on as a fail safe, but now that you mentioned it lmao
    im following the writeups at marlincrawler forums to build a DIY hydro assist on the cheap. so far i spent less then 70 bucks on new hoses and fittings and on a used SurplusCenter ram. i also have a massive trans cooler from an F450 that ill be using as a power steering fluid cooler :cookiemonster:
    check out these two threads on how to do the hydro assist on the cheap
    http://board.marlincrawler.com/index.php?topic=4699.0
    http://board.marlincrawler.com/index.php?topic=10579.0
  10. Oct 10, 2014 at 1:36 PM
    #4210
    MonkeyProof
    SoCal- SGV
    14 bolts are stronger then a D60 and a lot cheaper to build the a D60. easier to setup and the pinion support bearing thingy is pretty slick. and with with a shave kit i can still have the same clearance as a toy axle. i'll be going with a D60 in the front.
    http://www.pirate4x4.com/tech/billavista/14b_bible/index.html
    like this?
  11. Oct 10, 2014 at 1:42 PM
    #4211
    rctoy
    konstantenos
    Pocatello Idaho
    yup nailed it ^^^^..
    yeah all the same reason's i went with a 14 bolt even though i have a 35 spline 60.
    though i am not shaving mine i want every bit of tooth on that thing. i trimmed the housing and that put me at just a half inch less clearance than my dana 60. im ok with that.
  12. Oct 10, 2014 at 1:45 PM
    #4212
    MonkeyProof
    SoCal- SGV
    the teeth on the ring doesnt get touched when the ring is milled down, not even close. i think they're only taking less then 3/8 of the outside ring itself.
  13. Oct 10, 2014 at 1:50 PM
    #4213
    rctoy
    konstantenos
    Pocatello Idaho
    I know that i wasn't saying it cuz it makes them stronger i was saying it cuz i don't want to dick with a shave kit. i mean if i want to later i still can do that but for now im not worried about it.
  14. Oct 10, 2014 at 1:51 PM
    #4214
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    I think its only like 1/4 of the ring gear that gets taken off. Tmr also has a shave kit that doesnt require the ring gear to be turned down. 5/16th's of an inch less clearance then the ballistic shave kit.
  15. Oct 10, 2014 at 1:58 PM
    #4215
    rctoy
    konstantenos
    Pocatello Idaho
    like i said im only 1/2 and inch lower than the dana 60 and all i did was trim the housing down to the sealing surface of the cover. if i get hung up on it enough to bother me ill shave it with the ballistic kit. I don't know if you guys have picked up on this at all but i really do love working on my truck and designing as much as i can on my own. that's why with out even hitting trails yet im changing to a 4 link..
  16. Oct 10, 2014 at 9:17 PM
    #4216
    92LandCruiser
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I bought a surplus center ram and a seal kit for my 80 box, I've got to be in it around 130$, built my own lines -- free and everything else I sourced for free.
  17. Oct 10, 2014 at 9:30 PM
    #4217
    MonkeyProof
    SoCal- SGV
    That's what I'm talking about...awesome!
    I'm assuming that you're using a modified stock steering pump..did you have any issues with it?
  18. Oct 11, 2014 at 9:46 PM
    #4218
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Just stock cummins saginaw pump. I haven't actually driven with it but it turns 40s at idle sitting on pavement just fine. I need to drive it to see if I need to mod the pump but I've got a few things left to finish before it's ready to roll.
  19. Oct 12, 2014 at 6:19 PM
    #4219
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    So I had to thread my top seat on my 14" 2.5 coilovers down like almost 3" to take up all the slack out of the springs at full droop. Otherwise the springs were banging around.
    Now it sits like 3" too tall. Fuck man. Is that normal. 16 and a 14" spring.
    Gotta run a lighter spring rate I guess, it's stiff as fuck anyway.
  20. Oct 13, 2014 at 5:54 AM
    #4220
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Yup way too much spring. You want at least an inch or two preload on the springs with the coilover fully extended. Good thing is since you have springs on there now, you can take a couple measurements ad figure out what you need really quick. Shoot me a PM if you want some help.
