Scuba's 99 Single Cab SAS.. 5 Years in the Making
Discussion in 'Solid Axle Suspension' started by TherealScuba, Mar 12, 2014.
  1. May 11, 2014 at 12:26 AM
    #81
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    k thats what i figured. i know ive seen some factory jeeps with some stupid angles...but do you really anticipate it settling enough to push it back 45 degrees? I guess i dont know how the springs act. If anything you could set it and just modify/get new shackles when they settle. I would almost move it forward a half an inch so it at least sits close then hope it settles an inch
  2. May 11, 2014 at 1:04 AM
    #82
    TherealScuba
    TherealScuba [OP] Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    With the shackle hanger where it's at, I'll never have a 45* angle at ride height.
    I moved it forward 3/4" and got the shackle to sit at 85*.
    I believe after some settling I'll have around 60*. Won't be perfect but won't be horrible.
  3. May 11, 2014 at 1:08 AM
    #83
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    85 is still pretty high lol. But you're right it will be hard to tell before the springs settle.
    With a longer shackle you can make the angle Steeper, so you could always set it about where you want it and if it's not right get a longer shackle
  4. May 11, 2014 at 7:16 AM
    #84
    awsumdc
    awsumdc Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    Wow!!!.. 25-1/4" on what, 35's??
    Link that bitch and get it to 24-1/2" on 40's.
    But good to see your moving along at a good clip though.
    Pirhett likes this.
  5. May 11, 2014 at 9:06 AM
    #85
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Steering box is mounted, just gotta finish welding the brackets.
    Also, Wyatt, that's before settling.
  6. May 11, 2014 at 9:18 AM
    #86
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Awesome build man can't wait to see more! :thumbsup:
  7. May 11, 2014 at 11:10 PM
    #87
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    The front is "done." I still need to put the inner shafts/ birfs in, weld the steering stops on, and a couple other small things. I drove it out of the shop and got it up to about 50. I've gotta get the toe set a little better but everything is working pretty well.
    I was hoping to get the center of the axle about 3" forward of stock. I measured everything and the axle ended up 7" forward. I've got a 111.5" wheelbase with an 80* approach angle. :O
    Working on the rear suspension right now. The truck should be 95% by tomorrow evening.
  8. May 11, 2014 at 11:19 PM
    #88
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  9. May 12, 2014 at 5:37 AM
    #89
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Your on your way.....:D
  10. May 12, 2014 at 12:23 PM
    #90
    Dwill817
    Dwill817 Well-Known Member
    Drew
    Alabama
    1981 Toyota Pickup 4x4
    Man.. That thing is freakin awesome! Keep it up Scuba and when your done bring it back out to Alabama so we can test it out!
  11. May 12, 2014 at 1:10 PM
    #91
    mustangstephen
    mustangstephen raise hell, drink beer
    Stephen
    by da creek
    02 Tacoma TRD
    Homebrew bumpers and sliders, 5100s & Eibachs up front and mutt leaf pack out back, 285s & Wheelers type B, sway bar deleted. Wife's ride: 01 4Runner 4wd sport. Stock with exception of TRD taco coils, and shift kit.
  12. May 12, 2014 at 2:22 PM
    #92
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    37s and you'll be able to climb walls :eek:
    Looks awesome, congrats!
  13. May 12, 2014 at 2:32 PM
    #93
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Yup! Those slider boxes are awesome. Wish I knew about them for my old truck. You can play with truck heights by removing leafs to a certain extent or running the shortest shackle possible. My last Tacoma had the shackle under the frame and I got it to 24" to the frame on 37's by messing around with leaf combinations/shackle lengths.
  14. May 12, 2014 at 8:30 PM
    #94
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    It'll be fine. 25" frame height on brand new springs will settle to 23.5-24" at a minimum on true 35's ..and still wheel awesome with decent uptravel.
    Yeah links and exotic tricks with leafs are sexy to say you've got a low truck but that's not what he was after. It's a daily driver that will be out in the elements, bushings are a lot cheaper to replace than JJ's. Simple, reliable and semi-inexpensive was the name of the game and it was pulled off quite nicely I would say.
  15. May 12, 2014 at 9:09 PM
    #95
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I got to take the truck home from the shop tonight.
    It's slightly bouncy without shocks. Needs a steering stabilizer. Wanders a bit at speeds of 50 and over. Otherwise, everything is great. I need to triple check my toe which I thought I set at 3/16's in. I'll get some pictures tomorrow morning. I did the math and I was at the shop for a grand total of about 50 hours!
  16. May 12, 2014 at 9:15 PM
    #96
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I'm on axles that are almost full width. I'm on BRAND NEW springs. I expect at least an inch of sag. It's really not that tall. Low frame height isn't everything, btw. Besides, you have to realize my fenders have been cut 2" up so it LOOKS higher than is.
    Thanks, finally someone gets it.
  17. May 12, 2014 at 9:34 PM
    #97
    MonkeyProof
    SoCal- SGV
    You should head to SoCal and hit up the Hammers before it gets too hot!
  18. May 12, 2014 at 9:37 PM
    #98
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    That's a helluva weekend there.
    You considering throwing on a panhard with some sort of quick disconnect on one end so that you will have better highway manners when hooked up and then unhook it to wheel?
  19. May 13, 2014 at 6:29 AM
    #99
    mustangstephen
    Stephen
    by da creek
    02 Tacoma TRD
    I'll give it to you that I've never dealt with new springs and didn't realize how much fender trimming you've done. You're still doing more than me and I'm just a spectator who's opinion may or may not be worth the time it takes to read. :eek: Keep up the build. I'm sure it'll never be finished anyway.
  20. May 13, 2014 at 7:27 AM
    #100
    Dwill817
    Drew
    Alabama
    That sure is a confidence booster! :p
    It'll get finished Scuba. It'll get finished Scuba. It'll get finished Scuba. It'll get finished Scuba. It'll get finished Scuba. It'll get finished Scuba. It'll get finished Scuba. (repeat as much as necessary until your finished).
