Go Back   Tacoma World Forums > Tacoma Garage > Solid Axle Suspension
brake going to the floor
Old 08-01-2014, 04:23 AM   #1
ekahi1 [OP] ekahi1 is offline
CUZ I CAN
ekahi1 is on a distinguished road
Army: ARMT dawg Apache longbows, 101st ABN
ekahi1's Tacoma Gallery
Just replaced one caliper on my waggy 44 bleed all the lines pedal gets hard no air bubbles but as soon ad I start the truck pedal slowly goes to the floor. The truck does stop fine but soft pedal to the floor. Kept bleeding again no bubbles. Im lost on the pedal going to the floor still
Old 08-01-2014, 08:43 PM   #2
CUZ I CAN
ok so i thought maby my master was going bad. Since i was all ready dropping it the truck off at a shop i had them look at the brakes also. they said the master is good and bleed all the lines NO air, the tech said he thinks it could be my BPV ether out of adjustment or bad since the truck nose dives when braking. its like the rears are not braking. but how would this be affecting my pedal?
any ideas??
Old 08-01-2014, 11:22 PM   #4
CUZ I CAN
Thanks. I don't get how the bpv would cause the brake pedal to be soft
Old 08-03-2014, 09:26 AM   #5
CUZ I CAN
How can I check if the bpv is working. Also going to check the and adjust the rear drums. But im thinking it could be the master.
Old 08-03-2014, 11:32 AM   #6
icallhertaco11 is just really niceicallhertaco11 is just really niceicallhertaco11 is just really niceicallhertaco11 is just really nice
icallhertaco11's Tacoma Gallery
Cmon guys help him out! I'm sorry I don't know anything about this but I'll try to help with the bumps so you can get some.
Old 08-03-2014, 04:17 PM   #7
Heaton830 is on a distinguished road
Heaton830's Tacoma Gallery
I have the EXACT same thing going on. gunna try to re-bleed all the lines tomorrow just to see if that does anything but help on this would be great!
Ekahi- I'll let ya know if I figure anything out
Old 08-03-2014, 07:58 PM   #9
CUZ I CAN
So I re bleed every thing again completely no bubbles. With the truck off pedal gets hard and holds solid. But with the truck running there's some pressure but pedal still goes to the floor slowly. Thinking maby master or the rears some how need to be adjusted.
Also when I use the pumping the pedal method no bubbles at all. But if I use my hand pump im geting bubbles.its not leaking past the hose cuz when I close th bleeder no bubbles. Its like airs leaking past the bleed nut from the suction.
Old 08-03-2014, 08:03 PM   #10
CUZ I CAN
Never had a problem bleeding brakes its driving me crazy. Fyi the truck doesn't have abs. Didn't know there was a slave cylinder on the brakes. Your might be thinking of the clutch slave. Might try adjusting the rear drums.
Brake pedal goes to floor after turninng left?? jah8551 2nd Gen. Tacomas 9 10-21-2013 10:17 PM
brake pedal goes to the floor golstho 2nd Gen. Tacomas 34 07-15-2012 09:19 AM
SOCAL: bnob TC UCA'S, non jbl stock radio, side steps, stock brake lines, floor mats. lepedog23 Buy / Sell / Trade 11 12-18-2010 04:11 PM
Brake Pedal Goes to Floor When Starting Up Biocal Technical Chat 5 01-31-2010 10:22 AM
brake pedal bout went to the floor! devilsalmostfree 1st Gen. Tacomas 5 06-21-2009 05:13 AM
