Scuba's 99 Single Cab SAS.. 5 Years in the Making
Discussion in 'Solid Axle Suspension' started by TherealScuba, Mar 12, 2014.
  1. Mar 12, 2014 at 10:19 PM
    TherealScuba
    TherealScuba [OP] Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I've only got another month or so until I'll have most all of my parts in/ on the way. Figured I'd start this thread now.
    This thread will include parts lists, plans, pictures, beer, and I hope constructive criticism from everyone.
    This will be my first time with such an epic fab project on my own vehicle although I have helped out with a couple solid axle swaps.
    Cutting will not start until I have every part I will need to drive the truck safely. I will most likely be borrowing another TTORA member's garage, another members 220 welder, and hopefully a plasma.
    Goals for this SAS: get rid of the death trap IFS. Make a more reliable front end. Allow me to wheel more than I wrench.
    I want to push the front axle forward as far as possible. I want a better approach angle, I want the tires out of the firewall, and I want to stretch my short wheelbase a little bit.
    I am going leaf springs. I don't need a crap ton of flex. I want the strength of a high pinion 8" diff with chromoly everything.
    Parts list:
    Front: Diamond Axle, 8" High pinion (Marlin built, 5.29's, Yukon grizzly locker). 67" WMS w/ IFS hubs. FROR Tacoma brake mount. RCV inner shafts. TG "longfield" birfs.
    Marlin 25MM steering arms. FROR DOM Tie rod/ drag link. All-Pro FJ80 TRE's. Ford bronco forward swing steering box. Parts mike flat pitman arm. PSC 2.7L tacoma pump kit (I have found redline steering fluid that satisfies the needs of both the stock pump and the gear box. The PSC pump kit won't be needed). TG Steering shaft kit.
    FROR SAS kit, All-pro 4" springs. Bilstein 12" 5125's. All-Pro frame plates.
    T100 oil pan, pickup, and all that jazz.
    Rear: T100/ Tyndra axle. Will transplant my 8.4 welded 5.29 diff into it.
    All-pro 5" rear suspension kit. 12" bilsteins.
    The truck will probably be on 38's-40's next if I can grow some balls.
    That's the basic parts list, I'm sure I am missing some small things. Here are some pictures so far.
    Obligatory broken IFS pictures.
    Remaining parts:
    The IFS has taken me almost EVERYWHERE I've wanted. From Moab, to AZ, the Hammers, to the Rubicon, Windrock ORV, Hidden Falls, etc.. IFS has its purpose. It served me well for the past 5 years. However, it is time to take the truck to the next level.
    Stay tuned.
  2. Mar 12, 2014 at 10:24 PM
    AllMountainToy
    AllMountainToy Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    Nice! this is going to be good! Good luck
  3. Mar 12, 2014 at 10:28 PM
    Manwithoutaplan
    ID
  4. Mar 12, 2014 at 10:30 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  5. Mar 12, 2014 at 10:30 PM
    Manwithoutaplan
    ID
    Shouldn't you get rear axle to make sure you don't break anything since you are taking it to the next level? Jw
  6. Mar 12, 2014 at 11:00 PM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I'm not too concerned about the rear at the moment.
    The 8.4 is known to be "okay" on 37's/39's.
    I've got a friend with a very similar build who runs a stock Tundra rear axle with just an ARB and 5.29's. He's been wheeling on 39's for a couple years without issue.
    Later on down the line, I may add a full floating diamond axle rear with a Landcruiser 9.5 diff. That's a far way out though.
    Here's my buddy.
    Edit: here's another one. My truck will be a clone of his almost except for his front end is linked and I'll have leaf springs.
  7. Mar 12, 2014 at 11:05 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    reg cab :drool:
  8. Mar 12, 2014 at 11:08 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    going to be a rad build! cant wait to see you tear into it
  9. Mar 12, 2014 at 11:11 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    No hydro assist?
    I'm piecing together a kit for way way way cheaper then a TG or PSC kit using a topic or two from the marlincrawler Forums And Pirate4x4 for references
  10. Mar 12, 2014 at 11:16 PM
    MonkeyProof
    SoCal- SGV
    After going chromo shafts on the crawler I have never had problems with the rear..and that's with a dual tcase and a 5VZE swap on 39.5" Krawlers
  11. Mar 12, 2014 at 11:21 PM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I'm taking a page from AOR Scotty's "intervention" build. He used the ford box on that build and ran 37's or 39's without the need for assist. The ford box is so much larger than a Toyota box it just doesn't need it. Plus I'll have the high flow psc pump.
  12. Mar 12, 2014 at 11:22 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  13. Mar 12, 2014 at 11:26 PM
    MonkeyProof
    SoCal- SGV
    Ooohh..send me the link please. I haven't heard of that. I'm a tech at a Ford dealership and I know we have a few boxes laying around ...cha ching!!!!
  14. Mar 12, 2014 at 11:32 PM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
  15. Mar 12, 2014 at 11:34 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  16. Mar 13, 2014 at 9:13 AM
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    Sweet man. Keep us posted when the WAT and cutting are scheduled to start.
    Ditch the spreadsheet after you buy the parts so there are no reminders of the amount of $$$ that you sunk into your rig. I sunk way more into my 85 that I will ever divulge.
  17. Mar 13, 2014 at 9:23 AM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Should be sweet - although I think you had a CV trail swap down to about 5 minutes at Windrock.....
  18. Mar 13, 2014 at 10:01 AM
    Buy1Get1Freee
    Buy1Get1Freee HERP DERP
    PEI
    2001 Tacoma TRD
    Grey Wire Mod, Bilstein 5100s, Eibach Coils! 255/85/16 KM2. DDM HID 35W 6000K, Homemade Rear Bumper, Trail Gear Rock Sliders
    I love SAS'd Reg Cabs! :D
  19. Mar 13, 2014 at 12:03 PM
    LikeABoss4x4
    LikeABoss4x4 Well-Known Member Vendor
    Sarah
    So Cal
    Sub'd. Yay for Scuba! Are you doing one of your Scuba dances in anticipation!?! lol Good luck on the build. Can't wait to see it finished!
  20. Mar 13, 2014 at 12:08 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Subed, always like solid axle builds.
