Krans, BeeRadd, The Traveler and AMG4LIFE at Ocotillo Wells
Go Back   Tacoma World Forums > Regional Discussion > Regions > Southern California
When is a Differential Breather Mod Necessary?
Old 11-10-2011, 02:08 AM   #1
Olson [OP] Olson is offline
Olson will become famous soon enough
Olson's Avatar
Navy: Builder 3rd Class Petty Officer, Just transfered from Naval Mobile Construction Battalion 5 to 3
Olson's Tacoma Gallery
What are the chances of the water getting sucked up in the diff? I was going through trails online and want to hit up coyote trail and there is a part that is deep enough where differential is fully submerged for a decent distance.
Old 11-10-2011, 02:16 AM   #2
Hiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shed
Hiatt1991's Avatar
Hiatt1991's Tacoma Gallery
Send a message via MSN to Hiatt1991
If it gets past the stock diff even for a few seconds you are risking getting water in your diff. The mod inly costs less than $20
Old 11-10-2011, 02:49 AM   #4
Olson's Avatar
what is the best way to go about running it and where did you run it to? storage compartment?
Old 11-10-2011, 02:51 AM   #5
Street glide or die
yotamikez is one of the sharper tools in the shedyotamikez is one of the sharper tools in the shedyotamikez is one of the sharper tools in the shedyotamikez is one of the sharper tools in the shedyotamikez is one of the sharper tools in the shedyotamikez is one of the sharper tools in the shedyotamikez is one of the sharper tools in the shedyotamikez is one of the sharper tools in the shedyotamikez is one of the sharper tools in the shedyotamikez is one of the sharper tools in the shedyotamikez is one of the sharper tools in the shed
yotamikez's Avatar
yotamikez's Tacoma Gallery
Behind the fuel door... there are write ups on here.
Old 11-10-2011, 02:54 AM   #6
the full Monty
Manwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shed
Manwithoutaplan's Avatar
Manwithoutaplan's Tacoma Gallery
yea i ran mine from the diff to my driver side cuby hole. then i drill through it. Not very hard you can find the hose at your local auto parts store. I asked for about 7 feet of hose gasoline hose.http://www.tacomaworld.com/forum/tec...od-photos.html
Old 11-10-2011, 03:21 AM   #7
XXXXXXXXXXXXXXXXXXXX
T@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shed
T@co_Pr3runn3r's Avatar
T@co_Pr3runn3r's Tacoma Gallery
The other benefit of doing this is that the oem breather doesn't allow the axle to breath very easily when the fluid builds up pressure from getting hot so it puts pressure on your axle seals. I suppose it is made that way to balance keeping water out and letting it breath past a certain point. I had to have axle seals replaced on my 05 and believe this to have been the cause of them needing replacing at only 53k. I got the truck with 48k on it. I did the mod again immediately upon getting the 08 with 51k on it. The mod breather allows easy 2 way breathing. I believe it is more important for the axle seals than it is to keep water out. The pressure thing happens all the time when driving and axle deep water crossings a lot less often for most folks. Mine's up here high and dry...........
Old 11-10-2011, 03:27 AM   #8
Olson's Avatar
thank you i will do that. how did you get the cubby hole removed to make the drill?
Old 11-10-2011, 03:36 AM   #9
Drilled the hole from the outside in the gas door area. The cubby hole thing is a lift and pull and squish to get it out. Just has little ears that catch and hold it in place. You need it out for access to get the hose on the breather fitting if you put it in the gas door area. If you're putting it in the cubby area then yeah, just pull it out and drill it afterwards.
BTW, the front differential has the breather up high and is one that breaths easy without building up pressure so it isn't necessary to mess with that one according to the 4wd folks.
Old 11-10-2011, 07:46 AM   #10
David K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shed
David K's Avatar
David K's Tacoma Gallery
Olson, some of the photos posted above are from my thread on doing the mod... I recommend you click the link to my thread (below in my sig.)... See it all... http://www.tacomaworld.com/forum/tec...od-photos.html
I opt for easy, and this mod was easy. The water gets in through the AXLE seals, not the stock breather on top of the diff. By changing the one way breather (lets hot gasses out only) to a 2 way (true) breather up higher, it breaks any vacuum created inside the diff., which is what causes water to suck into the diff. when you drive into a foot or more of water (whatever your axle to ground distance is).
The 2 way breather we use, is the same one that is on the front diff. at the end of a tube... Seriously, the Off Road TRDs (or perhaps all 4WD Tacos) should have the same set up on the back, as it does on the front!
My Differential Breather Mod Photos David K Technical Chat 382 08-17-2014 11:08 AM
DIY: Differential Breather Extension Toy4Life 1st Gen. Tacomas 137 08-13-2014 03:44 AM
Creeper Breather - Differential Breather Kit Neubs 2nd Gen. Tacomas 33 10-24-2011 12:55 PM
Front differential breather.... is it LEAKING or normal???? wyotaco06 2nd Gen. Tacomas 3 02-22-2011 08:57 AM
Differential breather Questions Toy4Life Technical Chat 43 09-23-2008 12:53 PM
