-   Southern California (http://www.tacomaworld.com/forum/southern-california/)
-   -   Need deckplate help. (http://www.tacomaworld.com/forum/southern-california/236746-need-deckplate-help.html)
n0ms 08-29-2012 12:38 PM
Lke the title says I need some help with making the deckplate hole in/around san diego.
So does anyone have a 3inch holesaw I can borrow or come by and use?
Also if anyone knows of a good muffler shop that fabs up motorcycle exhuast let me know.
Siebler 08-29-2012 02:14 PM
You can do it with a jig saw or rotozip. We install 100's of them on kayaks and such every year, nothing different about this.
n0ms 08-29-2012 02:36 PM
I have a jig saw ,any blade you reccomend? Don't know what a rotozip is.
Is there a marine shop you know of that sells 3inch deckplates?
Siebler 08-29-2012 04:38 PM
Rotozip is a router. Any jigsaw blade should cut.
3" DP no, 4" I stock. if that fits ill pop one on the box for you for 20.00 total, just have to bring air box to my work.
A 4" plate is 6" over all OD. Never seen much for 3", you could try SD Marine Exchange, theyd be my best bet.
n0ms 08-29-2012 05:25 PM
Okay cool ,will check that shop out.
Think I will cut out the box with my jigsaw if not I will pm you.
LUSETACO 08-29-2012 05:32 PM
I cut mine with a Dremel and a drill bit. I tried a jigsaw but it bounced around a lot trying to make the cut.
n0ms 08-29-2012 11:34 PM
Picked up extra i4 stock intake parts for a 1st gen. Has the airbox, hose that connects to tb and a pretty clean k&n filter.Someone left on the curb and posted on cl. Going to cut into this box 1st.
n0ms 08-29-2012 11:36 PM
Ignore
BurqueTaco 08-30-2012 12:10 AM
I did mine with a drill and a keyhole saw. Cost me about 0 dollars as i havent put on the deckplate yet :D
