Strut Bar Removal ... front end damage posing a problem
Old 07-02-2010, 07:24 PM   #1
seligman [OP] seligman is offline
seligman will become famous soon enoughseligman will become famous soon enough
seligman's Tacoma Gallery
I need to remove a strut bar on my 96 2WD Tacoma. As you'll see in the photo, I have a problem removing it.
Front end damage bent the front side of the bracket which holds the bushing.
Any suggestions on bending the front side frontward again would be most appreciated.
Here's why I need to remove the strut bar. The bracket on the opposite end is broken. Another possibility here is to separate the bolt from the bracket and strut bar (underneath the bracket). The bolts are pressed into the bracket and as you can see, the left one already came loose.
In case you're wondering, I'm planning to weld the broken piece to the bracket again. All I need is for the bracket to separate from the strut bar.
Strut Bar Removal ... front end damage posing a problem-strutbar_stuck.jpg   Strut Bar Removal ... front end damage posing a problem-strutbar_broken.jpg
Old 07-02-2010, 10:15 PM   #2
nvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shed
nvdeserted's Avatar
nvdeserted's Tacoma Gallery
Big pry-bar?
Old 07-03-2010, 12:24 AM   #3
Originally Posted by nvdeserted View Post
Big pry-bar?
Tried that, no success. Also tried hitting it with a small sledge hammer. In both cases I'm not sure if we did it from the proper angle. I thought about putting a metal wedge on a floor jack, just inside the bent bracket, then lifting the jack with the wheels on the ground. The wedge would have to be milled and positioned properly.
Hopefully somebody else has a better idea. Oh yeah, in case anybody asks, I don't have a torch hot enough to bend that kind of steel.
Old 07-04-2010, 02:37 PM   #6
Thought about the chain and tree possibility. I'm afraid that will bend it outward too much.
Needs to be bent in a controlled fashion, because the bracket can't be destroyed and I want to re-use the strut bar after fixing the other end.
Strut Bar Removal -- Need some safety advice seligman 1st Gen. Tacomas 1 08-20-2012 12:02 PM
front strut removal? how to guide and pics gacandido2010 Suspension 2 10-18-2011 11:14 PM
'02 Front end damage 02owner 1st Gen. Tacomas 8 10-29-2010 07:30 PM
what is the maximum lift before premature front end damage? millerlight2496 Suspension 6 09-02-2010 03:59 PM
slight front end damage dirtbikeless 2nd Gen. Tacomas 6 04-04-2010 05:11 AM
