3" lift measurements???
Old 07-13-2010, 09:18 PM   #1
ETaco23 [OP] ETaco23 is offline
ETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shed
ETaco23's Avatar
ETaco23's Tacoma Gallery
I think my Toytec coilovers have settled/sagged over the last 4-5 months. And I would like to know what are some people's measurements from ground to fender flare. With 285/75/R16 AT's.
Im at 38-3/4" both sides. And when I first set them tey were closer to 39-1/4"
I would like to adjust them, But its ganna be nearly impossible... Thanks!
Old 07-14-2010, 10:10 AM   #2
Sublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shed
Sublime's Avatar
Sublime's Tacoma Gallery
I've got Toytec springs with 5100's, these are not the already built coilover set. Originally I was at 39.5" with 2" of thread on the collars and I lowered it to 38.5" to even out with the back. They felt stiffer are the higher setting and I replaced a spacer lift which had me at 38" so I'm happy where it's at. These are rough estimates but if factory is at 35"? 285 km2s give me 1" that means the coils are giving me 2.5". From what I've read every truck is a little different so I just played with it until I liked where it was at. However, with the new coils I'm now rubbing on the cab mounts so those are getting chopped today for $150 both sides. The spacer lift had no rubbing.....go figure!
Good luck man!
Old 07-14-2010, 10:18 AM   #3
chris4x4's Avatar
chris4x4's Tacoma Gallery
38.5" gives you 3" lift with 33" tires.
Old 07-14-2010, 10:33 AM   #4
Sublime's Avatar
Never owned the truck stock so wasn't sure what the factory height was. So I could probably lower it another .5" and keep it at 38". Would like to take advantage of travel and shock dampening more than lift. After that spacer lift I relized I'm looking more for a better ride and I thought the Toytec's would be a little softer with the 600lb spring. I'm happy with them though!
Old 07-14-2010, 06:23 PM   #5
ETaco23's Avatar
Is that measurement the same for the 1st gens.
Cause Im not exactly sure what I need to be at with my 285's.... Is 38-3/4" right?
Old 07-14-2010, 06:32 PM   #6
chris4x4's Avatar
I havent measured the stock first gen
Old 07-14-2010, 08:27 PM   #8
Sublime's Avatar
Do your tires have good clearance/no rubbing? You should be good. It sounds like we both have about the same height.
Nice truck by the way, it looks great!
Old 07-14-2010, 08:32 PM   #9
ETaco23's Avatar
Thanks man! I like yours too.
Yeah, I have some rub but not much. Im just wanting to know if my front coilovers are still at 3" lift or if they've sagged a little. Bc I really dont know what measurement I should be at....
lift measurements on 1st gen dlb cab before and after socal19 1st Gen. Tacomas 2 03-15-2011 07:42 PM
help with lift measurements please tacosupreme54 Suspension 25 10-26-2010 01:24 PM
Need help with 6" lift measurements 07tacoswb 2nd Gen. Tacomas 7 10-07-2010 10:39 AM
3" lift measurements..... ETaco23 1st Gen. Tacomas 24 09-24-2010 08:45 PM
3" lift measurements Stillfly199 2nd Gen. Tacomas 0 03-16-2010 06:50 PM
