5100 install....oops
Old 07-24-2010, 08:35 PM   #1
ryanringle [OP] ryanringle is offline
ryanringle is on a distinguished road
Navy: Missile Technician
ryanringle's Tacoma Gallery
Just got my truck back from the alignment shop, and they were able to align everything, with a caster of 2.0, and 1.8, are these going to be high enough? Also, when I looked at the coil springs, i noticed that the end of the coil spring on the bottom is facing the front, I think it was suppossed to face the rear of the truck, Do I need to take them off and adjust this, or does it not matter?
Old 07-24-2010, 08:53 PM   #2
toycar18 is one of the sharper tools in the shedtoycar18 is one of the sharper tools in the shedtoycar18 is one of the sharper tools in the shedtoycar18 is one of the sharper tools in the shedtoycar18 is one of the sharper tools in the shedtoycar18 is one of the sharper tools in the shedtoycar18 is one of the sharper tools in the shedtoycar18 is one of the sharper tools in the shedtoycar18 is one of the sharper tools in the shedtoycar18 is one of the sharper tools in the shedtoycar18 is one of the sharper tools in the shed
toycar18's Tacoma Gallery
Caster should be high enough.
If it isn't the truck will wander at highway speeds.
Old 07-24-2010, 10:08 PM   #3
chris4x4's Avatar
chris4x4's Tacoma Gallery
Pics would help us.
Old 07-25-2010, 12:36 PM   #4
Here is a pic of the coil with the 5100 installed. Notice how the end of the coil is facing towards the front. Is this bad?
Old 07-25-2010, 12:46 PM   #5
86ceeten has a spectacular aura about86ceeten has a spectacular aura about
86ceeten's Avatar
86ceeten's Tacoma Gallery
You need to fix that asap!!!!!
JK, let it ride. As long as it's seated correctly, which it looks to be, your good!
Old 07-25-2010, 12:49 PM   #6
Banned
Lentsnh is one of the sharper tools in the shedLentsnh is one of the sharper tools in the shedLentsnh is one of the sharper tools in the shedLentsnh is one of the sharper tools in the shedLentsnh is one of the sharper tools in the shedLentsnh is one of the sharper tools in the shedLentsnh is one of the sharper tools in the shedLentsnh is one of the sharper tools in the shedLentsnh is one of the sharper tools in the shedLentsnh is one of the sharper tools in the shedLentsnh is one of the sharper tools in the shed
Lentsnh's Tacoma Gallery
Nah your fine... As stated as long as the coil is seated correctly you'll be fine.. I believe mine are facing in towards the front/center of my truck.
Old 07-25-2010, 02:10 PM   #7
sanga700 will become famous soon enoughsanga700 will become famous soon enough
sanga700's Tacoma Gallery
Acorrding to the pic Rianringle took , Mine is not facing in toward , they ( both side ) facing to the rear of the truck but they sat correctly . Are they safe ? or Should I have to take them off and adjust them ?
Old 07-25-2010, 10:15 PM   #8
Banned
It really doesnt matter which way the end of the coil is pointing, as long as they are seated correctly on the coil seat your fine.
5100 install in N.H. TWhit 2nd Gen. Tacomas 0 10-09-2011 08:38 AM
5100 install toytaco2331 Suspension 9 07-23-2011 01:03 PM
5100 install before/after adamw Suspension 4 05-27-2011 12:04 AM
5100's Install and AAL Install? xcmiler707 1st Gen. Tacomas 6 02-21-2011 10:37 PM
5100 install johnw Suspension 17 03-14-2010 06:46 PM
