6 inch lift... 33's or 35's
Old 06-22-2008, 06:15 PM   #1
caleb337 [OP] caleb337 is offline
Lifted Tacoma
caleb337 is on a distinguished road
caleb337's Tacoma Gallery
I'm getting a 6 inch Procomp lift for my prerunner should I get 33 in. tires or 35's?
Old 06-22-2008, 06:37 PM   #2
branct06 has a spectacular aura aboutbranct06 has a spectacular aura about
branct06's Tacoma Gallery
i have been looking at the 6'' fabtech lift for my truck with the dirt logic shocks, i am looking at putting 35's on my truck when i get the lift. I have seen both 33's ad 35's on the lift and i think the 35's look better, look at some pics on the net or ask a 4 weel parts place if they have done the lift on any other trucks and see what they say....... but i would go 35's
Old 06-22-2008, 06:41 PM   #3
rick is one of the sharper tools in the shedrick is one of the sharper tools in the shedrick is one of the sharper tools in the shedrick is one of the sharper tools in the shedrick is one of the sharper tools in the shedrick is one of the sharper tools in the shedrick is one of the sharper tools in the shedrick is one of the sharper tools in the shedrick is one of the sharper tools in the shedrick is one of the sharper tools in the shedrick is one of the sharper tools in the shed
rick's Avatar
rick's Tacoma Gallery
35's
Old 06-23-2008, 03:21 PM   #4
ricepow is on a distinguished road
ricepow's Tacoma Gallery
How about a 34, lol. Goodyear Wrangler MTR. 305/70-17......specs per Goodyears site, 34.1" x 12.2"......I was running these on my Titan that I just got rid of. Approximately 27K miles and they are still looking good. Probably going to pick up a new set of wheels and use them on my Tacoma with Pro Comp stage 2.
Old 06-23-2008, 06:46 PM   #5
Lifted Tacoma
But, I have heard that if you run 35's you will have to get new gears and everything will start falling apart faster than it usually would. Is this true?
Old 06-24-2008, 07:46 AM   #6
Old & Forgetful
Janster's Avatar
Gender: Female
Janster's Tacoma Gallery
With 35's or 33's and stock gears - you're not gonna have the same power response as when it was stock.
For example: With 33/s or 35's - You're cruising down the highway at 65mph and you approach a hill. As you climb that hill, you quickly lose speed and momentum. You step on the gas to speed up and the truck just won't 'catch up' like it normally would. That's because of stock gears and larger tires.
When you re-gear, you get that power back....(hard to explain).
As for the *falling apart* bit....that would all depend on the kit you're buying, the installation of that kit, any other modifications you should have to make it a better driving/riding/functioning truck, the maintenance you give it, the driving you do, the terrain you take it on....and that's only off the top of my head.
35's and 3 inch lift on 2nd Gen.? JanBoothius Suspension 105 07-31-2013 11:30 AM
3 inch lift with 35's???? francis1291 Suspension 38 10-13-2011 09:03 PM
6 inch lift with 33's? Stillfly199 Suspension 49 09-18-2011 09:30 AM
33's vs. 35's with 8 inches lift up front. con3boy808 2nd Gen. Tacomas 39 05-09-2011 12:22 AM
6 inch lift with 33's seayboy03 1st Gen. Tacomas 12 01-04-2009 02:04 PM
