Need advice about problems with ball joints
Old 08-19-2010, 05:42 PM   #1
Warwookie [OP] Warwookie is offline
Warwookie is on a distinguished road
Marines: Sgt 6th Communications Battalion
Warwookie's Tacoma Gallery
Talking Need advice about problems with ball joints
So I have been seriously looking into getting a lift on my taco. Its an 09 DC TRD Offroad. Im leaning more towards a 3" lift with simple,but very good and dependable black rims. Not sure on the tires yet though. Right now,im pretty lift illiterate and my friend keeps telling me to get a full suspension lift because if i dont it will mess with the ball joints and i will have to replace the control arms. Is this true? I know what a body lift is but can someone please explain to me the difference between suspension lifts if there is one? Also any suggestions on rims and tires would be awesome. Thxs taco lovers!
Old 08-19-2010, 05:55 PM   #2
Rich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shed
Navy:
Rich Beauregard's Tacoma Gallery
This is the (Old Man Emu) OME 885 Springs and OME Front Struts I put on a 2010 Tacoma 4x4 Dbl Cab LB TRD Sport. They lift it about 2-3/4" up front. If you want more add the top spacer they offer from toytec. It's about 1/4" thick, but adds 3/4" in lift. Best place to get good deals I was able to find is: www.trdparts4u.com
Old 08-19-2010, 05:59 PM   #3
Another Toyota Enthusiast
toyo freak is one of the sharper tools in the shedtoyo freak is one of the sharper tools in the shedtoyo freak is one of the sharper tools in the shedtoyo freak is one of the sharper tools in the shedtoyo freak is one of the sharper tools in the shedtoyo freak is one of the sharper tools in the shedtoyo freak is one of the sharper tools in the shedtoyo freak is one of the sharper tools in the shedtoyo freak is one of the sharper tools in the shedtoyo freak is one of the sharper tools in the shedtoyo freak is one of the sharper tools in the shed
toyo freak's Avatar
toyo freak's Tacoma Gallery
X2 nice post
You will prob need new Upper controll arms with three inch lift. Make sure you get 4.5" bs wheels
Old 08-19-2010, 06:03 PM   #4
Navy:
I have about 35,000 miles on my Silver Tacoma since I put the OME 886 Springs and OME Struts. No ball joint problems. Note: OME 885 springs are good if you have no added weight to the front. I used the OME 886 springs because I have the extra 300lbs with the 200lb ARB front bumper and about 100lb T-Max 10k Winch.
Old 08-19-2010, 06:09 PM   #5
Navy:
As you can see, No need to change the upper control arms with 3" lift, but I do agree if you buy new rims, get a 4-1/2" back space (4.5" BS)
Also the Dakar rear leaf springs give a good 3" lift in the rear.
Old 08-19-2010, 06:12 PM   #6
4.5 bs wheels? What exactly does that mean? Im sorry, im just in the process of learning all of this? What should i look for if i have to get a different control arm and is that all i would need? What would i do about the back of the truck? I read about blocks or leaf springs and leaf spring packages.
Old 08-19-2010, 06:29 PM   #7
Navy:
Some things you will see: AAL = Add A Leaf, BS = Back Space (That's the distance from the back edge of your rim to the back edge of the center part of the rim.) you need about 4.5" BS to clear a bigger tire on your upper Control Arms (UCA)
Old 08-19-2010, 06:35 PM   #8
Ok So all i would need in the back is those leaf springs and that would give me the 3 inches to equal the front? Do i still get a good weight load with those or better? Im still a bit confused. Do i get a kit that does the front.
Old 08-19-2010, 06:55 PM   #9
No better friend,No worse enemy...
InfidelTaco has a brilliant futureInfidelTaco has a brilliant futureInfidelTaco has a brilliant futureInfidelTaco has a brilliant futureInfidelTaco has a brilliant futureInfidelTaco has a brilliant futureInfidelTaco has a brilliant futureInfidelTaco has a brilliant futureInfidelTaco has a brilliant futureInfidelTaco has a brilliant futureInfidelTaco has a brilliant future
Marines: iKill
InfidelTaco's Tacoma Gallery
Dont forget to do ur alignment after u complete ur front lift alignment...
Old 08-19-2010, 10:31 PM   #10
nvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shed
nvdeserted's Avatar
nvdeserted's Tacoma Gallery
You don't need to worry about ball-joints when lifting these things.
Many folks find it beneficial to add aftermarket upper control arms (UCA) so they can get the front tires aligned properly and/or get a little extra performance out of coilovers.... Many folks lift and never add UCAs...
The only thing you need to watch is your CV angle (basically the little drivelines in the front with the black accordian booties on them). Generally a 3" or less seems to be ok but they'll likely wear out a little earlier than stock.
BTW, a "suspension lift" is any modification to the suspension that results in the vehicle be higher. Blocks, Spacers, Adjustable/extended/lifting coilovers, AAL, custom leafsprings, oversized spindles, extended shackles, etc = suspension. Basically, the only lift type that is not "suspension" is a bodylift (extended bushings/pucks/spacers between the truck body and frame.
Old 08-19-2010, 10:34 PM   #11
nvdeserted's Avatar
There is some choice for the rear lift. if you want it to look level you probably want anywhere from 1" to 2" of rear lift; if you want the rear a little higher, like it's tilted right now, then you'll want 3" in the rear.
Lower ball joints leaking - need advice DTacoms Suspension 21 11-08-2012 09:52 AM
Does anyone have any advice on greasing my new moog ball joints? Stout890 1st Gen. Tacomas 6 09-24-2011 01:23 PM
best ball joints? Joels98taco 5 Lug 9 04-07-2011 08:02 PM
Ball Joints twfsa 1st Gen. Tacomas 1 07-11-2010 05:48 PM
got ball joints! tacomaforlife 1st Gen. Tacomas 7 07-05-2010 11:12 PM
