Fox coilovers vs drop bracket lift
Discussion in 'Suspension' started by especk, Aug 22, 2010.
  1. Aug 22, 2010 at 4:46 PM
    especk
    especk [OP] Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    So right now I'm running a 2.5 inch Daystar coilover spacer lift with 32 inch tires on a 2010 reg cab 4 cyl.
    I want to upgrade to a better lift. I was looking at the Pro Comp 6'' stage 2 lift with 35"s but thinking it may be too high. I would gear it with 4.88's but would I have any driveline issues or any other problems to worry about?
    Or secondly, I was thinking about running Fox coilovers in the front with All-pro 3'' leafs in the rear. Would I need to worry about any CV issues with the new coilovers? Also, does anyone know how much lift the 2.5 Fox coilovers will give me? I think it's 3", but not sure. What's the largest tire I would be able to use with this set up?
  2. Aug 22, 2010 at 5:05 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    coilovers will give you 3" max. but i wouldnt go over 2.5" due to putting to much tension on the springs making them very stiff.
    33" tires max on a 3" lift but you will get rubbing at full turn and reverse.
  3. Aug 22, 2010 at 5:14 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    Drop brakets will be the way to go. B/C the drop brackets will give you the lift while keeping all of your steering/axle components in the same position preventing wear/alignment issues/vibrations and so on. If I wanted to lift my truck 4" I would do drop brakets. Anytime you lift with shocks/springs/coilovers you loose some down travel. With drop brakets you keep all of your down travel
  4. Aug 22, 2010 at 8:05 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    but drop brackets also weaken your suspension...and make your center of gravity higher with the 6" lift. not the ideal set up for wheeling. if you dont wheel too hard and are mostly on road it would be ok.
  5. Aug 23, 2010 at 8:32 AM
    tacoma44x44
    tacoma44x44 Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    ^^^^ I don't agree with a DB lift weakening your suspension??? if anything makes it way stronger.
  6. Aug 23, 2010 at 8:39 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    so cutting your solid crossmember and bolting in a new piece makes it stronger? I hope he wont be around any rocks to snag it on! you gain no additional ground clearance with a DB lift...so other than looks they dont serve that much of a purpose
  7. Aug 23, 2010 at 8:41 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    I would rather stay away from a DB lift if you wheel. They don't really add to much clearance besides being able to stick bigger tires on it.
  8. Aug 23, 2010 at 8:47 AM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    Ya cutting out your pissy ass cross member and replacing it with 1/4 inch steal brackets is making it worse? All the cross members are so thin and weak it's actually really disappointing.
    I'm not debating the fact you don't gain any ground clearance but the DB lifts beaf up the suspension way more than the shitty stock setup.
  9. Aug 23, 2010 at 9:49 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    DB lifts are a piece of shit. Dont ruin your truck. (Unless thats what youre going for?)
  10. Aug 24, 2010 at 7:34 PM
    especk
    Erik
    Redding, CA
    thanks for the comments. I knew that some of you would be hating on the DB lift. But besides a higher center of gravity and possibly slightly weaker suspension components and relatively low front diff clearance, what else do I need to worry about with the DB lift - anything? This truck wont be used for wheelin' too much. It will mainly be a street rig but will occasionaly be taken offroad for huntin but probably no serious wheelin'.
    Will I have any CV or driveline issues with the higher lift? Any serious vibration issues I should be aware of? I am mainly concerned about any critical angles that may be made by the 6" DB lift. Any comments would be appreciated.
    thanks!
  11. Aug 24, 2010 at 7:39 PM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    thats what the DB lift does is keep all your suspension components as close to factory specs as possible.
    But for the most part you will be sacrificing something with any type of "lift"
    I get driveline vibes pretty bad so i am gonna be looking into a 1 piece driveshaft
  12. Aug 24, 2010 at 8:10 PM
    especk
    Erik
    Redding, CA
    Thanks. I'm pretty set on this Pro Comp 6" stage II.
    44x44, what lift r u running?
  13. Aug 24, 2010 at 8:17 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    i have these but 3"
    Pretty dirty i know
  14. Aug 25, 2010 at 7:24 AM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    i am running a 6" fabtech just installed it a week ago
    I see you have a 2010 so you kinda have to go with the Pro comp its the only one that's compatible with your VSC. The pro comp kit is a nice setup, but just a suggestion if i was you i would get the stage 1 and upgrade to the icon 6" coilovers for the fronts. i have heard nothing but good things about them.
  15. Aug 25, 2010 at 9:23 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    X2 to both of those...:D
  16. Aug 25, 2010 at 9:34 AM
    mjp2
    Milton Juevo Portimous II
    NJ
  17. Aug 25, 2010 at 10:34 AM
    especk
    Erik
    Redding, CA
    ok guys so i'm goin with a Pro Comp 6" stage II. I appreciate all the comments. Last thing - I'm a 4 cyl and I'm gonna throw in 4.88s when I get it lifted. My question is, should I go with 33" tires or 35"s? I'm concerned my truck may not have enough power to push those 35's even with the regear.
  18. Aug 25, 2010 at 10:43 AM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    if you just got the 4 banger i would go with the 33's but if your re gearing you should be fine with the 35's..
  19. Aug 30, 2010 at 6:46 PM
    09OFF-ROAD
    09OFF-ROAD Member
    Bridgeport, Newfoundland, Canada
    09 TRD Off Road 6-Sp
    TRD Cold Air Intake, Bug-Deflector, Headlight and tailight covers, back rack. 4 hella 550 driving lights on back rack, 3" suspension and 3" body lift, KMC XD Spy wheels 18"x9" with 34x12x18 Nitto Trail Grapplers. Alpine IVA-W505 head unit with Nav. and Bluetooth, Alpine Type R 6.5" components in from, Type-R 6.5" speakers in rear doors. Speakers powered by Alpine 4 Channel Amp 90Wx4 RMS. 12" Alpine Type-R Sub in bass worx ported box powered by Alpine 500W RMS Mono Amp
    I have a 09 Off Road with a 3" spacer and 3" body lift with 35's. Should I re-gear? I find the truck a little bit worse then stock for acceleration and losing speed on hills but nothing worth talking about. Where would you buy gears to do it??
  20. Aug 30, 2010 at 7:01 PM
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    Warranty, trade in value, Higher COG, overpriced...
    For a street rig it should be OK though. Id go another route but....To each his own. Just get your gearing correct.
