Anyone had any experience with these...King Coilovers
Discussion in 'Suspension' started by Mytidawg, Sep 21, 2010.
  1. Sep 21, 2010 at 5:20 PM
    Mytidawg
    Mytidawg [OP] Active Member
    Vince
    Bay Area, CA
    07 Tacoma 4x4 Sport
    ARB front bumper, King Coil over suspension
  2. Sep 21, 2010 at 5:41 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Great coilovers and that is a great seller. They are here on the site, PM downsouthmotorsports.com and you get a Tacomaworld discount
    Ive been in a 1st gen with them and they are loads better than stock
  3. Sep 21, 2010 at 5:43 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    can't go wrong with king, there are many members here running king OE coilovers
    i'm about to put some kings on my truck
  4. Oct 11, 2010 at 12:10 PM
    Mytidawg
    Vince
    Bay Area, CA
    07 Tacoma 4x4 Sport
    A quick question about these coil overs.....do they change the camber of the tire?
    noneck180....the spindles are stock right on your taco ?
    VF
  5. Oct 19, 2010 at 12:20 PM
    AKtoyTaco
    AKtoyTaco Well-Known Member
    Adam
    Anchorage, AK
    2011 TRD Double Cab
    Those are freaking HOT! I've got a 2011 DC Off Road ordered which should be here in a few weeks. Already ordered my full King system. Can't wait to put it together!
  6. Oct 19, 2010 at 12:30 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    now that is some badass suspension ... just add a pair of uca's and spindles and you have yourself a damn good mid-travel set-up
  7. Oct 19, 2010 at 2:37 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    If you run them at stock height then no, if u crank them up any bit they will knock ur alignment out, so u need to get realigned, it's like that with any lift
  8. Oct 20, 2010 at 12:28 PM
    AKtoyTaco
    Adam
    Anchorage, AK
    2011 TRD Double Cab
    Would you be willing to expand on your comment "a harsher ride than I anticipate" ? I've already ordered my King's and was hoping that it would be a more plush ride than stock. Can you give me a quick compare/contrast between the stock ride qualtiy & the King ride quality? Before I install everything I want to make sure it is going to give me the ride I'm looking for. Thanks in advance for your help, you have a great looking truck!
  9. Oct 20, 2010 at 12:32 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    its gonna give u a great OFF ROAD ride.... i think with most after market COs they are gonna give u the same ride.... I have the same setup and it is a little stiffer and i would suggest not to have them cranked super high... are u looking for off road or on road capabilities...
  10. Oct 20, 2010 at 1:22 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    x2
    any coilover cranked up will ride stiffer on road, but the truck will feel tighter in the turns...
    if you leave them cranked down, at neutral, the shaft travel is nice and smooth... now that would be cush...
  11. Oct 20, 2010 at 1:31 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    i <3 my Kings...
  12. Oct 20, 2010 at 5:04 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    mike is big pimpin gangsta
  13. Oct 20, 2010 at 9:05 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    so do i :drool:
  14. Oct 22, 2010 at 11:59 AM
    AKtoyTaco
    Adam
    Anchorage, AK
    2011 TRD Double Cab
    Rock on, thanks for the additional input. My shocks just came in this morning. I am going to go check them out as soon as I get off work. I don't even have my truck yet... (should arrive in about 2-4 weeks) but I've got my Kings! Most of my driving will be on-road, but I live up in Alaska and there are tons of places to go play, and I will make time w/ the new truck. My initial plan is to leave the coilovers set the way they come from the factory. around 2 inches or so of lift... I believe. I want them just high enough to squeeze some 285/70/17's underneath. I'll post pics as soon as I get all the pieces in!
  15. Oct 22, 2010 at 3:41 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    If the ride is too harsh maybe look into getting a different spring. I think the from the factory spring rates for Tacoma's are 650...maybe bump it down to 600 or even 550. That will give you a better ride for the street but for wheeling id think 650 would work out very well!
    Are king and fox springs interchangable?
    EDIT: looking on king's website they only have 500 and 600 they dont show a 650 or a 550.
