bjmoose installs full OME kit & rear brake lines with pics
Old 01-31-2013, 10:02 PM   #121
totmacher has a spectacular aura abouttotmacher has a spectacular aura about
totmacher's Avatar
totmacher's Tacoma Gallery
Originally Posted by Hippynotions View Post
so the new UCA's would compensate the twitchy steering? and bring it back to stock handling are both of your lifts 2"
I guess my lift was called a 2 inch lift. OME 885s WITHOUT the top spacer.
The amount of lift you'll see from before and after measurements will depend on how worn out your old parts were. I measured 3 inches lift in the front but I know my stock springs had sagged a lot and one of the stock struts had been leaking. Someone else might only measure 2 inches lift by installing the same setup if their stuff isn't worn out so much.
Old 02-04-2013, 02:21 AM   #122
SR5808 is on a distinguished road
SR5808's Tacoma Gallery
Nice
Old 02-10-2013, 09:19 AM   #123
geogecko has a spectacular aura aboutgeogecko has a spectacular aura aboutgeogecko has a spectacular aura about
geogecko's Tacoma Gallery
Thanks for the excellent write up. I was just installing 5100's all around, but 80% of this still applied.
The part that didn't work out for me was trying to get the bottom of the strut back into the LCA mount. I tried everything suggested, but couldn't get it back in there. Tried several pry spots, but didn't want to risk breaking the brake line or ABS wires.
In about 2 hours of frustration, I stumbled on the solution, and even ended up pushing the strut mount in by myself, but still required the help of my wife to get the bolt installed.
What I did, was climb up into the wheel well, placing my hand right on the ball joint on too of the UCA, then placed my outside knee on top of the caliper. Then I just pushed against those two points with my back against the wheel well, and it's like the whole assembly dropped 2+ inches! It was such a relief after struggling for so long, wondering what to do.
Taking all my borrowed tools from Advance Auto back for $Free.99!
Old 02-16-2013, 11:39 PM   #124
phatso is on a distinguished road
phatso's Tacoma Gallery
Originally Posted by bjmoose View Post
I am confused... my kit did not come with the thing at the top of your spring...here is what I have...
Am I missing anything...and will I be using anything from the original assembly?
Edit: I think I missed this...
NEW: We now offer Assembly with new top mounts and bushings for $100.00! Choose from options below.
Am I screwed and have to order this...or can I use the old assembly...or can I get this from Napa or O'Reillys?
Old 02-17-2013, 08:12 AM   #125
bjmoose [OP] bjmoose is online now
Bullwinkle J. Moose
bjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shed
bjmoose's Avatar
bjmoose's Tacoma Gallery
You can re-use the existing ones that are currently on your truck.
The only disadvantage is you need to have a shop with a spring compressor disassemble your old coilover assembly and assembe the new one with the new springs.
Spring compressors you can rent to use yourself down at e.g. Napa typically aren't strong enough to compress the OME springs.
Old 02-17-2013, 06:00 PM   #126
I'm finally finished. I decided not to use the top plate spacer and I'm happy with my decision. However it sounds like the aal is squeaking, is that normal? Will it go away with time?
Old 02-17-2013, 08:02 PM   #127
Bullwinkle J. Moose
bjmoose's Avatar
squeeking leaf packs are pretty normal. If it's not loud you may wanna just live with it.
Old 02-18-2013, 08:35 PM   #128
Did you all not have front drive train vibrations after installing the lift in the front? I just did 0.85 5100's and have vibrations...
Old 02-19-2013, 06:15 AM   #129
penguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shed
penguins_cc's Avatar
penguins_cc's Tacoma Gallery
Send a message via Skype™ to penguins_cc
No vibes after installing the OME lift. Most people don't have vibes after installing 5100's at 0.85 either.
Old 02-19-2013, 06:44 AM   #130
Ugh, guess I got unlucky, unless its something else...
Old 03-14-2013, 01:05 PM   #131
Stay Calm, and Fire For Effect
YOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shedYOTA LOVER is one of the sharper tools in the shed
YOTA LOVER's Avatar
Army: Training NCO, B Btry, 3-197th FA
YOTA LOVER's Tacoma Gallery
Kudos to the Moose! Great write-up and pics!!!
I went with the OME 2" heavy kit (towing and trail armor) and installed as soon as I purchased the truck. I installed the drive-line spacer (4-door 6' bed) and the diff drop for good measure and haven't encountered any drive line issues after 15k on the lift.
Maybe I should have made some measurements before and after but I gambled that OME did their homework. Your attention to detail should be commended BTW.
The only downside to the kit is that the truck was dead level before I put on the All-Pro bumper and skid plate and now the front has settled down a bit. I got the heavy kit to avoid sag. Maybe I'll cheap out on a 1/2 spacer? Dunno yet. Throwing a lot more $$$ at the suspension isn't an option right now.
EDIT: Have been informed by many gurus that OME upgraded/fixed their front springs, so the old 885 or 886 have become 885X and 886X, which can be found on a dainty little tag when you get the spring. The "X" series isn't prone to sag. Dunno if there are any of the older version still being sold or if there are still some floating around in warehouses.
Follow up: Verified mine were the newer 886X. No kidding, they still sag like a mutherf@c(er. So, in went the 13mm spacer. I did recover 1" of lift, and the overall rake on the truck is 1/2".
Old 03-14-2013, 01:10 PM   #132
YOTA LOVER's Avatar
Spray silicone lube will do the trick. The Dakar's I ran on my 95 developed a squeak as they began to accumulate surface rust and dirt, so I sprayed the hell out of them. It doesn't look pretty, but it'll get the job done.
Old 03-31-2013, 10:14 PM   #133
Eastsyde*808* is on a distinguished road
Eastsyde*808*'s Avatar
Eastsyde*808*'s Tacoma Gallery
"MAJOR PROPS" to you moose for the helpful write up on the ome kit!!!!
i just installed the 3" leaf pack w/shocks today and what a "HELP" it has been!!!!!!! and its good to have a ipad too!!!
i had a pro comp 3" kit before but my friend did it and couldnt remember how to do it again (he wasnt there to help).
p.s. that bottle jack theory made it sooo much easier too!!!
Old 06-06-2013, 02:44 PM   #134
Mama says Tacoma World is da devil!
bjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shedbjboucher is one of the sharper tools in the shed
bjboucher's Avatar
Air Force:
bjboucher's Tacoma Gallery
If I'm replacing my UCAs at the same time, will that make more room for me to get the new shock in or am I still going to have to force down the lower control arm to make some room? Will I still need to separate the tie rods?
Old 06-06-2013, 02:57 PM   #135
evanmb31's Avatar
evanmb31's Tacoma Gallery
If you pull the UCA out you dont need to mess woth the tie rods, there is enough room. I had to pry my lca just a little bit, barley any force to work the eye of the shock in, this was with OME 885s and nitrochargers. I got the shock in place, then shoved a catspaw in between the eye of the shock and the LCA mounting location, made it really easy to line everything up and push the bolt thru.
Old 06-06-2013, 03:16 PM   #136
bjboucher's Avatar
Air Force:
I'm getting 885s with the newer sport shocks. Hopefully it's just as "easy" as yours!
Old 06-06-2013, 03:29 PM   #137
evanmb31's Avatar
I was surprised how easy it was, especially with write ups like this one, props to bjmoose. There is a couple other good write ups floating aroud here, some good ones that are not stickied also.
Old 06-14-2013, 07:39 AM   #138
bjboucher's Avatar
Air Force:
What direction do the axle shims go in? The narrow end facing the front or the back? Lift gets here Monday, doing the install next Saturday. Can't wait!
Old 06-14-2013, 07:42 AM   #139
YOTA LOVER's Avatar
Narrow to the front. But I didn't bother adding any when I did mine.
Old 06-14-2013, 07:45 AM   #140
bjboucher's Avatar
Air Force:
Thanks. I ordered them with the kit, just in case. I'm still debating using them. I have some vibes stock so maybe the lift will "cure" them.
bjmoose installs receiver winch bjmoose 2nd Gen. Tacomas 36 12-05-2014 05:09 PM
bjmoose installs CB Cobra 75 bjmoose 2nd Gen. Tacomas 33 12-30-2013 12:04 AM
bjmoose installs HAM Radio with NMO antenna mount bjmoose Audio & Video 23 06-30-2013 09:30 PM
FS Extended Rear Brake Lines for 05 & UP Tacoma Jesse1983 Buy / Sell / Trade 4 02-14-2012 10:23 AM
OME full kit installed *pics* especk 2nd Gen. Tacomas 78 02-23-2011 09:52 PM
