| Register | Search For Products | Site Information | Glossary | Calendar | Search | Today's Posts | Mark Forums Read |
#21 | |
Thanks, Sam PS- so those are factory 245/75/16's on there now?
__________________
Sam, Bianca, Matthew 8, Ethan 4 07 Tacoma, DC, SR5, Susp. TSB http://littlehartsfields.blogspot.com/ |
#22 | |
If you wanted to change the height, you'll probably have the remove the shocks completely every time. It's a good idea to have an alignment done whenever the suspension/steering is messed with so I got that done as well. To be honest, the steering was wobbly and went all over the road when I first got it. After the tie rods were replaced and the Bilsteins were installed with another alignment did the truck not run all over the road. The shocks perform great. Dips that would completely compress the OEM shocks before are now just comfortable to drive through, at faster speeds. Stock BFG Rugged Trails 265/70/16. They suck. The truck has 58K on it; not sure if the previous owners replaced the factory tires with the same ones or if the tires currently on my truck have been on it since it's rolled off the assembly line. |
#23 |
Cool, thanks. Looks like 5100's up front make the most sense for me as a first step, if I can get a deal... might buy 4 of them. Seen some posts, 2 are 199.00 and 4 are 259.00??
will see. Thanks Bambooshoots & TW crew! I have one last question to post about adjusting the 5100's under suspensions..
__________________
#24 | |
#25 | |
Western Aliance: Fix it Division
__________________
The simplest solutions are often the most clever..............they are also usually wrong. |
#26 |
I've been reading everyones postings, I have a question now!
So I ordered all four 5100's, and a AAL. I have 33'' tires I want to mount on my 05 taco, they are the toyos 295/70/17 on 17x9 wheels. Is this 2.5'' lift in the front going to be enough combined with the AAL and rear 5100's??? I have currenlty the OME 885 coils with spacers, but I was wondering if it would be better to do all four 5100's or the 885's in the front and 5100's on the rear? Any info will be greatly appreciated! SO in a nutshell, 3'' toytec OME885 vs. front 5100, is it a "huge" difference? WIll they both fit 33'' tires? |
#27 | |
__________________
#28 | |
If I am going 3" or great, OME shocks with OME springs (Your Advice, and I will follow if that direction is taken).. I am really interesting in the 5100's now.. seems cheap, and adjustable so I can play with it. Can they be adjusted on the fly?? please let me know.. one more dang inch in back the via AAL with the TSB susp. would be... relaxing Thank you Chris! -Sam
__________________
#29 | |
__________________
#30 | |
__________________
#31 | |
Nope, everything is laying in my garage brand new, the 885's and 5100's, and wheels! I want to wait until I have everything ready and then get it all done at once. Thats why I'm debating what to do! will I need spacers? I have no clue, this is all new to me! I'll probly go with the 885's and AAL with 5100's in the rear...This seems like the best from what I've read... |
#32 | |
__________________
| Display Modes | |
| 2.5" Leveling Kit. | roxspin72 | Suspension | 11 | 03-17-2008 01:15 PM |
| 2" leveling kit? | mbaltonv | 1st Gen. Tacomas | 5 | 02-07-2008 01:30 PM |
| 6" Pro Comp on 07 Tacoma | caglezxj | Suspension | 53 | 01-23-2008 06:39 PM |
| 16" Ultra Wheels and 33" Pro comp X-Terrain Tires | mattyrez09 | Buy / Sell / Trade | 3 | 01-12-2008 01:50 PM |
| 4" Lift kit? | Slvr_DblTaco | Suspension | 11 | 11-10-2007 08:14 AM |
